New Tires - Fiberglass RV
Old 06-19-2007, 08:54 PM   #1
Trailer: 1998 13 ft Scamp
Just thought I would pass along some useful info. I recently took the cover off the spare tire on my Scamp 13 and found a large bulge under the tread, from a separated ply or belt. I shopped around for a replacement ST175/80R13, and found prices ranging from 70 to 110. I called Costco and got it for $59, including mounting and balance. It's a Towmaster, which I have been told is made by Michelin. They told me that they just recently started carrying trailer tires. I know who I will call first next time!
Anybody out there know what is different about trailer tires?
Sonny is offline   Reply With Quote
Old 06-19-2007, 10:11 PM   #2
Chris B's Avatar
Trailer: 2003 Casita Liberty Deluxe
There's been alot of discussion about tires on one of the Casita websites. It seems that Goodyear Marathon tires are failing, in some cases. I know that the tread on mine has worn differently than car tires. This was posted by one of the forum members. It's an easy read with good information.
http://www.discounttire.com/dtcs/infoTrail...ghQK30FM0Hj9ZzN
Chris B is offline   Reply With Quote
Old 06-20-2007, 11:14 AM   #3
Brian B-P's Avatar
..It's a Towmaster, which I have been told is made by Michelin...
Towmaster is a brand from Greenball. Their Company History page explains their sources, but basically they are an importer of tires from cheap sources. I would be surprised if any Michelin plant was the cheapest source for these guys, but I suppose it could be true. The tire coding experts among us may be able to explain how to read the cryptic codes moulded into the tire sidewall, which might list who really makes the tires.
Old 06-20-2007, 11:22 AM   #4
Brian B-P's Avatar
There has been a lot of discussion of this here in FiberglassRV, too. The Search tool can find the topics, but you can't search on very short keyword, such as the two-letter "ST", and "tire" might be a little to general... so I would try "Marathon", since just about every tire topic eventually mentions the Goodyear Marathon.
Old 06-20-2007, 02:20 PM   #5
Pete Dumbleton's Avatar
You might want to go back to Costco and ascertain that they know that trailer wheels require a special adapter on the balancing equipment because they are LUG-centric and the hub hole is just stamped and may not be the actual balance center of the wheel. Most US automotive wheel are HUB-centric.
You can generally tell that a wheel is lug-centric if the center hole is not in actual contact with the hub or hub-ring.
Old 06-20-2007, 02:54 PM   #6
Chester Taje's Avatar
Now this is real interesting.
Old 06-20-2007, 03:19 PM   #7
Trailer: Casita 2000 17ft. Liberty
I recently had a huge blowout on my 13 footer. Bad damage on the fiberglass and the rim was ripped off the hub lost in the ditch.
I'm not sure why what failed-no way to tell. Loose lug nuts or tire failure?
What I know for sure is the tire was marked "P" for passenger!
Never knew that. I changed to 8ply Light Truck tires. Could not find any marked LT but the salesman said these are the best for heavy sidewall wear.
jim munson is offline   Reply With Quote
Old 06-20-2007, 03:34 PM   #8
Chester, do a search of the group on "centric" and you will find some interesting info. Seems that some of the larger Toyota truck wheels, esp the after-market 4WD ones, are also lug-centric and the Toyota dealers weren't balancing them properly (taking mildly out of balance wheels and making them worse...).
Actually, according to some recent info posted to Yahoo Scampers, ST tires are indeed better for trailer use (more UV protection and interior belts and steel) than LT, which in turn are better than P-radials. Some folks have good luck with Ps, and probably less rolling resistance becasue of the less stiff sidewalls, but most RV groups recommend against them, as does my personal experience with them on my Jayco 16', because of their tendency to allow sway.
Old 06-20-2007, 03:52 PM   #9
Brian B-P's Avatar
I changed to 8ply Light Truck tires. Could not find any marked LT...
Light truck tires are really hard to find in the size of a stock small travel trailer tire. They might be a commercial tire. What size did you get, Jim?
