New to campers 19' scamp "fifth wheel" - Fiberglass RV
Old 10-21-2012, 03:52 PM   #1
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Disclaimer: I've posted this on another forum, so I just copied/pasted/edited if you see something odd...
I just bought a 1984 19' scamp fifth wheel camper.
Here's some pictures (I used the panoramic feature on my iphone, if something seems curved, that's why. It's hard to keep the camera steady in a rocking camper.):
I towed it home 450 miles @ 80 mph, no sweat. The previous owner made a receiver adapter to use on it. The 28 year old trailer brakes work like you wouldn't believe, shocked me.
The 28 year old torsion axle is shot, it rides way low. No biggie, I need to raise it more to fit over the pickup bed, anyway. New axle and suspension will be coming. I already have two 15" spares for the car trailer, so I'm going to see if I can get 15" tires under it when I do this. One way or the other, those ugly wheels have got to go.
The goofy proprietary hitch is getting replaced with either a gooseneck or fifth wheel coupler. I have to look at the frame more to see which one. I have a gooseneck hitch in the truck, so that's the easy route, but I think the trailer frame might warrant putting a fifth wheel kinpin on it (not sure it will take the added stress of a gooseneck), and getting the b&w companion fifth wheel for my hitch. No biggie, either way.
The outside needs cleaned up. That's the first step. Thanks to this forum, I'm going to clean it with scotchbrite and barkeepers friend, then TSP. After that....zep floor polish. I thought it was nuts. 40 page thread, hundreds of people doing it, almost no problems, though. Who can argue? I already tried to polish it...didn't work well.
Carpet needs to go. Who wants carpet in a camper? Deciding between laminate or vinyl, mostly hinges on how clean I can get the floor (carpet is glued well).
Paint all the fake wood crap inside the trailer (not sure on color, we'll see what I get for floor first).
Replace rear window with a hinged egress window so I can throw my kayaks inside the trailer.
Everything works, with the possible exception of the furnace. It has never been used that they can remember. So, it's "new" but 28 years old.
Oh, then there's this unintentional mod...You know that rare '57 chevy pickup rear bumper you keep, just in case you ever get another project one? Yeah...well, I moved it and set it on the spare tire of the camper to get at some things in the garage...see what I see?
This forum has already been great for ideas. One thing I didn't find, has anybody successfully primed/painted over the fake wood vinyl on the cabinet doors? I cant imagine ever getting it off and cleaning the glue off, it would be easier to make new ones at that point, I think.
Old 10-21-2012, 05:57 PM   #2
cpaharley2008's Avatar
Welcome to the forum Jared,
Now sit down and listen for your first bit of advice.
Why would you tow @80 mph a 28 year old trailer you have never towed before?
You have no idea what may have broken or failed on this used unit. We want you to hang around here for awhile so take it easy. Cool double rear bumper set up, maybe turn the bumper over for the curve to encompass the spare.
Old 10-21-2012, 06:25 PM   #3
John & BJ S.'s Avatar
Jared -
Welcome to the forum. Take the time to wander through the photos on the Scampers_Modifications group (a sibling to this group). There have been a couple axle mods to fit 15" wheels & tires. There has also been at least one adaptation to a fifth wheel pin.
Fixing up the cabinet doors is easy if you have access to a table saw to cut new doors - you can finish them with clear varnish or paint them - in either case, I'd advocate for starting fresh on the doors.
John & BJ
Mesa, AZ
"We're not lost. We're just finding our way."
www.justfinding.blogspot.com
John & BJ S. is offline   Reply With Quote
Old 10-21-2012, 06:32 PM   #4
Jared J's Avatar
Kansas
I was under it and checked the frame/tires/bearings/ body attach points/etc., before I ever hooked up to it. I'm no stranger to towing, from semis, to goosenecks, to car trailers and this little guy. The only thing I didn't like was not having spare parts for it, but I had no problems. I usually travel with spare bearings/dust seals/hub/wiring/lights/etc. It helps to keep Murphy away.
I wasn't going to do a double setup, just replace the existing bumper with the chevy one. That curve will fit around the spare tire great. No good reason, just for looks (I have problems leaving things alone). I'll also probably be welding a rear receiver on the bumper for my bike rack. It looks like I'll need to add a second crossmember to tie the receiver tube into, no biggie. It would probably work fine without, but with all the bouncing and stuff, a second crossmember is a sure thing to keep it from possibly twisting and cracking the frame.
