Needing help for above the Stove Cabinet - Fiberglass RV
Old 01-15-2010, 10:15 PM   #1
Anne3358's Avatar
Trailer: 2009 17 ft Casita Liberty Deluxe
2009 Casita Liberty 17'
We want to change the cabinet above the stove. The cabinet has 'precious' space that is covered by the fiberglass wall. 'Things' get lost ..... you have to reach in and 'feel around' to see what's hidden in the dead space.
Hubby things we could do something similar to what a Casita Liberty owner from San Diego (sorry forgot the names) did. Me saw their Casita at Lake San Antonio. Cut the opening on the left and right and make a larger door.
OK ................. I'm wondering (always gets me in trouble) why not 'create' some partition and then make two doors. Maybe using fiberglass that was cut out to widen the opening, as a divider/separator. Hubby wants to use a wooden brace, attach fiberglass (cut from the opening), to retain the uniform look of the Casita. Need some feedback especially 'what's wrong with this idea'? (?????)
(Still cringing that we're considering a permanent change to our Little White House)
Bill & Marianne, Silicon Valley, CA
2009 Casita "Little White House" Liberty Deluxe
Next Trip: 14th Annual FiberglassRV Rally @ San Lorenzo Park, King City, CA - May04 - May08, 2017
Anne3358 is offline   Reply With Quote
Old 01-16-2010, 07:39 AM   #2
Trailer: 84 16 ft Scamp
What you could do would be to completely remove the cabinet and put it into storage -- then make a cabinet that pleases you. As long as you constructed it so it mounted using the same holes, you could return to the stock configuration.
Our Scamp is 25 years old, and where it was possible, I also did this in case it would be desirable to go back to stock.
Old 01-18-2010, 12:40 PM   #3
peterh's Avatar
Our Scamp has upper cabinets with these little openings in them, too, but I've noted the 3" wide verticals in between the doors all have a 1x1 wood member backing them. Makes me wonder whether there is a structural component to the design that helps support the floor of the cabinet and prevent sag.
When we decided to replace the ugly fake wood Scamp cabinets over our dinette with something that matched our fiberglass kitchen cabinets I built new cabinets from 1/4" birch plywood and 1x2 & 2x2 lumber.
before
cabinet up
now with a door
How to get that rounded edge look.
To get a good color match I took a scrap of fiberglass to the paint department and had them mix up a glossy paint to match. THe new cabinets aren't exactly the same white and they're not quite as glossy as the actual fiberglass cabinets, but it's close enough that neither of us really notices. They just kinda blend in.
Old 02-12-2010, 04:39 PM   #4
Jacob S.'s Avatar
Trailer: 86 Scamp 16 ft
Post
Nice work, i want to make new doors for mine. I like the pie door idea. I also like your upper cabinet supports, I tried to think of something cool but all i could come up with was chrome. You will see those in chtome or something close in my rig this year. Thanks for the idea.
Jacob S. is offline   Reply With Quote
Old 02-12-2010, 10:39 PM   #5
Anne3358's Avatar
Great job .... love your doors. I love glass doors .... helps when you search for your 'stuff'. <g>
Old 02-13-2010, 12:04 AM   #6
peterh's Avatar
They're not actually glass. It's punched aluminum.
Old 02-13-2010, 11:56 AM   #7
Sharon G's Avatar
Trailer: 2005 Casita Spirit Deluxe
Peter... slightly off topic, but how high above the floor is your new extended loft?
Sharon G is offline   Reply With Quote
Old 02-13-2010, 01:10 PM   #8
peterh's Avatar
The loft extension is at the same level as the original Scamp loft, about 40" above floor level plus the thickness of the mattress. There are two steps that make getting up and down fairly easy. My loft project has its own thread if you want to learn more. You'll find a rough set of plans toward the end of the thread.
cabinet doors Rarebird Modifications, Alterations and Updates 15 12-07-2008 09:05 AM
Overhead cabinet Nina E. Problem Solving | Owners Helping Owners 4 06-02-2007 01:49 PM
Needing Tail Light Lens for 77 Trillium frank_o Classified Archives 2 06-01-2006 05:59 AM
cabinet latches Legacy Posts Problem Solving | Owners Helping Owners 0 06-01-2003 11:37 PM
Needing help for above the Stove Cabinet Anne3358 Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
