MORE SPACE UNDER SEAT - Fiberglass RV
Old 11-30-2006, 12:08 PM   #1
Trailer: 2000 Scamp 16 ft Side Dinette Deluxe / 2006 Toyota Tundra
OK so I am new to fiber trailers with alot of questions.
On our way back from picking up the Scamp we were camped next to an airstream and I saw that his electriacal plug in for shore power was like a heavy duty extension cord. OK let me try to explan. On the Scamp I open up a door and pull the cord out ( this takes up alot of space under the seat for storage maybe another water tank?) to plug into shore power. But on the airstream he took the heavy duty cord from inside his trailer and pluged in.
Has anyone done this modification and where can in get the plug for the cord and trailer.
Female on the cord (like all extension cords) and male connector (fixed) on the Scamp?
THANK YOU
D Tharp is offline   Reply With Quote
Old 11-30-2006, 12:18 PM   #2
Alf S.'s Avatar
THANK YOU
Hi: Someone on this sight did a shortening of the power cord to abought 12" with a new connector and then bought a H.D. power cord to store under the front bunk...Makes sense as you instantly gain more cupboard space... Hummmmmm Now who was it?????????Darn memory Alf S. North shore of Lake Erie
Old 11-30-2006, 12:20 PM   #3
Then too, check Byron's posting here to a link at Camping World: Replacing Electrical Cover
The electric cord in my Scamp, when fed back into the trailer rides next to the hotwater heater and on top of the converter....not much room for anything else there anyway. I'm just glad I don't have to go hunt up the cord when it's time to plug in!
Old 11-30-2006, 12:20 PM   #4
Brian B-P's Avatar
Just about any specialty RV supplier should have the cord sets, or ends to convert your existing cord. For example, many stores use Coast as their supplier, and the Coast catalog has cords starting on page 115 and "power inlets" (the male connector and fitting that would install in the trailer wall) on page 117. They even have a conversion kit on page 118 (lower left corner) to do exactly the proposed modification.
I have had the same thought, and the only concern I have heard is that a separate power cord like this might be stolen too easily. I don't know if that's a real concern.
Old 11-30-2006, 12:25 PM   #5
Alf S.'s Avatar
THANK YOU
Hi: ...I think it was Con "Boler Mods" and he posted pics. Since Bolers and Scamps are Cousins it should be easy to follow...Now where did I put my "Thingy"??? Alf S. North shore of Lake Erie
Old 11-30-2006, 12:46 PM   #6
A word of caution here. If your converter is where mine is, you'll need to make sure you do something to allow air flow around the back of the converter. To solve the problem of using that compartment I put a plywood partition in just behind the converter. You can see a picture here.
The main thing don't block the air flow to the converter.
Old 11-30-2006, 02:03 PM   #7
Dan Meyer's Avatar
I've added a power "Inlet" to my Scamp that replaced the heavy power cord. See my website (listed below), and click on "modifications and repairs".
-- Dan Meyer
Old 11-30-2006, 02:29 PM   #8
Trailer: 1978 Volkswagen Westfalia
VW Westfalia has something like that. Our electric connection on the side has a lid. You flip open the lid and put your electric extension cord right on it and run it to the post. The only thing you need to do on the inside and flip the switch to ON and you have electric. We store the cord on a reel under the back seat.
Here is what VW uses - http://www.gowesty.com/ec_view_category.ph...&parent_id=
Jan Adams is offline   Reply With Quote
Old 11-30-2006, 05:42 PM   #9
Lizbeth's Avatar
When I rebuilt mine I used that set up. I think it works great! I'm not fond of shoving the cord into the trailer, I have had them get tangled.
Old 12-01-2006, 03:07 AM   #10
Trailer: Boler 13 ft / 31 ft Holiday Rambler
Maine
...he took the heavy duty cord from inside his trailer and pluged in.
THANK YOU
I Did this to my 13 foot Boler (Lady-bug)when I wanted more space and it worked great.
I just cut the main wire which was about 25 feet long so that it would just clear the exterior wall of the Lady-Bug and installed a regular 30 amp male end which can be purchased almost anywhere.
This is called the pig tail and the Male end sits in the well for the electrical entrance to trailer.
I then took the remainder cord and installed a 30 amp female end plug on the cut end so I now have a extension cord of about 23 feet of the same wire that the camper came with and I now keep this roll of wire in a nice neat circle with all other neat circles of hoses.
Gerry
Old 12-03-2006, 11:41 PM   #11
Pete Dumbleton's Avatar
You can get a female outlet at places like Home Depot -- Be SURE that the outlet you get is for 30Amps@120VAC, not 30@240VAC (the second is commonly used in households for dryers, air conditioners, etc. and is NOT the right thing for RV application.
You can get a 30A/120VAC extension cable at WalMart for less money than at an RV store.
Personally, not having an air conditioner, I replaced my heavy 30A cable with a 15A short outlet and use an extension cable for longer distances (I gave my old cable to an RVing friend and he made a 30A extension cable out of it).
Below is the arrangement Yahoo Scamper Lescher made for his Scamp 13 -- It has a 15A connection cable, plus two GFCI outlets:
Old 12-04-2006, 08:20 AM   #12
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
Pete, did I misread this, or is this outlet being used as a feed for power in? Is the 30 amp connector in the photo a male or female connector? I can't tell very well from the photo, and although I'm sure no one would ever do it, the National Electrical Code specifically prohibits putting male connectors on both ends of a cord because of accidental shock hazard. The "hot" end of an extension cord should always be a female end. This is especially hazardous if the cord accidentally gets pulled out of the trailer by children.
Gerry's idea is probably the most cost-effective, and will work with any RV 30 amp extension cord.
Most of the major RV manufacturers are now supplying marine-type connectors on their coaches where they have a removeable cord application. This is a Marinco 30 amp removeable cord with a screw lock. Obviously the connector on the trailer would have to fit this connector, and is also available.
Roger
Old 12-04-2006, 08:27 AM   #13
Gina D.'s Avatar
West Coast USA
Roger,
The trailer connector pictured above is male.
It is not hot, sitting as is, so it is safe.
It only becomes "Hot" when plugged in and then it is covered by the female end of the cord.
Old 12-04-2006, 10:33 PM   #14
james kent's Avatar
Trailer: Boler 1984
Here's another type. This came with the Boler when we got it. The lid covers a three prong receptacle to which I attach the female end of an extension cord.A word of caution here. Be sure to use a heavy duty cord. I once used a 100 ft lawnmower cord and almost cooked the converter. Boy did it get hot.Too much resistance and too long a cord.
Drawer Space james kent Problem Solving | Owners Helping Owners 2 12-28-2009 07:30 AM
Storage Space? Byron Kinnaman General Chat 4 03-18-2008 05:26 PM
Sightings! From Space! Shawn Englehart General Chat 20 12-14-2007 01:10 PM
New space saving portapotty Ron Wrighton Jokes, Stories & Tall Tales 14 03-01-2007 10:35 AM
» Trailer Showcase
we-2
lloyd
1995 Scamp
C. SMITH
