New propane lines in a Boler 13 - Fiberglass RV
Old 09-21-2009, 12:24 PM   #1
Raya's Avatar
I've got new propane lines on my list, so I thought I'd ask about it. I have to admit that I haven't really tried to plan it out myself yet, so this may be a bit premature, but Lizbeth posted in different thread that she'd replaced (and re-routed, I think) the propane lines in her Boler 13, so it made me want to ask now. Would be nice to hear about "been there done that" things from anyone who has done it.
Now I know that propane is nothing to "mess with." And I'm not posting this to encourage anyone to forgo having the professionals do it. On the other hand, I have done a couple of propane installations on boats, with good results, and I treat it like hitches, tires, boat rigging, or anything else that can have serious consequences if not done right. That is, I research how to do it, and then if I feel comfortable with it, I proceed.
Even if I ultimately decided not to do the actual flare work on my Boler system, I would like to remove the old lines and then probably reinstall the new ones. I know how to test the lines for leaks. I also know that my carefully working on them would most likely result in a system much safer than the existing one that many people are using (i.e. the 35 year old one that lurks beneath the camper).
So... with that said, I welcome input from anyone who has done the propane lines on their Boler 13 (or other eggs).
1) How did you remove the old lines? For example, did you take them apart first, or remove them in a big "tree?"
2) Do you have to flare the new ones after you run the bare lines up through the holes in the floor? Or are they big enough to accommodate a pre-flared system?
3) Any other installation caveats I'm not thinking of?
4) What did you improve from the original installation, if anything? (I know some systems are black pipe. I plan to use suitable flexible copper unless a better idea comes up. I'm also going to install a double regulator when I do this.)
5) I've heard suggestion of using rubber-encased copper tubing that's meant for burying underground. On the face of it, this sounds like a good idea, but... any experience?
Thanks very much for any input
Raya
Old 09-21-2009, 04:59 PM   #2
Greg A's Avatar
I replaced mine with Flexible Gas Line.
Been a couple of years with no issues or leaks, and very easy to work with, route, and you don't need an expensive flare tool.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 09-21-2009, 07:08 PM   #3
Lizbeth's Avatar
We removed fittings and then cut it where needed and yanked it out.
The holes in our trailer were pretty good sized.
Now is the chance to reroute. New regulator, regulator location?
Our original lines were not a clean installation. Two lines came up through the center of the cabinet space under the sink. (huh?) We went to one line at the side if the cabinet and then teed off of it to run to the heater, stove and fridge.
Nope.
Old 09-21-2009, 07:14 PM   #4
james kent's Avatar
Trailer: Boler 1984
Hi Raya
The propane lines in our '84 are non-flexable copper. There is one line from the tank to a 't' under the floor. From there two lines run into the trailer. One to the stove and one to the fridge. While I have the fridge out at present [repairs], I noticed that the hole through the floor is only marginally bigger than the pipe and so the ends had to have been flared AFTERWARDS. The copper is stiff enough, and short enough, that there are no fasteners anywhere so that it doesn't flex against anything, Just one hole through the body and two holes through the floor behind the fridge.
For protection from the tank to the 'T', The line runs through a rubber tube. Why could you not run the line through a short length of black Garden Hose as a protector, or a short piece of the foam covering used to prevent condensation from dripping from cold water pipes?
PS
It's raining out or I would gone outside and take a couple of picture.
Old 09-21-2009, 08:17 PM   #5
Raya's Avatar
I want to pop in to thank those of you who have responded so far.
Although, that said, I don't want to discourage anyone else from "piping" in.
James, the reason I wasn't thinking of using regular pipe and encasing it in something is that I hate to trap potential corrosives against the tubing (salt, etc.). I wouldn't be against short bits of chafe guard if necessary.
The reason I started out thinking of flexible copper tubing in my mind is because that's what's often recommended in boats (a heavier wall than the garden variety tubing), and boats are what I'm familiar with. (Then there is a bit of flexible hose leading to the stove, because that's gimballed and swings back and forth quite a bit.)
The boating guidelines are probably overly strict for RV's, because propane is heavier than air and sinks. In a camper, this would generally mean that a leak (especially if it were beneath the camper) would sink down and away, but in a boat it collects in the bilge and then just waits to explode. However, I've lived with propane on boats for years, as it makes for a really good stove/oven fuel. You just have to be very careful with installation and use.
