No wonder the Burro floor is rotted - Page 2 - Fiberglass RV
Old 09-21-2010, 06:23 PM   #15
Trailer: 1980 Burro
Originally Posted by Andy B View Post
Thanks for the information on how much epoxy you used. I had been planning on getting 1.5 gal but after hearing your experience, I will get 2 gal. It sounds like you did a great job with the floor. I have not yet decided yet on what to use for a finished floor.
Prior to starting work on the floor I rebuilt the frame including replacing the axle with a 2000 lb Dexter axle with brakes. I used a 10 deg up angle because it looked like that was original and there was plenty of clearance in the wheel well. When I was locating the axle the frame was upside-down so it was easy to make small axle location adjustments before welding on the frame mounting brackets. I locked a loose hitch ball in the hitch and put a large washer on the threaded part of the hitch ball. The washer was large enough that it could easily rotate on the hitch ball shaft with a tape measure hooked to the inside edge of the washer. I adjusted the placement of the ends of the axle using the tape measure until both sides were the same distance from the hitch ball. It was within 1/64" when I was done.
As part of the frame rebuild, I also replaced the hitch, added an additional cross piece in front of the furthest forward cross member, and added two supports between each of the cross pieces, I also added much stronger support for the floor at the doorway. I added a 2" receiver in the rear and reinforcement along each side of the frame. I also added some angle iron in the triangle part of the frame. My source for most of the angle iron for the new frame supports is old bed frame rails that I have picked up for free. I also added a spare tire winch under the frame just behind the axle. I welded on supports in the front and rear for fold up stabilizers and numerous tie-down points on the frame that could be used to secure a tarp or lock the trailer to itself or something else.
Here are some pictures of the frame rebuild. The two lengthwise main frame supports are rectangular tubes made from 11 gage steel. 11 gage is a little less than 1/8" thick. My frame came from the factory with welded on supports on the inside where the frame bends. Other than the heavy coating of rust there were no cracks, sags or bends. I removed the rust with a wire wheel in a 4" angle grinder. On each side I added 8 feet of 11 gage steel to the outside of the frame rails.
Andy B is offline   Reply With Quote
Old 09-21-2010, 06:28 PM   #16
Trailer: 1980 Burro
More frame pictures...
Old 09-21-2010, 06:31 PM   #17
Trailer: 1980 Burro
And some more
Old 09-21-2010, 06:36 PM   #18
Trailer: 1980 Burro
Final painting, with new 14"wheels.
Old 09-21-2010, 08:28 PM   #19
Raya's Avatar
Wow
That framing you added (?) for the step looks really stout. No flexing there!
What are the loops for? (The ones that look like safety chain loops but in other places.)
Thanks for the photos
Raya
Old 09-22-2010, 07:33 AM   #20
Michel, Bouchard's Avatar
Trailer: Boler 1300 1973
Quebec
Nice work !
Boler 1300 1973
Jeep Wrangler 2dr 2012
Michel, Bouchard is offline   Reply With Quote
Old 09-22-2010, 08:12 PM   #21
Trailer: 1980 Burro
Originally Posted by Raya L. View Post
Wow
Raya
Raya, The original support under the doorway was two stubs of angle iron. Each one was a different size, like they just used scraps. The new support is 1 1/4" angle iron from old bed frame rails.
The old floor was really rotted and felt like you would fall through, so I decided to add the additional supports at the doorway and on both sides of the walking area down the center of the trailer.
The "loops" are made from half links of 3/8" chain, there are 4 on each side and 2 in front and 2 in back. I put them on for 2 reasons.
1) So there would be good places to tie down a tarp if I want to cover it for the winter.
2) If I want to lock the trailer, either at home or when camping, I can use a padlock and a loop of chain or cable through the wheels or to a tree and connect it to those locations.
Andy
Old 09-24-2010, 04:11 PM   #22
Trailer: 1983 Burro 13 ft
West Virginia
An attempt at Burro photo posting.....
Thank you Donna....the link was very helpful. I had attempted what others do routinely and your link supported my past efforts. I still seem to fall short and am beginning to think its my laptop. I did just as your link suggested and when I hit "upload" Windows xp says it "can't open that window"... Mr. Symantec will act as my enforcer and check out the laptop for baggage. Thanks to all.
Your work is above reproach, Andy. Looks great from here.
Best wishes,
Mike
ps...this goofy thing just said "windows xp cannot display this webpage" when I hit "upload" from my picture selection....yet again.
Mike Shackelford is offline   Reply With Quote
Old 09-25-2010, 05:45 AM   #23
Mike it sounds like your anti-virus. I run two machines with XP, one with 2000 pro and one on Vista. None have the condition as described, but I run McAfee. I've heard on other forums people have problems with Symantec and different forum software. While not as elegant and will cause problems in the future, you can post on a free picture hosting site and link back here. See this post by Janet for more info: Flying South for the Spring!
Old 07-05-2011, 02:31 PM   #24
Trailer: 1980 Burro
I just realized that I never posted pictures of the new floor installation, here they are... Old floor removal.
Old 07-05-2011, 02:39 PM   #25
Trailer: 1980 Burro
Some more pictures
Old 07-05-2011, 02:44 PM   #26
Trailer: 1980 Burro
And some more, good sealing at the wheel wells, the source of much of the water that rotted the first floor.
Old 07-05-2011, 03:13 PM   #27
Trailer: 1980 Burro
Inside attachment to the walls. I have been using 20 oz fiberglass and epoxy resin. The 20 oz is very heavy/thick glass. There are 2 layers where the walls and floor join, 0ne layer 3" wide and one layer 5"wide. I cut the strips at 45 degrees to the glass cloth weave direction so all the fibers go across the seam. There is also a 4" wide layer of the same cloth on the outside.
The center seam between the 2 shell halves was cracked both front and rear where it meets the floor. Cracked in front at top and bottom of window and rear at bottom of window. When they made the Burro they glued the halves together with thickened resin, but did not use any fiberglass to bridge the seam.
Old 07-05-2011, 03:25 PM   #28
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
you're gonna get alot of inquires about repairing trailers excellent work and documentation.
Bruce Thomas is offline   Reply With Quote
burro
13' Burro Floor Scott B. Modifications, Alterations and Updates 15 08-03-2009 09:11 AM
ripping out rotted floor..... LaurieK Problem Solving | Owners Helping Owners 6 06-06-2008 06:39 AM
replacing rotted floor section Isaac Problem Solving | Owners Helping Owners 9 12-10-2007 07:59 AM
New floor for Burro MyronL Modifications, Alterations and Updates 14 05-14-2006 04:29 PM
13' Burro Floor Mark Hutton General Chat 0 01-01-1970 12:00 AM
