Need new battery - currently inside - Page 2 - Fiberglass RV
Old 03-04-2016, 04:47 PM   #15
Someone in the other thread mentioned updating the converter. I have the original one installed and it works fine. In the other thread it mentioned that it will kill the battery, or something to that effect. Is that true? If so, what is a good converter that looks like it belongs/fits in the same spot?
JBjunior is offline   Reply With Quote
Old 03-04-2016, 05:27 PM   #16
Originally Posted by JBjunior View Post
As an owner of a tdi and as someone that just helped installed an AGM in a neighbor's tdi, why does that particular AGM need vent tubes?
If you look carefully at the top there are two oval "tubes" that vent the battery.
If the battery were to be installed in a closed space these two ports should be plumbed to the outside in the event of a problem that caused outgassing.
They don't need to be hooked up since there is some ventilation under the hood.
Old 03-04-2016, 06:01 PM   #17
It the battery were to be installed in a closed space these two ports should be plumbed to the outside in the event of a problem that caused outgassing.
Good copy.... I re-read what you wrote. When you said "like goes in my TDI" I thought you were saying you installed the tubes on your TDI. I advised the neighbor that he didn't need the tubes for that same reason, it is vented under the hood.
Old 03-04-2016, 08:12 PM   #18
tractors1's Avatar
Trailer: Escape 21 - Felicity
Originally Posted by apfixer View Post
Has anyone here at the fiberglassrv tried lithium batteries as a replacement for lead acid?
Way to spendy for me. Here's a group 31 replacement:
12V 100AH Lithium Ion Battery | Deep Cycle Lithium Ion Battery | Smart Battery
Charlie Y
Old 03-04-2016, 08:15 PM   #19
You're just being ridiculous... everyone knows you need to shop around :
12V 100Ah,StarkPower 'UltraEnergy" Lithium Ion Battery (LiFePO) Energy Storage Battery
Old 03-04-2016, 08:52 PM   #20
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I use the Lifeline 4D battery 4D AGM Batteries - Lifeline | Fisheries Supply inside our trailer.
Dave & Paula
Old 03-05-2016, 01:22 PM   #21
As I am searching, I am looking for a pure deep cycle battery, it seems these wouldn't be listed as having CCA. I can get a decent price on an Optima Yellow Top, but it seems their Blue Top version (they make a deep cycle and non-deep cycle) is the same thing but has the terminals (threaded stud) I need. I am trying to avoid dual starting/deep cycle batteries, as they tend to be less efficient at the deep cycle part.
Old 03-05-2016, 01:31 PM   #22
Dave & Paula
It seems that these are phenomenal batteries. That model would be crazy overkill for my situation. Some of their other models may work.
Old 03-05-2016, 01:50 PM   #23
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
I am using a Optima Yellow Top D51 (38 amp hours). This works great for my Trillium 4500. The loads are: eight 1156 LED bulbs (each bulb draws .12 amps at 12 VDC), and one LP gas detector (draws .075 amps at 12 VDC).
The battery discharges down to 50% in four or five days based on average 5 of the 1156 LED bulbs being used 5 hours per day, and the LP gas detector being using 24 hours per day.
Beyond four or five days (haven't had to do this), I can partially re-charge the battery using my smart charger powered by a pure sine wave inverter in my tow vehicle. Other charging options would be a solar panel or a generator.
Keep in mind that a battery is ONLY needed if you plan to camp without shore power.
Old 03-05-2016, 01:56 PM   #24
Thank you very much, good information.
Old 03-05-2016, 01:58 PM   #25
For the Optima Yellow Top D51, fully charged = 13.1 volts (resting voltage). 50% charged = 12.2 volts (resting voltage). Resting voltage is measured by waiting 2 hours after charging or discharging the battery. Charging voltage will be higher; discharging voltage will be lower.
Old 03-05-2016, 02:06 PM   #26
Trailer: R-Vision Trail Lite
Best value for deep cycle AGM battery.true deep cycle..AMAZON....UB121000-45978....12 volt group 27 size...100AH. By Universal Power Group...excellent reviews..
One year warranty...one reviewer indicated in use in RV for 4 years plus.
Cost $149.99. Shipping $10. ......BEAT THAT !!!
Uplander is offline   Reply With Quote
Old 03-05-2016, 02:11 PM   #27
Crazy to consider a battery costing $1,000 !
Lithium Ion batteries are a dangerous fire hazard.
Not in my RV !
Old 03-05-2016, 05:00 PM   #28
You might want to check out Odyssey batteries.
I use them for industrial UPS in critical applications and they have a good performance history and long life.
ODYSSEY battery - Design Advantages
Marine Battery Specifications €“ ODYSSEY battery
battery
How much does it matter to own a currently manu. FGRV? Bster13 Care and Feeding of Molded Fiberglass Trailers 41 07-28-2015 12:51 PM
WY | Not currently For Sale 1985 U-Haul CT 13 $4000 magpie Classified Archives 8 10-29-2014 10:51 AM
Trailers currently being made Roger C H Forum Admin, News & Announcements 8 06-25-2013 05:02 AM
Currently still in business? tclyatt Problem Solving | Owners Helping Owners 6 01-23-2008 08:25 PM
Is it ok to mount a battery isolation (cut off) switch inside the trai Curtis F. Problem Solving | Owners Helping Owners 8 07-05-2007 06:46 PM
