Oh The Sun Shines Bright On My Old Trailer Home - Fiberglass RV
Old 06-08-2009, 09:35 AM   #1
james kent's Avatar
Trailer: Boler 1984
I know that some of you have huge solar pannels and some have minimum. Just what will EACH size really do?
For instance, how quickly will a 15w pannel recharge a battery and/or what will it support. Same question for 30w and for 45w?
If I start with a 15w pannel and a class 27 battery, will I be able to support a 40 qt, 12v cooler, a fan at times and overhead trailer lights in the evening? OR, do I have to move up to a larger pannel now? I am presently just using a 5w pannel for my inside lights [non led] in the evening and it is just adequate to recharge the system, if there's plenty of sunlight in the daytime.
Old 06-11-2009, 12:21 PM   #2
james kent's Avatar
Trailer: Boler 1984
Here's some information that I have found, using a 30Watt solar panel as an example
Typical power consumption..wattage/hr
Sump/Bilge pump...............100
CB radio...............................5
Clock Radio...........................5
Computer............................50
Cooler,12v[3A] Electric.........36
Lights [Compact 40w equiv....10
Satellite Dish........................50
TV 12".................................20
Power Output of a 12v solar panel generating 30Watts[at]15V=2Amps
Weekly Output...A 30Watt solar panel will generate 1470 Watts 98Amps} =30W x 7 hours x 7 days/week
Weekly Battery Charging Capacity...1470W will provide approximately 98Amps into a 12V battery over a 7 day period.
In a typical week a 30W solar panel will operate......
Item Wattage Hours of use
Sump pump 100 14
CB Radio 5 294
Lights 10 147
TV 20 73
Laptop 50 29
Satellite Dish 50 29
Cooler 36 41
Stereo 50 29
solar, solar panel
Sunny an' Bright Today I Took a Bike Ride Adrian W General Chat 1 02-14-2010 07:26 AM
Plugging in trailer at home Bruce Wray Care and Feeding of Molded Fiberglass Trailers 26 02-11-2009 07:01 PM
One tail light is too bright! Kevin A Problem Solving | Owners Helping Owners 18 06-13-2006 08:28 PM
bright spot Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 3 06-16-2003 09:34 AM
Bright sun Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 09-26-2002 08:29 PM
