Make-Your-Own Surge Protector - Fiberglass RV
Old 07-29-2010, 07:07 PM   #1
Jane P.'s Avatar
Trailer: Bigfoot 19 ft
Lightbulb Make-Your-Own Surge Protector
I found the following thread on making-your-own Surge Protector on the Casita Travel Forum.
http://www.casitaforum.com/invboard/...showtopic=6952
The poster shows how to make your own surge protector for a fraction of the cost of a new one. If you read through the entire thread you'll see alternate approaches.
I think this is a terrific discussion and wanted to pass it on.
JMP
Jane P. is offline   Reply With Quote
Old 07-30-2010, 01:36 AM   #2
Trailer: 2005 13 ft Trillium Outback
Thanks.
Curtis F. is offline   Reply With Quote
Old 07-30-2010, 09:48 AM   #3
Joe Z's Avatar
New River AZ
Great link......
I need to make one of these as i have already burnt out two directv receivers from surges and this should be the answer.
Joe
Old 07-30-2010, 11:08 AM   #4
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
Link is only good if you are a Casita forum member.
Bryan L. is offline   Reply With Quote
Old 07-30-2010, 11:14 AM   #5
Joe N's Avatar
Trailer: none
Wyoming
This is a copy of the post on the casita forum for those that are not members over there.
Posted 24 July 2010 - 10:58 AM
I have been meaning to purchase a power line surge protector for our Casita. I am not the type that would dream of plugging a TV or home stereo system into a home plug without some sort of surge protector, but here I am three years into this new camper without any surge protection. Just think what a high voltage spike could damage: converter, refrigerator, AC, sound system etc. Enough to really ruin a trip!
What I wasn't prepared for was the cost of commercial surge suppressors for campers/RVs. It appears that a simple inline protector starts at about $80. Hard wired units that protect against low voltage or power line frequency problems quickly cross $300. These may well be worth the money for peace of mind, but I just want basic protection from over-voltage spikes. Three MOVs (Metal Oxide Varistors), a plug, socket and short section of chord shouldn't cost $80. I went to the shop and found the parts left over from past projects, but since I assume most readers of this Forum are not ham operators and pack rats, I tried to track down a source for these items.
Parts list:
Radio Shack MOVs (part 276-568) about $2 each X3
30 Amp 3 prong female receptacle (Camco) about $6 any RV store
Short 30 amp male molded plug/chord about $10 any RV store
Attached Image: KAMCO parts (Small).JPG
Male Plug and chord and Female receptacle
Attached Image: MOVs (Small).JPG
The three MOVs are mounted across the hot and neutral wire, The hot and ground terminal, and the neutral and ground terminal. All three are needed to protect against common mode spikes (typical of nearby lightning strikes). The Camco receptacle has enough room to hold all three MOVs without any modification.
Attached Image: Labled receptecal (Small).JPG
Finished labeled project
Why would you not want to do this? There is no liability or damage insurance that is typical of commercial products
I got the CAMCO recepectal from Dixie RV in Newport News, VA. It was some years ago for a project I never completed so I guess prices have gone up (high price of plastic I guess).
You could do the same project with a short 30 amp extension cable and a simple 110 volt electrical junction box in the middle. Cut the cable in the middle and mount the MOV's in the box. I was just using what I had on hand.
Not much at drawing schematics, but I copied the installation diagram from the CAMCO unit.
In a perfect world, two MOVs would be enough, but is either the neutral or the ground lead are not functioning, a common mode spike could cause damage.
Attached Image: MOV Placement (Small).jpg
Jeanne & Gil & Oliver
16 foot FD 2007
Rocinante II
2006 Toyota Highlander V6 FWD
Factory tow package
Hensley CUB sway/WDH hitch
Jeanne & Gil & Oliver (the dog that owns us)
This is a copy of Jeanne & Gil's post, for your convenience. I did not make copies of of the other replies.
Joe N is offline   Reply With Quote
Old 07-30-2010, 09:43 PM   #6
Jane P.'s Avatar
I believe you can go to Casita Travel Forum as a visitor. Look up "Electrical". then "Surge protector".
BTW, you don't have to own a Casita to join the forum. And ... it's a good one.
Old 07-31-2010, 01:26 AM   #7
Roger C H's Avatar
These aren't so expensive:
DeltaSurgeProtectors.com - Homepage
Old 07-31-2010, 05:14 PM   #8
Bob H's Avatar
Trailer: 1983 Scamp 13 ft Standard
For what it's worth, a safe solution for those folk who have sensitive electronics like TV, laptops, radio, etc is to purchase a uninterruptable power supply. Commonly used with computers, a UPS offers surge and ripple protection by actually separating your valuable appliances from shore power, and with it's built in battery back-up, a UPS gives you a few precious minutes of power during outages, to power down safely.
I can't afford one of those high-dollar, built-in inverter type power generators, but by using a UPS as protection, any generator, or other less than reliable or suspect power source is fine.
Happy Campin',
ConwayBob
Check out my Scamp restoration video on Youtube, & my Ham Radio Blog. Or take the 50 cent tour...
