New flooring in Patriot - Fiberglass RV
Old 02-11-2013, 12:05 PM   #1
ShirleyA's Avatar
Trailer: Casita patriot
I have a 2003 Patriot. It has the factory carpet on the floor. I would like to put down vinyl or laminate flooring. What is under that carpet?
What have some of you done and what do you recommend?
I travel with dogs, so I thought different flooring might be better for us.
Thank you.
ShirleyA is offline   Reply With Quote
Old 02-11-2013, 07:46 PM   #2
Robin G's Avatar
Trailer: 2007 Casita
Fiberglass, if it's like my 07........ To my understanding all Casitas have fiberglass inside and out! With wood in between..
Old 02-12-2013, 04:56 AM   #3
Raz
Raz's Avatar
Vermont
Hi Shirley and welcome to the forum. We also have carpet on fiberglass. Ours is held in place with snaps and can be removed. This let's us remove it and shake it out or vacuum from time to time. Our last trailer had linoleum which was easily brushed out. I prefer the carpet but I suspect the dog would prefer the cool linoleum on a hot summer night. Take care, Raz
Old 02-12-2013, 09:16 AM   #4
ShirleyA's Avatar
Thanks. Having the carpet was nice at Thanksgiving time when it was cold....Hmmmm maybe I will leave well enough alone for now. And Raz, as for the dogs, I don't think they care. They just love camping.
Old 02-12-2013, 09:32 AM   #5
cpaharley2008's Avatar
Shirley,
I'm sure underneath your carpet is a unfinished wooden underlayment. You can remove the carpet, paint or coat the underlayment if it is rough and put down a laminate floor. I did one in my Egg Camper. A lot easier to keep clean. In the winter, you buy some remnants and put down for warmth. Cost of materials was less than $100.
Old 02-13-2013, 09:25 AM   #6
fusedlight's Avatar
Trailer: 16' 1998 Scamp
That's what we're thinking of doing with our 16' Scamp. Right now I'm pulling off the "cat" fur that someone put in. Think not-quite shag carpeting covering a lot of fiberglass surfaces. The flooring would work well with the oak veneer I'm going to put up.
fusedlight is offline   Reply With Quote
Old 02-13-2013, 12:59 PM   #7
ShirleyA's Avatar
That is a beautiful floor Jim. I would love to get that done. Thanks for the photos.
Old 02-13-2013, 02:32 PM   #8
Trailer: 1980 Dolphin 14 ft formerly
Because of the higher humidity inside the trailer, you might have problems develop with some of the laminates and engineered woods available. Have you considered the Trafficmaster Allure vinyl plank flooring available from Home Depot? We put it in the Dolphin in a light oak color and were very pleased with the results. It is a heavy traffic / commercial type of flooring, that is quite easy to cut and use. Looks luxurious with minimum effort and skill required. Good luck with that!
When you retire, everyday becomes Saturday!
Owen & Rosemary
Formerly - 14'Dolphin, Looking for another!
Owen Lindsay is offline   Reply With Quote
Old 02-13-2013, 06:01 PM   #9
These floors are floating floors in that they are not nailed to the subfloor. There is a space around the perimeter covered by molding that allows the floor to contract and expand with the weather. A tube of matching caulk handles the other side of the install.
Old 03-17-2013, 11:52 AM   #10
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I'm hijacking here because I'm maybe finally going to install the Allure I've had for several years. I have carpet cut to fit the floor space now, no edging, it just sits on the old linoleum. I'm thinking of hauling it out, laying out the Allure on it and cutting/glueing the pieces to fit the same pattern, and sliding it back in. (It's a straight shot in the Campster- that's how I clean the carpet- pull out, clean, shove back.) But as, unlike the carpet, it won't breathe, I'll need to edge with something. And I don't quite follow what you said here. What do you mean "the other side of the install?" Can I just caulk the edges?
Old 03-17-2013, 11:59 AM   #11
I used molding on one side and caulk on the opposite, you can probably use caulk or molding on both, but the molding may need to be nailed and thus that side becomes fixed. I installed each piece separately, they click and lock into one another, trying to install one long piece won't work. Piece by piece would allow for any irregularities in dimensions, which does occur.The molding covers/hides the spacing around the perimeter on one side, that allowing for expansion. The caulking will eliminate any tiny difference on the opposite side. Here are some pictures from a second trailer I did.
Old 03-17-2013, 12:07 PM   #12
I have the glued kind. It would stay together in one piece once put together, I think. The floor is just about 2 ft by 10 ft and almost a rectangle but slightly narrower in the front (dinette) than in the galley.
Old 03-17-2013, 12:41 PM   #13
Are you saying glue to the floor or glued to one another? Not familiar with the latter
Old 03-17-2013, 12:51 PM   #14
The cheap Allure has glue strips for the planks to attach to one another, not to the floor. So I'd use my carpet as template, lay the Allure out on it and put it together, then slide it in (narrower part is up front.) I just pulled out the carpet and the linoleum, which once was textured, is worn smooth, so that shouldn't be an issue. And this doesn't have to last forever- if I like the vinyl floor I can always put in a better one later.
Although that Allure may not be any good anymore after sitting in my garage for several summers in Fresno.. we'll see. I might as well try it as if it doesn't work I'm no worse off.
looking for 13' Casita Patriot Deluxe kayvan Wanted: Molded Fiberglass Travel Trailers 1 03-11-2013 12:37 PM
Looking for a 13' Patriot Deluxe kayvan Hi, I am.... 2 04-05-2012 06:47 AM
13' CASITA PATRIOT - $3750 (seabrook, TX) Camilla Referrals: Molded Fiberglass Trailers 1 06-08-2011 07:29 AM
2002 13' Casita Patriot For Sale Linda&Dale Referrals: Molded Fiberglass Trailers 1 06-08-2010 04:40 AM
cute patriot pix ronsmith100 General Chat 7 05-22-2008 01:12 PM