I got a little cleaning done with the barkeeper's friend. It's much better, but needs much more before it's ready for the floor polish. I'm thinking it's going to take my buffer now. I'm hoping that and the barkeepers friend will do it, if not, I have some very fine polishin compound that I tried and will do the job of cleaning it well. I'm hoping to avoid that, not knowing how thick this gelcoat is.
I also decided the decals have to go. I'm going to hate myself for that part of the way through removing them, but if I have this much time in cleaning it already, I can't do it half baked. I'm not sure if I'll go back with factory decals or something else...to be continued.
Top half done
All done
Top half of right side done from the door back:
Right side all done:
Left side before starting:
I need to remove the propane tanks and spare to get behind them still. It's getting too dark, though. Time to eat and then start ripping out carpet.
Old 10-21-2012, 06:34 PM   #5
Steve Hammel's Avatar
Trailer: Trillium 4500
Is your spare 4 bolt? Are all your wheels 4 bolt?
That bumper would make a nice replacement and the spare would fit perfectly.
Old 10-21-2012, 06:40 PM   #6
Jared J's Avatar
Kansas
Originally Posted by John & BJ S. View Post
Jared -
Thanks, will definitely look at that. I like it when people work my problems out for me.
I kind of figured that on the doors. I saw where somebody on here went and did all three top kitchen ones as one big door and hinged it up. I think I might go that route myself. Looks clean, easy, and out of the way.
Yes, and yes. For now, at least. When I replace the axle I'll be going to 5 lug 15" if I can fit them. I wasn't too impressed with how the 13" tires would flatten the sidewall on a bump. I always liked maxxis trailer tires and was surprised by this. today I noticed they're p's, not st's. Doh! That explains that.
Old 10-21-2012, 07:08 PM   #7
Jared J's Avatar
Kansas
Ok, I'm an idiot. Where do I found the scamper modifications group?
Old 10-21-2012, 07:19 PM   #8
Nope - it was my fault. I was reading the Scampers list just before I started catching up on Fiberglassrv and as a result led you astray. Scampers_Modifications is a Yahoo group - Scampers_Modifications : Scampers_Modifications
John & BJ
Mesa, AZ
Old 10-21-2012, 07:36 PM   #9
Exit Hatch
Jared
Looks like you have the plastic frame vents. Order the larger metal frame escape hatches, you will be better off in the long run. When you cut the larger hole you will be able to cut out all the old rivet holes. Just like starting from scratch.
Eddie
Old 10-21-2012, 10:35 PM   #10
Jared J's Avatar
Kansas
Well, I got the carpet ripped out. If I glue vinyl down, it will need sanding. If I do laminate or vinyl plank, it's good to go as is. Unfortunately, there's a little bit of rot by the rear window. Oh well, not a huge deal to fix, it's a pretty small area.
I'm also going to replace all the water lines, as long as I'm right there. Has anybody used pex for this? I might do the wiring, too.
I got the bunk setup, just to see how it works. It seems like the poles are too long, they tilt the top bunk towards the hinge. Am I missing something, or do they just need to be cut down
Also, what does the loop on the poles do?
Old 10-21-2012, 10:50 PM   #11
New factory plumbing is PEX
John & BJ
Mesa, AZ
Old 10-21-2012, 11:12 PM   #12
Trailer: 1976 Trillium 1300
Welcome -
Bunk bed poles - flip them the other way up and the loop is hooked on to a protruding nail on the underneath of the top bunk. That should make the bunk more level.
kootenaigirl is offline   Reply With Quote
Old 10-21-2012, 11:19 PM   #13
Jared J's Avatar
Kansas
Thanks, seems a better choice.
Originally Posted by kootenaigirl View Post
Welcome -
Oh good grief. Yeah, I just set the open end over the screw. I thought it was weird they would do it like that and angle the poles in... I get it, the poles hold the cushion in place.
Thanks!
One more thing...any tips on the search function? I put "floor repair" in, and got everything but...
