I went and looked at this
fiberglass trailer today. Haven't seen this style before but I am sure somebody on this forum has one or can tell me what make it is. Outside looks good but needs to be completely stripped out inside and start over. The floor is soft enough you could put your foot thru it if you were not careful. Apparently it sat outside for a number of years with a broken roof vent. I can't imagine the appliances being any good either. Little different configuration with the raised center roof section. it is wider than my
Trillium and the band around the middle is all one piece with the body. By the looks of the seams in the body, the sides, front and rear are all one piece top to bottom and then were joined in the four corners. Still a little pricey I am thinking. He is asking $1500. for it.
