Originally Posted by John Linck
Floyd,
Its the air cells keeping you warm, not the reflective surfaces buried in the wall. When covering your windows the foil really helps. There you have the air space necessary for an effective radiant barrier.
John
PS. Have you tried campers with an inch or two of foam insulation? I have not, but expect them to be more comfortable.
I cut my window covers to fit the glass flush inside the frame.
As I said earlier, the walls have never felt hot or cold to the touch.
Thermopane windows would improve interior comfort too.
Since the trailer was designed for use in conditions which require only single pane windows and the reflextix, ratfur combination far exceeds the comfort capability of those windows, anything more would be excessive, and I believe less reliable over time.
Excellence is enough for me, especially since perfection is unattainable.
I live in Illannoy and have standard construction in my house. I can not tell what the weather is outside without going out or checking the internet. My utility bills are low enough that it would take a lifetime to lower them enough more to pay for a house with the marginal increases in insulation to reach maximum efficiency.
Optimum is not only enough it is the smart choice.