However, I'm glad to hear ideas and experiences from those who've got experience re-doing their eggs, before I decide on any one way, because I've never worked on the propane lines in one.
So thanks, and keep them coming
Raya
Old 09-22-2009, 07:59 AM   #6
james kent's Avatar
Trailer: Boler 1984
S'me Again
We just had new lines installed, for an oil stove, at a family cottage. The line from the tank to the stove carburator has a plastic coating so it is available out there.
BTW the covering on the pipe on the trailer only extends from the regulator to about 2 inches inside the body shell. That's only about two feet.
Old 09-23-2009, 06:27 AM   #7
Two things come to mind.
1) You can not flare hard copper, it has to be soft copper.
2) I would use a propane hose with flare ends on it to go from the tank to the trailer. This is because of flex and corrosion.
Bill K
Old 09-23-2009, 07:09 AM   #8
Trailer: Escape 19
Ohio
Arrow
I installed a cataytic heater last winter using soft copper tubing (Lowes). After looking at various routings, I tee'd into the existing propane line outside the trailer wall, right at the bulkhead fitting. Except for inserting a shutoff in the line in front of the trailer wall, I managed to do this in one run of tubing, running across the front of the wall (behind the battery box), down under the curb side of the frame, up into the closet, and finally to a fitting that goes through the closet wall to the heater. I used a flexible spring tubing bender (Lowes) to help form the tubing as I went. I had planned on using a lever-type bender, but that proved too difficult. The spring benders can be moved along the tubing as needed. I left the tubing long on both ends, then cut and flared after all the bending was completed. This allowed me to snake the tubing around to get it up through the floor, across the closet, etc. I installed a shutoff valve in the vicinity of the battery box, leaving this last run of straight tubing from the valve to the original bulkhead fitting until last, so I could fiddle with this length as needed.
For flaring, I used an old fashioned tool that clamps around the tubing, with a conical piece that screws down into the end of the tubing. I guess that's still the common tool for such jobs. Anyway, I suggest practicing on some scrap to learn where to clamp the tubing to get the right amount of flare. And most important......don't forget to slide the nut on the tube BEFORE flaring. I supposed everyone has to do this once, but it just doesn't make one's day to take the flaring tool off the tube and the see the nut laying nearby.
I probably could have saved myself a lot of effort by using a flexible line, but wanted to try the copper, thinking it will look tidier and be closer to Scamp's original tubing installation. Of course, they can install theirs while building the trailer and have already worked out all the lengths and bends. Still, it was a fun project, and a little challenge is good from time to time.
Good luck!
Parker
Parker Buckley is offline   Reply With Quote
Old 09-29-2009, 08:07 AM   #9
Trailer: Boler 13 ft
Make sure to use a 'propane nut' or' forged nut', [sold by most rv suppliers in canada, its been 'code' in canada for many yrs, not sure about usa] its a heavier than the standard 3/8 flare nut sold in hardware stores for 3/8 copper tubing. All the older rv's used the standard lite wt flare nut. The standard flare nuts tend to split or crack on the side if overtightened. Install a pressure gauge on the tank, so each time u open the valve, u then shut it off for several seconds to see if the pressure 'holds', very cheap life insurance!!!! salud brent
Brent R. is offline   Reply With Quote
Old 09-29-2009, 08:20 AM   #10
floyd's Avatar
When you buy soft copper tubing , be sure you get the tubing rated for gas, there is a thinner and cheaper tubing available which should not be used.
Old 09-29-2009, 09:12 AM   #11
Raya's Avatar
Thanks for the additional input
Raya
Old 09-29-2009, 09:40 AM   #12
Trailer: Boler
I'm going to add a strong note of caution here.I grew up in southern Ontario with a Dad who worked for the local gas company.In 1974,while working on a gas installation next to a 3 story warehouse in Collingwood,Ont,my Dad smelled gas.He chased his crew away from the building,but,in the ensuing explosion,he a 2 of his crew were injured,with my Dad losing hearing in one ear for the rest of his days.
Moral of the story:are you DAMN sure that you want to do this gas line work?What would your insurance company think?What would the insurers of the adjacent trailers think?I appreciate cost savings and DIY,I do.I'm reno'ing as well,painting,basic plumbing.But,When it comes to things that can go bang in the night,I'm letting a pro do it.
My 2 cents worth...