Also, the "ply" numbers don't really mean construction plies anymore. They're probably load range D tires, with a 65 psi maximum inflation pressure; what do they say they are?
Old 06-22-2007, 04:58 AM   #10
Alf S.'s Avatar
Hi: Getting ready to "Tug To Emily" for the "Retro Rally" I buffed my Baby Moons only to discover sidewall cracks in my... Prev. Own's. description "New Tires Now I thought was a good time to go Radial...3 new Tires The only radials my trusted R.V.Dealer can supply are Goodyear Marathons and I feel insecure towing with cracked Carlisle's??? Alf S. North shore of Lake Erie p.s. 2 New bias Carlisles @ $95.00ea or 3 radial Marathons @ $78.00ea.
Old 06-22-2007, 05:42 AM   #11
Joe Z's Avatar
New River AZ
Hi Alf...
While there are many good tires out there I have been reading about "Kuhmo Radial 857" tires a real lot lately and i have not heard one negative thought on these tires... do a search in the forums on this tire...........
I have the "goodyear marathons" at the present and will be switching over to the "Kuhmo's" as they have a heavier ply and a higher speed rating and if you purchase these be sure to get the metal valve stems for the increased tire pressure that they use.... also be sure that your rims can carry the extra load rating tires.
Joe
Link to "Kuhmo radial 857"
http://www.tirerack.com/tires/Sizes.jsp?ma...odel=Radial+857
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 06-22-2007, 06:51 AM   #12
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
(Propeller Beanie turns on...)
A few minutes with the Tire & Rim Assn handbook yields the following capacities:
P205/75R15SL (standard load): 1452 pounds at 35 psi (when used on a trailer)
P205/75R15 XL (extra load): 1553 pounds at 38 psi (when used on a trailer)
LT205/75R15C: 1655 pounds at 50 psi
ST205/75R15C: 1820 pounds at 50 psi
I chose that size because it's common across all the tables and they are all dimensionally basically equal.
Note that the P tires carry about 41 pounds of load for every 1 psi of inflation. The LT (33) and ST (36) carry less load per psi but more load ultimately because of the higher allowed inflation. (A side benefit is that properly loaded and inflated ST and LT tires deflect less and put their sidewalls in less danger from road hazards.)
Air carries the load. The tire carcass and steel belts basically holds the air inside. The tire companies have formulas (basically throw backs to the old steam boiler formulas) that determine how much material to put in the belts and plies based on air pressure and maximum load. Then, they will add to the belt strength as required to accommodate the expected usage of the tire.
Of the four tire sizes shown, the ST tire would start from the strongest position. The LT tire would calculate out to have slightly less material, but then they would add belt strength to account for the rougher roads a light truck is likely to see.
Also,
Old 06-22-2007, 10:43 AM   #13
Brian B-P's Avatar
...2 New bias Carlisles @ $95.00ea or 3 radial Marathons @ $78.00ea.
The price difference is a little surprising to me, given that the Goodyear brand is not commonly a cut-price offering and there's nothing special about Carlisle. Are they really comparable; that is, are both tires the same load rating?
Old 06-22-2007, 10:51 AM   #14
Brian B-P's Avatar
...I have the "goodyear marathons" at the present and will be switching over to the "Kuhmo's" as they have a heavier ply and a higher speed rating...
The Kuhmos are a commercial tires, not ST (one of the errors in this Tire Rack page); in my view there's absolutely nothing wrong with that, and it may help explain the higher speed rating.
The "heavier ply" presumably means a higher ply rating - that is just another way of saying that the Kuhmos are are load range D tires; 14" Marathons are only available up to load range C. If the Load Range C tires have appropriate capacity, is there really a point to going to heavier "D" tires? It's not a quality rating...
The higher speed rating does seem to me like a factor worthy of consideration.
tires
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 19 12-30-2014 01:14 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 10:33 PM
ST Tires Pete Dumbleton Towing, Hitching, Axles and Running Gear 7 04-13-2008 09:37 PM
Need new tires Don Davis Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