Bob H is offline   Reply With Quote
Old 07-31-2010, 05:52 PM   #9
Happy Campin',
ConwayBob
Using a UPS is a good practice. However, a UPS only filters the 120 volt power on it's way to your device. The UPS will sound rapid beeps when it can't handle the 120 volt source power and provide properly filtered 120 volt power. At that time disconnect your sensitive devices and try to find a 120 volt source that doesn't make your UPS beep rapidly. When 120 volt power is lost, then the UPS uses an inverter to convert the stored 12 volt power to 120 volt power. Back-UPS LS - Product Information
It also safeguards your equipment from damaging surges and spikes that travel along utility and phone lines. A distinguishing feature of the Back-UPS LS is automatic voltage regulation (AVR). AVR instantly adjusts both low and high voltages to safe levels, so you can work indefinitely during brownouts, saving the battery for power outages when you need it most.
Don't do as one of my bosses did and turn off the beeps and continue to use his computer while running on a construction grade generator.
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Old 10-06-2011, 05:13 PM   #10
Bonnie n Claude's Avatar
Name: Bonnie and Claude
Trailer: N/A
We just bought a refurbished 1974 Boler that has no fuses or breaker box. We are going to Texas in nine days and will be running the fridge on 120V along with a small LED light. We have added a 4 cup coffee maker, small microwave and LCD TV (for rainy days) and a notebook computer. Aside from using only one thing at a time and using a computer-type power bar/surge protector is there anything we can do over the short term to avoid electronic problems? (We are having the wiring rechecked in the spring.)
Bonnie n Claude is offline   Reply With Quote
Old 10-06-2011, 08:03 PM   #11
Bob H's Avatar
Assuming you'll be plugging into a standard 120 volt, 15 amp. service when you camp, you have potentially 1800 watts of electricity to work with. From your list of appliances, count on the refrigerator & microwave to draw the most juice. Any appliance with a heater coil (coffee maker) you can count on 200 watts in use. You can see how it all can quickly add up.
The smartest investment is to get load tester. You can get one built-in with its own power strip/surge protector too.
Old 10-07-2011, 05:29 AM   #12
Trailer: N/A
Thanks, Bob. We also have a 33' trailer that's been stationary in a campground for 13 years. The last time we hauled a trailer it was a Lionel tent trailer in the late 1970s so we have a lot to learn about moving about. Will add the load tester and built-in surge protector to my ToDo list and continue reading the posts on this wonderful site for additional recommendations / warnings.
Old 10-11-2011, 11:58 AM   #13
Jane P.'s Avatar
Since I started this thread, I'll update you all on my eventual decision.
A brief background: About 18 months ago, I was at RV "service garage" and saw a fairly new Bigfoot Camper. So, of course, I asked the service people about it. They told me that the Camper's appliances and electronics were totally "fried" via faulty wiring at a RV Trailer lot. Everything had to be replaced ($$$$!). That got me thinking seriously about surge protection.
But ... surge protectors are expensive. And when dealing with expensive stuff, I tend to research my purchases.
I was interested in saving money, so I liked the idea of this do it yourself approach.
However, because I have an air conditioner, I needed protection for under voltage as well as power surge problems.
I did learn that Built-in Surge Protectors are not a good idea with smaller trailers. These products are designed with the large RVs in mind. They are expensive, overkill, and will inhibit flexibility.
And so, I decided to go with the Surge Guard portable model #34730: http://www.surgeguard.com/comparison1.html
The price of the "make-your-own" components added up to about $100. And the Surge Guard unit has come down in price dramatically since I first started researching surge protectors.
The best deal I could find was on Adventure RV:
Portable Surge Guard 120V 30 Amp - $219.79
I was worried about theft, and so I also bought a 25' extension cord. http://www.adventurerv.net/advanced_...xtension+cords
There was another thread of FGRV that discussed length of RV extension cords. This informed me that 25' will not compromise the power coming to my Trailer.
Surge Guard does have a lock hasp: http://www.adventurerv.net/surge-gua...p-p-13593.html
But, Casita forum members agreed that this hasp was fairly easy to break open and does alert potential thieves that there is an "expensive" surge protector hooked up to the power box. Because of this, I opted for the extension cord which costs just a few dollars more than the lock hasp. This cord allows me to lock the Surge Guard in my cabin, so I now have complete piece of mind when I am off training.
I have been using my Surge Guard everywhere I hook up. It takes a few extra minutes to get out the Surge Guard and extension cord. Last Spring, I camped at a spot where the power box was fairly far away, and the 25' cord worked great.
I am really happy with the decision.
'92 Bigfoot 19' | '07 Chevy Tahoe
Old 10-11-2011, 12:50 PM   #14
Ups
There are different types of UPS systems . One uses the battery only as a backup power source, better ones have the battery across the load at all times (or floating on line) which eliminates voltage dips & spikes . Tripp makes a good UPS but they cost more .
The last ones I bought were for an automated assembly line. They were 1.0 KW and cost about $800.00 ea
electrical
edge protector strips ronsmith100 Care and Feeding of Molded Fiberglass Trailers 5 04-02-2009 01:35 PM
Bumper protector Alistair Camelford Towing, Hitching, Axles and Running Gear 16 12-22-2008 02:17 PM
Surge Guard 30 AMP For Sale -$45.00- Tom T. Classified Archives 0 12-04-2008 02:36 PM
Why not surge brake? EricMeyer Care and Feeding of Molded Fiberglass Trailers 12 04-17-2008 07:11 PM
Power surge 12volt DC Hutt Problem Solving | Owners Helping Owners 7 04-18-2006 05:37 PM
