Mattress replacement for Scamp - Fiberglass RV
Old 02-12-2019, 04:13 PM   #1
M Scott's Avatar
Trailer: 13 ft 2005 Scamp Deluxe; 2002 Subaru V6 Outback
I'm looking for a mattress to replace my hard-as-rock cushions on my Scamp 13.
Anyone have experience with Magic Sleeper Mattress company or another company that makes mattresses to fit a Scamp? I'm unsure of dimensions for a 2005 Scamp as mine is in winter storage elsewhere. Not sure if dimensions are the same as for a Casita.
Your suggestions are most appreciated. Thanks
M Scott is offline   Reply With Quote
Old 02-12-2019, 08:01 PM   #2
I’d get you favorite mattress in a box (foam). Use your existing mattress/cushion set as a pattern and cut with an electric knife. I picked up a cheap electric knife at a thrift store to do this. Don’t want to cut a mattress with the same knife I use for Thanksgiving turkey!
I bought one from Costco, it’s what I use at home too.
Old 02-12-2019, 08:12 PM   #3
I used a 3" foam on top of the OEM cushions and was quite comfortable with that. But the foam was not holding up and the thin cover for it didn't do much. So I got the https://www.magicsleepermattress.com...mattress-shell and used the OEM cushions with my foam inside the shell. I don't know how the comfort would compare to their regular mattress but I mention all this for a few reasons:
Outside of number of loose threads it seems like good quality. The loose threads were almost all inside and so not a problem once the kit is assembled.
Having a full mattress makes it quite difficult to get into the bench storage, water tank, tank drain, etc. Even the shell when filled is not easy to deal with, or to remove for storage in a climate controlled area. It would be easier to leave it in place but leaving it in the camper full time might not be a good idea, esp if you have occasion leaks.
The shell was a good fit (of not maybe a smidgen on the large side) for my 2015 Scampif that helps you on sizing.
Old 02-13-2019, 08:33 AM   #4
Trailer: 1986 Play-Mor II & Scamp 13' Build date April 2019
Connecticut
I am buying a foam IKEA mattress and cutting that for my mattress
CSiko is offline   Reply With Quote
Old 02-13-2019, 08:40 AM   #5
Trailer: '82 Burro 13'
Northern VA
I've seen people get foam from this place with good success.
https://www.foambymail.com/foam-mattresses.html
1982 13' Burro
Burro Renovation
Dan-NS27 is offline   Reply With Quote
Old 02-13-2019, 11:17 AM   #6
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I built a mattress from Foam By Mail (LUX HQ2) for my Escape 17B using 3" material & was pleased with it.
Old 02-13-2019, 01:06 PM   #7
Weavery's Avatar
I bought a full size 7" memory foam mattress from Costco. Reasonable price and I find it very comfortable. Mine is a 19'Scamp.
Weavery is offline   Reply With Quote
Old 02-13-2019, 01:39 PM   #8
John in Michigan's Avatar
For our Trillium 4500 (53x75) picked up foam layers from The Foam Factory actual store location (aka Foam by Mail):
- 5" LUX HQ base layer
- 2.5" LUX HQ egg crate
- 2" HD36 HQ top layer
Very comfortable. Next time I would reduce the thickness of the base layer and possibly the egg crate layer.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 02-13-2019, 02:45 PM   #9
Iowa
Check out Southern Mattress. They make a quality custom mattress, a bit more expensive than a DYI foam but well worth it in our experience.
jjohn is offline   Reply With Quote
Old 02-13-2019, 03:20 PM   #10
I also bought a mattress off ebay, got it home took my measurements , cut open the side of the cover cut to width. made a 17" radius and cut it with electric knife. Worked great, sewed up where i cut the cover. hwas worked great for 4 years so far.
kayaker51 is offline   Reply With Quote
Old 02-18-2019, 09:14 AM   #11
Al and Cindy K's Avatar
Trailer: 19D Front bath Scamp
Second to Jack’s recommendation. We’ve had two - Scamp 16’ and now 19’. Phone # is 800.227.8701, website southernmattressnc.com
Al and Cindy K is offline   Reply With Quote
Old 02-20-2019, 11:15 AM   #12
Trailer: 2015 17' Casita Independence, 2010 Escape 19’
I got a wonderfully rated foam mattress of Amazon. Let it expand, put my camper cushions on top to use to draw/outline the size needed, cut it with my electric knife and voila! Comfy bed! Just as comfy as my home bed.
TappyGee is offline   Reply With Quote
Old 02-21-2019, 07:33 AM   #13
farmerdoug's Avatar
Name: Doug & Linny
Trailer: Escape
I just placed an order on MattressInsider.com. They make custom mattresses, sheets, and lots of other great stuff. You should check them out!
http://mattressinsider.refr.cc/douglasb
I purchased, a mattress encasement and Aire-flow from them and received good service. The link above should get you 5% discount. Good Luck
farmerdoug is offline   Reply With Quote
Old 02-21-2019, 07:57 AM   #14
farmerdoug's Avatar
Name: Doug & Linny
Trailer: Escape
One other note: On our scamp 16 we bought a gel foam topper from Sams Club for the mattress. It seemed to us that the gelfoam retained moisture in high humidity, our coil spring mattress in the Escape is much more comfortable.
Replacement cushion/mattress options dbir Modifications, Alterations and Updates 14 05-28-2015 11:46 PM
For Sale: Custom Scamp Dinette Mattress For Sale Janb313 Parts: Buy | Sell | Trade 15 04-26-2014 07:11 PM
TAKEN - Free Foam / Scamp 5er Loft Mattress peterh Classified Archives 2 07-09-2007 11:18 PM
Scamp Mattress Instead of Cushions Kimberly Geddes Problem Solving | Owners Helping Owners 6 06-14-2006 09:08 AM
Scamp Mattress Instead of Cushions Classified Archives 0 01-01-1970 12:00 AM