Rick Harmer is offline   Reply With Quote
Old 09-29-2009, 10:33 AM   #13
Raya's Avatar
Rick,
I appreciate your concern, and I share your caution.
That said, I am a very careful, conscientious person. Many of the other systems I work with have the same potential to cause death or injury, so I have to be very careful. I do believe that it is possible to do this sort of work one's self if one is cognizant of the dangers and if one has the right bent.
One plus is that there is no propane in the system while doing the work (this may not be the case on large construction sites?). In other words, someone like me can do all the work, slowly and carefully, and then test the system before using it.
(Note that my original questions were not really about how to do the basic work - i.e. flares and such - but were more about how people routed their lines, and the procedure they used for getting them in place. In other words, the logistics more than the techniques of working with the tools and materials.)
Now I have nothing against professionals doing work on my things, but I have had difficulty finding *true* professionals. As an example, I took my car to a professional shop (new to me but well recommended), and they really messed it up. I ended up having to fix it, and the job was harder than if I had just done it in the first place.
Again, I have no problem with hiring a true professional.
On the other hand, no one cares more about my life than me, and I'm not working to an estimate. So I have all the time I need to do the job carefully and methodically. As a bonus, I might see a better way to route the lines, something else I need to work on, and/or I will get a chance to check over other systems under the trailer.
I think either avenue can be appropriate; it just depends on the comfort level of the person who owns the trailer, how they feel about working with tools and handling the responsibility, and how tidy and careful they are.
Would I want to camp next to someone who had done their own propane repair sloppily? No, of course not. But I don't think that's a good reason for one to not do their own work if they do it properly.
Some professionals do great work; some are sloppy. Some people are good drivers; some aren't. Some wear proper safety equipment when they work; some don't. I wish I didn't have to share the world with the latter, but I also don't feel that they should keep everyone from doing their own work.
I certainly hope insurance companies are looking for the trailer to be safe, not for who has done the work. After all, if the latter were the case, who would be allowed to change their own flat tire and tighten their own lug nuts? (Not to be "smart" but seriously, I do feel that way.) I bet there are plenty of people going around with unsafe towing rigs, that have nothing to do with the fact that they do (or don't do) the work themselves. In fact, I would venture a guess that people who do work on their own rigs, and are aware of their condition, might even have rigs that are more safe, overall, than people who don't.
I'm sorry to ramble on, but I felt that I had addressed this in my original post, and it makes me feel a bit frustrated to hear swearing and "threatening" things about what insurers might think.
Again, please don't take this as encouragement to do your own work on a potentially dangerous system you are not comfortable with. On the other hand, know that there is no "magic" involved, and with knowledge, care, and proper procedure, people can do things.
Raya
Old 09-29-2009, 11:03 AM   #14
Trailer: Boler
Sorry.I get carried away when anything about gas is discussed.I have no doubt that many can do it safely and without incident;I'm opting for the pro,one who was recommended by a friend in the boat accessories business.Same with the complete update on the electrical-don't have the skills,but do have an electrician who lives nearby.A short while ago,my DW designed and had built our little slice of life in the woods not too far from Vancouver,BC.Met many good tradespeople(house is still standing,never had to call them back for further work)and will use them as needed.We've been very lucky in that any work we've had done in the last decade or so,on vehicle or houses,no problems at all.
But...
As you say,we do change our own tires,so what do I know..?
Old 09-29-2009, 11:16 AM   #15
Raya's Avatar
Thanks for the reply, Rick. I'm glad we're both happy with the discussion at this point.
I can understand why you would be a bit sensitive to the propane issue, considering what happened to your dad.
The other day I passed someone driving a mini-van that was towing a (non-egg) trailer on an in-town stretch of Interstate, and the driver had a book propped up on the steering wheel, reading (not a map... a chapter book!).
Honestly, what are some people thinking?!
Raya
Old 10-03-2009, 08:38 AM   #16
Trailer: Boler
If you want to make sure everthing is good do a pressure test on it. The best way to test is to have the lines capped where they would hook up to the stove, fridge, etc... and then add a gauge at the other end. Put a valve on like a tire valve and fill the tubing/piping up with air to at least 15psi. According to code it should stay at 15psi for at least 15 minutes. If pressure drops you know you have a leak but at least your not messing with the propane.
