magnetic screen door - Page 2 - Fiberglass RV
Old 04-06-2013, 09:09 AM   #15
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Donna, I'm talking about the wood part. It's 1/8" thick, no way it's structural. Plus, the closet is on one side of the door, and the bunk support is on the other. The square tubing I'm leaving. I'll chuck the piece in and get a picture of it later.
Noreen, thanks for the info. I haven't heard back yet from them.
Old 04-06-2013, 09:15 AM   #16
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
While it may not fit the curve of the Scamp door (although by setting it back a bit it works on my Escape 17) the Vista Plus Screen Door takes up very little room & works well.
The link is to one of the Escape Forum's File Download pages.
Old 04-06-2013, 10:05 AM   #17
That door, the Escape screen door, is totally cool. If I didn't already have one I liked, I'd definitely be looking into it!
Old 04-06-2013, 10:47 AM   #18
santacruzer's Avatar
Trailer: Escape 19
The Escape screen door (Vista Plus) does have it's shortcomings. The dog sees right through it...and has jumped through it twice now. Even I walked through it once. So far, I'm not willing to paint a spot on it, or sew threads in it, just trying to live with it by being very careful. I did add a handle on each side to make it a little easier to grab. I've also found you need to slide it open and closed with equal pressure on the top and bottom. I'm also looking at supplementing it by adding a magnetic screen.
2009 Tacoma 4DR TRD 4wd
2007 Tundra 4DR TRD 4wd
2012 Escape 19
2007 Norwegian Elkhound "Baxter"
santacruzer is offline   Reply With Quote
Old 04-06-2013, 11:26 AM   #19
Trailer: 2008 13' Scamp
The more I read on this thread, the more I appreciate how well my Scamp screen door works.
Old 04-06-2013, 05:54 PM   #20
Jared J's Avatar
Kansas
I don't appreciate how it ruins 7" of seating space. That, and it's all horrid craftsmanship and needs to be redone anyway, if it's going back in.
Old 04-06-2013, 08:36 PM   #21
Pam Garlow's Avatar
Trailer: U-Haul 1985
Maybe it's not as bad as you think? Many people (me for one) would just curl into the corner against the side wall. I've camped with several other Scamp owners and have never had one complain about it. But everyone has their own personal preferences about their rigs, so you've got the right to personalize yours as you want.
But if you choose to remove the door, I don't think you'll have any problem reselling it. People love them scamp folding screen doors
Old 04-06-2013, 08:57 PM   #22
Jared J's Avatar
Kansas
It would be one thing if I could give it a coat of paint and revisit the issue later. However, there are saw cuts showing on the top piece over the opening, the piece in the picture is as rough as bark, and the piece that goes against the closet has uneven cuts on it, and it all has unsightly gaps, so it needs to be redone either way. I might still just do that, I was trying to avoid it, though. We'll see if I get an answer from the screen place.
I don't think I'll use the screen that much either, otherwise it wouldn't bother me as much. Unless its between 55-75, that door will be closed (at least if I'm at a place with power).
Old 04-07-2013, 05:42 AM   #23
Pam Garlow's Avatar
Yep, slivers are not a good thing, and it might be difficult to sand and paint that frame in place. Sounds like you are working on several options.
I'm a big fan of keeping my door open as much as possible. I even have a plastic curtain to hang in the doorway for inclement weather, so I can keep my heat inside and maintain a view to the outside. Maybe you can simply put plexi on your folding screen door if you want to open the big door more often
Old 04-07-2013, 06:20 AM   #24
Jared J's Avatar
Kansas
Now that's an interesting thought.
Old 04-07-2013, 06:34 AM   #25
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
Jared, you got an awning and a screen door with your rig? I'm jealous! I got neither and I'm scrambling to find some.
Old 04-07-2013, 06:50 AM   #26
Now here's a nice home made screen door.
New Wood Screen Door - Casita
Old 04-07-2013, 07:27 AM   #27
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Yeah, I really love how out of the way it is when open. We might use the screen 50% of the time, and it is nice to not have to deal with it when not in use.
I have had those screens that open with the door on stickies, and boy are they a pain to use. We I first looked at Escape, they too were using a bi-fold that I saw as a huge improvement for my needs, then when I saw the roll-up screen being used I was loving it.
We really have not had much issue with trying to go through it when closed, just once for me. Our dog has never had an issue, and can always tell when it is closed. The nice thing with it is, that if it even gets knocked out of its tracks, it is easy to put back in place.
Escape does the same thing for making a plumb opening in a curved wall, though the amount of curve is less. Kinda necessary, unfortunately.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-07-2013, 07:45 AM   #28
Dudley's Avatar
Trailer: 1998 Casita 17 SD
There was a forum from last year about these screens, Mine works well but I have a straight door
BUG OFF SCREEN DOOR
Screen door ?? koehlerk Modifications, Alterations and Updates 1 07-14-2011 02:06 AM
new screen door! Bud Kennedy Care and Feeding of Molded Fiberglass Trailers 5 07-12-2010 09:01 AM
New screen door! April Wilcox Modifications, Alterations and Updates 10 09-09-2009 11:51 AM
Screen Door david duboe Problem Solving | Owners Helping Owners 16 01-30-2008 02:18 PM
screen door james kent Modifications, Alterations and Updates 15 04-06-2006 08:42 PM
