Mold on Fiberglass - Fiberglass RV
Old 07-14-2008, 03:09 AM   #1
Trailer: Triple E Surf Side
It may be late to be asking advice on how to remove mold as i spent a few hours yesterday with light rubbing compound and an electric polisher. The day before I tested hand cleaner (orange with pumice) but feared it was too abrasive. The rubbing compound (i think it is turtle wax brand light duty compound - white colour and less abrasive feeling than red/brown stuff) It is working but very slowly and does not completely remove the mold. When up close I can see the previously very black spots are still there. They are just very pale grey now. Will anything completely remove this stuff without doing damage to the 32 year old surface?
Once I get it as clean as possible what is the recommended treatment to keep the mold from returning? Wax? What brand?
Any advice would be appreciated.
Alan
Alan P. is offline   Reply With Quote
Old 07-14-2008, 05:19 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
This is the best stuff I have found.
http://www.lowes.com/lowes/lkn?action=prod...&lpage=none
Kevin K is online now   Reply With Quote
Old 07-14-2008, 06:58 AM   #3
I use regular Clorox and water mixed 50/50.
Old 07-14-2008, 08:14 AM   #4
Trailer: 1960 28 ft Airstream
Too strong of a concentration, you will give yourself burns and destroy your clothes...usually for mold and bacteria, 1/4 cup of bleach to a gallon of water is all you need. Might need a bit more elbow grease, but at least you won't be breathing noxious fumes.
Pam
Pamela H is offline   Reply With Quote
Old 07-18-2008, 05:43 PM   #5
Thanks for this advice. The job is half done and I'm going to try the bleach tomorrow if it ever stops raining. Then will have a go with the rubbing compound.
Old 07-18-2008, 08:14 PM   #6
Trailer: 1978 Trillium 4500 Deluxe
Hi,
I just restored my 5th Fiberglassrv. I used "Bar Keepers Friend" Make it into a past andworks 2-3 foot sections, leaving it on the entire trailer for 3-4 hours in the sunlight. Wash twice and rinse well. The original gelcoat will come through like you can't believe.
Dave
"The Trillium King"
Dave Baston is offline   Reply With Quote
Old 07-20-2008, 04:27 PM   #7
Trailer: Scamp 13 ft
my scamp was moldy as all heck, when I got it, I towed it to the quicky wash and pressure washed every square inch of the outside, blasted it off pretty good, took about 15 bucks in quarters thou, but it worked really good.
Scott Corsaro is offline   Reply With Quote
Old 07-20-2008, 06:14 PM   #8
Carolyn Patterson's Avatar
Trailer: 16 ft U-Haul VT / 2004 GMC Safari
Hi,
Dave
"The Trillium King"
Dave,
I've used Bar Keepers friend to clean my trailer and it does work very well but I've never kept it on very long. Do you mix it up prior, or just put it on thick? The week before 4th of July I went over every inch of my trailer cleaning it with 2 cans of the stuff from the top of the a/c shroud to the bottom. Took 2 days - then I read somewhere on here that someone used "NuFinish" and while it looked nice for about 4 days, I'm back to square 1 again...no shine.
I'm all for trying anything to get 'some' shine...I realize it's 23 years old...heck I don't shine as well as I used to 23 years ago either...can't expect my trailer to!
Carolyn Patterson is offline   Reply With Quote
Old 07-21-2008, 02:20 PM   #9
Trailer:
I've never cleaned a fiberglass trailer but there are products made for getting the scummy line off boat hulls just above the waterline that work quickly and easily without doing any harm to the gel coat. They contain oxalic acid (dilute for sure) - which is exactly what Barkeeper's Friend has in it.
However it might be a toss-up between the premium price for a brand name product like Barkeeper's Friend in small quantities and the premium price for anything to do with boats in larger quantities!
Andrew
Old 08-15-2008, 07:09 AM   #10
kevin242's Avatar
Trailer: 1976 Beachcomber 15 ft and 1977 Airstream Tradewind 25 ft
"Spray-nine" from Canadian Tire works well. Scrub with a brush and rinse off with water.
kevin242 is offline   Reply With Quote
Old 08-15-2008, 07:28 AM   #11
Administrator
Mary F's Avatar
Probably another coat of the NuFinish would help... when you've cleaned so thoroughly (sort of a chemical peel), the gelcoat seems to absorb the wax. So, "just" put on another coat. (I realize it's a lot of work!)
BTW, I used NuFinish when my Casita was new. In more recent years, I've switched to Meguiar's; but, the brand isn't as important as the doing.
Good luck with it!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 08-15-2008, 09:17 AM   #12
Mary,
You're probably right...it's a lot of work and very disappointing when the shine just isn't what you had hoped it to be. Before putting 'her' in storage, I'm going to give that Poli-glow a try!
As far as mold, I'm still a big fan of the Awesome Spray cleaner I wrote about on another thread. Cleans everything from tree sap to tire marks....someone stated that it also removes wax and I'm sure it does - but rubbing compound does too and spray and wipe is so much easier!!!
Old 08-15-2008, 09:55 AM   #13
Administrator
Mary F's Avatar
Rubbing compound not only removes wax, it also removes gelcoat... and gelcoat isn't very thick to begin with
You might enjoy reading this old (very old) topic on Waxes and polishes. Suz is (or was then) the "queen of shine" and her 1989 Casita was her willing victim. I wish I had the old pictures that she posted of her results!!
ON EDIT: No, wait! I found her old post, which includes a link to where she resubmitted the pics. See Old like New (almost) and Want the Shine.
Just keep on working and don't give up. Don't think you have to do the whole thing at one time or you may never get started. Just go out there and just do a little at a time. That's what I've done, and that is what has worked the best for me.
Old 08-15-2008, 10:40 AM   #14
Administrator
Mary F's Avatar
Ha! I've inspired myself to go out and put some wax on my trailer! See y'all later!
Making a Mold Heath G. Problem Solving | Owners Helping Owners 8 07-20-2010 03:36 PM
Black mold & mildew jrnutpaul Care and Feeding of Molded Fiberglass Trailers 4 09-26-2008 12:27 PM
Removing MOLD Kevin K Problem Solving | Owners Helping Owners 12 10-17-2007 10:43 AM
Fuzzy mold Cheryl C Problem Solving | Owners Helping Owners 2 04-30-2007 05:39 PM
Cleaning mold/mildew Rick and Shannen Care and Feeding of Molded Fiberglass Trailers 7 02-27-2006 09:31 PM
