New Boler owner - Fiberglass RV
Old 07-11-2013, 02:29 PM   #1
New Boler owner
Hi everyone. I need HELP and lots of it. Just bought a boler, 13'. Not sure on the year or anything yet, long story... Anyways I want opinions on a few things as this is the first time I will be doing this sort of thing. The frame has been completely re-welded and reinforced, and the inside has had a few renovations but it still needs a lot of work. The floor is fiberglass, and the previous owner put vinyl tiles on it. I want to put new tiles but I see a lot of people have put down a plywood subfloor first. Is this necessary or can I put vinyl straight onto the fiberglass (with prep work of course)? As well, any suggestions for a fridge? electric only? or is it worth having a 3 way fridge? I will have electricity hookup about 2/3 of the time I use it. Is it worth the hassle to deal with propane? The stove top has been removed but honestly don't see myself ever using it, maybe just an outdoor bbq/stovetop. I will be removing the furnace as I also never see myself using this, and can use a portable electric heater if I ever needed. I will post pictures as I go along but could really use some advice!! Thanks in advance!
CS86 is offline   Reply With Quote
Old 07-11-2013, 04:11 PM   #2
slavandheather's Avatar
Trailer: 1978 Boler
Howdy! No matter on your floor, you should have a subfloor. Older Bolers had their entire floor glassed in with wood in it, but by later 70s they were casting the floor as past of the entire bottom half of the shell. Especially if it is just the wall-thickness FG, you will want ply subfloor or you'll go thru the floor.
Lots of fridge options out there. More people getting the AC/DC ones now, but you'd want to patch up your vent holes.
Nice to have a cooktop inside for rainy/buggy days.
Catalytic heaters are really nice as a cleaner/quiet alternative to the furnace.
Several of us are actively doing full renovations, so check the first couple pages of the Boler forum. Look up Robert Johans for truly masterful renovations with lots of ideas. His latest completed rig is here.
Don't hesitate to ask questions, lots of amazing help is to be had here!
Cheers,
Slav
slavandheather is offline   Reply With Quote
Old 07-11-2013, 04:24 PM   #3
Thanks slav.
I don't know what my floor is, it looks like fiberglass but must be thicker or reinforced as no one has gone thru it yet, and doesn't feel weak when you walk on it. I'll try to figure out what it is.
I have been looking at all the reno's (including yours) and they are great, but I don't have the time or money to do a complete strip-down reno.
Keep the advice coming!
Old 07-11-2013, 04:40 PM   #4
Trailer: 1978 Boler
Originally Posted by CS86 View Post
Thanks slav.
Have a look underneath. Is the surface smooth FG that looks just like outside of the body? If so, you should have just FG for the floor...and there must be a ply subfloor under the tiles. If the underneath is not smooth, you should be able to see where slats of wood have been glassed in. This floor would be stronger as I believe actual ply is glassed in - but if it is old, it may be rotten and you may need to redo the floor.
Also, if you have the older style, the bottom lip/edge of the body will be just the thickness of the FG body. If it's newer, it will be about 1 inch wide as it curves underneath and then up again on the underside to form the floor. That should give you the indication of the one-piece body and floor.
If your entire rig is anchored to the frame only thru the FG (no ply), you risk having it rip off the frame while in transit...
Hope this helps.
Slav
Old 07-11-2013, 05:27 PM   #5
Trailer: Fiber Stream
Dustin: I moved your post
http://www.fiberglassrv.com/forums/f...ere-59604.html
Old 07-11-2013, 05:50 PM   #6
Thumbs up
Old 07-11-2013, 05:57 PM   #7
Question
Anyone have any idea on the year from looking at my picture? The person I bought it from lost his registration papers (I know I'm going to have trouble registering it in my name, I'll cross that bridge later). There is no # on the cupboard doors, there are no plaques on the interior or exterior. There is a # on the trailer frame, its 9 digits I belive... Does that sound like a vin?
Old 07-11-2013, 07:21 PM   #8
Hope this helps.
Slav
The underneath is rough FG and has horizontal strips that look like wood running every foot or so, and that's where the frame is attached. I tried to take a pic, let me know what you think. Also, does this mean its an early 70's?
Old 07-11-2013, 08:17 PM   #9
Trailer: 1978 Boler
This looks like earlier 70s. What does the edge look like where the body ends as it goes toward the ground? There were variations on these from all the different factories so not sure you will be able to figure out the year exactly.
Old 07-11-2013, 08:23 PM   #10
It's the frenched tail lights that will help determine the age... I THINK those were only done for a couple of years... like 1972 & 1973. Someone much more knowledgable about Bolers than I, will need to confirm.
Old 07-11-2013, 08:24 PM   #11
The body is seperate from the bottom. The body hangs down about 4" past where it meets the bottom. Do you still think I should put a subfloor?
Old 07-11-2013, 08:31 PM   #12
Thanks donna (and slav). I'm ripping things apart right now and seeing what needs to be done. I need to learn how to fix fiberglass where someone cut a chunk out of the closet. I will meet with an RV electrician on monday to discuss rewiring the interior as its a bit of a mess and electircal is not something I want to learn/attempt. The front dinette is in pretty good shape and doesn't need much. The cusions in the front were reupholstered and decent enough that they aren't a priority. I have a long haul ahead of me! Anyone want to travel to BC to help? you can park your trailer here!!!!
Old 07-12-2013, 01:33 PM   #13
Trailer: 1978 Boler
Have a quick look at this drawing below of the cross section of body and floor. The left shows you the older design where the sides are independent of the floor. You see the overhang of the sidewall at the bottom as simply a FG panel. This is going to be the floor that should have wood glassed in.
The right side shows you the newer design where you have the wall FG continue over and then back up to form the floor as a single piece. This will have no wood imbedded in it, just FG. You definitely need a subfloor here.
As for the older design, pull up the tiles you want to replace and see what it looks like. If the wood is rotten underneath from moisture, you have some work to do.
Old 07-12-2013, 01:38 PM   #14
Definitely the one on the left. The paperwork says 1975... ? I think either way I will lay a subfloor. How thick? 3/8 good one side plywood?
boler
New Boler Owner mouse_apples Hi, I am.... 4 03-30-2013 08:39 PM
New Boler Owner Kady Hi, I am.... 2 09-05-2012 05:33 AM
New boler owner Amy W General Chat 2 08-03-2010 05:21 PM
74 Boler Owner NEEDS HELP Jayson Wall General Chat 5 11-10-2009 07:55 PM
74 Boler Owner NEEDS HELP Jayson Wall Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