Old 10-22-2012, 04:44 AM   #14
I'm going to love watching this. I have a 1984 that I'm about to start tearing into and making major mods. Right now I'm collecting all the new parts, converter/charger, solar system, sink. Gonna redo the floor, new cabinet doors etc. I'm also making the bed mod moving it lengthwise instead of sideways. I'm looking for a bigger, nicer fridge and I'm toying with the idea of making it either a rear kitchen or rear bathroom (major mods). This is the luxury/curse of buying a cheap older trailer. I also need to change out my axle, let me know if you come up with a good one at a great price. Somebody put a leaf spring axle in mine and did a butcher job of doing it.
Old 10-22-2012, 04:59 AM   #15
Also, just looking at your pics you might want to pull off all that old yellowed seam tape. I took mine off and there was mold in the seams. I cleaned it up pretty good and washed it with bleach. It went a long way towards getting rid of the musty smell. You can still buy the tape and most other original parts that you need from Scamp and they are pretty reasonable.
Old 10-22-2012, 06:25 AM   #16
Have you found the source of leak for the rotted floor? Looks discolored but I can not tell it's condition. I pained my underlayment with an oil base paint to "seal" it before laying my laminate down.
By the way, I'm going to move this thread to another category "Care and Feeding" since it is now beyond introductions. Keep up the pictures, we love pictures.
Old 10-24-2012, 04:48 AM   #17
Jared J's Avatar
Kansas
I called scamp today. I ordered the factory lift, and a new 3500 lb axle with 5x4.5 bolt pattern. Easy, and I thought the price was fair enough. I also found out that the model wheel I have on my truck, also comes in a trailer wheel, bonus!
Will do. Mine isn't musty at all, but it looks bad, anyway. I'm collecting a parts list, and will be getting a lot of stuff at once to save on shipping.
The weatherstripping is bad on the back window. I just blobbed silicone all over it for now, since I'm trashing it, anyway. The floor could probably be left alone...but I'm already there. I'm going to replace it.
I don't have much to show. I've been removing decals before work when it's light, and cleaning the floor inside at night. I have two days into sanding down the floor just from the door through the kitchen, haven't even touched the raised portion yet. My oscillating sander and 36 grit hardly touched it. I'm running a 5" angle grinder with a 5" 36 grit flap disk in it.
I'm trying to put in 2mm peel and stick vinyl plank. If I went with laminate, I could be down by now. If I put a thin underlayment down, then the vinyl plank, I could be done by now. The problem is, my head just touched with the carpet and padding, now I have a fingers width of head room, and I don't want to lose that. An 1/8" is a big difference right now. So, I have to get the floor very flat to look decent, and clean of the glue/padding. After that, it's getting several thick coats of primer to help level it a wee bit more and stick down any loose fibers.
The benches will be out for a while. I want to redo the wiring, add more outlets, replace all the hoses for the plumbing, new water fillers with filters, port to clean out the fresh water tank, level monitors, etc.
Old 10-24-2012, 05:06 AM   #18
Axel Swap
Jared
If I were a days drive from the Scamp factory I would consider getting them to do the lift and axle work. You can't beat their labor cost and you will be back on the road the same day and you save on shipping. I took a 13 to them for an axle swap and made a vacation out of it. You just need to make an appointment to get it done. Need to move quick if you go this route because of winter weather.
Eddie
Old 10-24-2012, 05:20 AM   #19
I found a, made in America, 3500 lb axle here in Vegas for $249. It doesn't have hubs or brakes so I need to see if the ones on the axle I have will fit it. The axle isn't my #1 priority as I drove several thousand miles with this one and never noticed the difference until I crawled under to see about combining the outlets to both sewer systems.
Right now I'm looking for a Dometic rm8555. It is a beautiful fridge but the nice thing is it is less than 21" wide and will fit through our doors without modification on the doorway.
Old 10-24-2012, 06:48 AM   #20
In using the Search function, I ignore the top box, and use the lower one - the Google Custom Search - delivers much, much better targeted results...
Richard Hayes is offline   Reply With Quote
Wanted; 14" OR 15" WHEEL COVERS Joe Lacey Classified Archives 2 04-21-2010 08:04 AM
"U" Molding & Cabinet doors needed 76' Scamp Dave Baston Problem Solving | Owners Helping Owners 4 06-03-2008 04:27 PM
5th wheel "misjudgment"... steven jones General Chat 1 04-23-2008 05:31 AM
