ok to level with (built-in) rear jacks, for winterizing? - Page 4 - Fiberglass RV
Old 11-20-2012, 12:37 PM   #43
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
....... Both parties if I recall correctly felt it was a clear indication of the frame twisting/bending.
I'd think that frame twisting is more likely than bending, given most trailer frame designs. The open C channel or angle iron longitudinal rails don't have much torsional strength.
Old 11-20-2012, 09:34 PM   #44
Trailer: 1975 ventura 400 towed by a jeep grand cherokee sometimes, and an ugly 89 dodge truck other times.
A trailer shouldn't bend when you jack it by the bumper, but why take the chance? Also, many of our trailers are 10-40 years old. So they're corroded and fatigued, to the point where they aren't as strong as a new one. Better safe than broken.
streetvan1 is offline   Reply With Quote
Old 11-21-2012, 07:52 AM   #45
Brian B-P's Avatar
Pretty sure Brian P? once indicated (a couple of years ago) that when he jacked up the trailer from outside the undercarriage area - if I recall correctly he had the jacks under the bumper area & as a result he couldnt close the trailers door. I think he had a Boler though.
The above may be a reference to one of these posts:
Keeping Door shut while traveling? Trillium 4500 - post #9
Originally Posted by Brian B-P View Post
The only issue I have had with body flex due to frame bending has been when I have transferred too much load to rear stabilizer stands, bending the body up at the ends and causing the door to stick (latch jamming, not letting go).
rear stabilizing jacks - post #14
With my B1700 (which has 2" wide 4" high 1/8" thick box-section frame rails), I found that I can support it entirely at the ends of the frame, suspension hanging in the air, but it bends just enough that the door does not fit properly; put the load back on the suspension, and it flexes back to normal.
If anyone is referring to these posts, please note that:
  1. in this case I had the wheels entirely off the ground, which is very different from just relieving some of the suspension load
  2. the trailer is indeed a Boler - a 17-foot B1700 - not the same as the original subject of this thread
  3. I did have the supporting jacks right back at the bumper, although under the frame, not the bumper itself
  4. the bend in the frame was so slight that it was not visually obvious (and I was working under the trailer); I have no concern with my trailer's structure in this situation
  5. I did not lift the trailer with stabilizing jacks - I lowered the tongue, placed jacks under the back, then raised the front... so the jacks under the back were not moved while supporting load (a technique which can be used with any stabilizer jack).
The full text of the second post (linked above) also has substantial additional information, which I think is relevant and of some value, but of course I'm biased.
If either of these are the post to which Carol was referring: good memory - these posts are from 6 and 5-1/2 years ago.
Old 11-21-2012, 11:02 AM   #46
Yup those are them! Thanks for finding them. That long ago? My how time flys!
Bottle Jacks vs. Scissor Jacks Jane P. Towing, Hitching, Axles and Running Gear 21 02-26-2011 07:17 PM
Scamp rear leveling Jacks length? Roger Harshaw Towing, Hitching, Axles and Running Gear 2 04-20-2009 02:23 PM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
Rear Jacks - Am I missing a part? Sheryl M Problem Solving | Owners Helping Owners 15 10-17-2007 10:01 AM
rear stabilizing jacks Mo22 Problem Solving | Owners Helping Owners 23 05-18-2007 03:16 PM