Eric S 2 is offline   Reply With Quote
Old 10-03-2009, 12:17 PM   #17
floyd's Avatar
Rick,
Raya
Old 10-06-2009, 11:46 AM   #18
Scott S.'s Avatar
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I consider myself to be fairly capable but I drew the line at the gas. I had a pro do it because there are laws about how many fittings are allowed inside the camper and other things that just plain scared me off. I paid $200 and had them all replaced. my other concern was that if I burned the egg to the ground due to my own work, would my insurance company cover me?
Scott S. is offline   Reply With Quote
Old 10-06-2009, 05:10 PM   #19
Raya's Avatar
If you hitch up your trailer improperly, and it flies off and hurts someone, will your insurance cover you?
Scott, I'm glad that you did not tackle a job on your camper that you were not comfortable with. That's how everyone should handle projects, whether they be propane, electrical, changing a tire, or whatever. But to pose the question about "would insurance cover me?" and then leave it hanging in mid air like that seems to make it sound as though propane would be a special case, and that people had better not even think of trying it themselves. It uses fear to add an element of doubt and then leaves it at that.
I do understand that one must research how to do it properly, and must be comfortable doing it. That holds true for propane, electricity, hitching up, driving, pumping sewage, using power tools, and many other things on our trailers. People have all different levels of comfort with these things, and either choose to do them or to have them done by others.
If someone wires a circuit wrong and the trailer burns down, is it covered? How about if someone doesn't tighten the hitch coupler properly? Or turns in front of oncoming traffic (their own fault)? I don't know but I guess if I wanted to find out I would call my insurance company and ask.
I realize this is a bit of a rant, but I get tired of people acting as if propane is somehow so much more dangerous than driving down the freeway at 70mph, or handling 120 volts of electricity, or running a gasoline appliance. They can all be very dangerous if one is not careful.
If you're not comfortable with it, that is totally understandable. But please let's keep to the facts here. I started this thread to ask about the logistics of getting the old propane lines out of the trailer (with no propane in them) and the new ones in (still with no propane in them). The next step would be to pressure test them (with no propane in them). Only after that would propane be introduced, and I have to say that at that point such a system would likely be much more "tested" than most of the older trailers out there who are using theirs as-is.
Raya
Old 10-07-2009, 02:02 PM   #20
Greg A's Avatar
Reminds me of a discussion we had with our builder when we bought our first house in Phoenix. I had never heard this before, and not saying it is necessarily related but an interesting story just the same.
We were looking at a builder spec house that had fallen through on the original buyer and we couldn't make our decision for a few weeks. There was another elderly couple that was hot on it, so we were afraid we wouldn't get it. Turns out that the other couple got frightened off because it had a gas stove. The builder rep told us he had found that Seniors in general get really nervous about gas appliances and almost never went with them over electric. Since AZ has a lot of Seniors you don't see a ton of gas appliances in the resale homes.
I personally have worked with gas connections all my life and feel very comfortable hooking up gas lines. After watching many pros over the years, I'm more comfortable with my connections and always go behind them when they do the work and soap test everything anyway.
Like the Seniors in AZ and their gas appliance nervousness you certainly need to operate within your comfort zone and shouldn't do any repairs or have items in the camper that are outside that zone. Since things sometimes come loose in transit, propane repairs may have to be done in the field where pros aren't available, so one might want to consider an all electric option for their camper if they are nervous working with propane lines and connections. I know there have been several discussions on this board over the years about folks removing the propane from their camper or ordering all electric for very similar reasons. I almost totally removed the propane from my Scamp until I discovered how well the fridge works on propane for "boondocking." I'm now in the process of removing the propane stove since we never use it but will keep the fridge for now.
As for Raya's project I'm not familiar with the Boler or where they run the lines, but the Scamp 13 was a breeze to remove the old lines and replace. I'd estimate that when I replaced mine it was about a 45 minute to 1 hour job.
Owner:
boler, propane
Where to Buy? New propane lines, fittings, etc? Kurt in BC Problem Solving | Owners Helping Owners 9 06-12-2008 05:27 PM
Capping propane lines Peggy Problem Solving | Owners Helping Owners 8 07-12-2007 05:54 AM
Propane lines Jim Hovind Problem Solving | Owners Helping Owners 3 01-09-2006 08:30 AM
Propane Tanks for a Boler 13' Legacy Posts Problem Solving | Owners Helping Owners 11 07-18-2003 09:13 PM
Propane lines General Chat 0 01-01-1970 12:00 AM
