Old fridges - Fiberglass RV
Old 06-06-2007, 07:20 PM   #1
Trailer: 73 Boler 13 ft
Our "new" 1974, 13ft. boler has the original fridge, I'm thinkin'. The only identification inside is "Mini-15", Escort Cooler Company, Canada. Any opinions on this? It's pretty small, and looks to be not full depth of the cupboard. Suggestions for replacements?Thanks!
Peggy is offline   Reply With Quote
Old 06-06-2007, 11:20 PM   #2
Alf S.'s Avatar
Hi: Our local S.W.Ontario appliance dealer is www.gammonsrv.com At least you may find some options on line to help you shop locally for a replacement. Alf S. North shore of Lake Erie
Old 06-07-2007, 07:12 AM   #3
I see 78 people have viewed this topic and only Alf has given you his opinion ...well ...guess I'll give you mine too!
Depends
How's that for an opinion or suggestion
Actually it does matter...what do you want to accomplish? Are you looking for a three-way refrigerator, one that only runs on electricity (because you're always plugged in), would an icebox do? Or perhaps a 12-volt Igloo??
Maybe if you gave us some measurements of what you have to work with. .that would help too.
Old 06-07-2007, 10:41 AM   #4
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
Peggy,
We bought a small Haier refrigerator (at Sam's or Wal-Mart) as a replacement in our Scamp. It's electric only but we don't boondock, so that's fine. It's not very big but it's all we need since we usually only camp 2 or 3 nights at a time.
Sandra
Sandra Lair is offline   Reply With Quote
Old 06-07-2007, 01:43 PM   #5
I believe that the Escort is original to the Boler.....I replaced mine with a somewhat larger fridge that was in an older Starcraft pop up trailer......as you`re finding out, there are lots of options.....even using a vertical electric cooler, i.e. Koolatron or Coleman.....the only problem with these is that in hot weather the higher ambient temp reduces the ability of the coolers to cool....they only stay about 30-40 degrees below the ambient temp and also you don`t have a freezer capability with them, although the prices are pretty good.....I have a chest model and it was okay in the summer as extra cooling capacity....Benny
Old 06-09-2007, 08:22 PM   #6
Thanks for all the suggestions about the fridges. So, now that I have scrubbed it squeaky clean, we plugged it in, and no cooling happening! Is there anything to check before we just send it to the dump? I scrubbed all the storage compartments today too, and didn't see anything that looks like a fuse.. Tried the propane for the fridge and flame shot out the wrong junction of the tubing, in the outside compartment, but a bit of tightening of nuts seemed to fix that. A bit nervewracking, if the propane connections can jiggle loose.
So, what to do about the fridge?
Old 06-10-2007, 12:45 AM   #7
Trailer: 1975 Trillium 13 ft / Chevy Astrovan
Our frig didn't work at first, but after we took it on a really bumpy road, it began to work just fine.
I've seen other posts that bumpy roads or removing and carefully rotating an old dead frig can bring it back to life.
Connie M. is offline   Reply With Quote
Old 06-10-2007, 12:50 AM   #8
Robin H's Avatar
Trailer: 73 13 ft Boler / 2004 Toyota Corolla
Send a message via MSN to Robin H
I too have just found out the fridge in my 73 13' boler does not work. The rv shops said it is around $700 to replace - they suggested I just get a bar fridge from somewhere as I plan to always be in an electrified site. So I guess that is where I am at!
Robin
Robin H is offline   Reply With Quote
Old 06-10-2007, 09:43 AM   #9
John Perry's Avatar
Trailer: 1996 13 ft Scamp
Send a message via AIM to John Perry
Robin
Remove the refer and set it upside down for 24 hours and reinstall it and it will probably work. I have done this on 3 old refers in the past and it has corrected the problem every time.
John
John Perry is offline   Reply With Quote
Old 06-10-2007, 12:29 PM   #10
Are you serious about the upside down? What could that do? Is it an annual event? Weekly? Thanks
Old 06-10-2007, 02:36 PM   #11
Brian B-P's Avatar
Yeah, they're serious about the inverting and shaking thing. It's not a regular event, just a last-resort way to get the fluids in the system mixed up and flowing again, maybe once in the life of the unit.
Before resorting to that, I would do some more troubleshooting. Obviously, the propane burner wasn't entirely operable at first, and it still may not be right. If it is a three-way (AC/DC/propane), I would try each of the other heat sources first. Starting from shut down (not still warm from the propane burner), I would turn on one of the other sources; if the tube above the burner heats up, the electrical heating element is working. If that heat doesn't make the refrigerator cool down (allowing hours for it to be noticeable), then I might consider that it needs a "shake up".
There are various refrigerator service manuals in the Document Center; while none may be for this model, the operating principles are all the same, so they may still be helpful.
I'm lucky: I didn't need to do anything extreme to mine, and I would not look forward to getting it out of the cabinet.
Old 06-10-2007, 03:10 PM   #12
John & Sandy M's Avatar
Trailer: 1999 Scamp 16 ft
One thing to remember with the propane fridges is that they are SLOW to get cooled down (on either electric or propane... and they don't make any noise). You might leave it on in either mode over night and see if any result. If not, take a rubber hammer and tap on the coils in the back (crystals form in the tubes and may plug them up). The ammonia fridge is really handy when there is no electrical power as I live in hurricane country and stuff happens from time to time.
John & Sandy M is offline   Reply With Quote
Old 06-10-2007, 03:46 PM   #13
John Perry's Avatar
Very Serious. It has something to do with the liquid in the coils. I am not a refer tech so I only know that it works most of the time.
I just bought a slide in Camper for my PU on Ebay and the refer did not work . It does now after being turned uupside down over night.
John
Old 06-10-2007, 07:33 PM   #14
A ride on a rough road got my clunker going again a couple years ago......prior to that I had the fridge out when I pulled it out of a pop up and the coils didn`t cool but turning it on one side and listen to the gurgle , then onto it`s top, again more gurgling, then on the other side and ditto , and then back onto it`s bottom and it worked fine for about 3 years until when I let it run too long, parked, but not leveled....they have to be level to work....that was when I took it down a rough road.....there is a particular rotation to start, either right or left but have forgotten since I took an appliance course about 30+ years ago.......also like someone posted earlier....level it, fire it up and feel the inside body of the freezer.... and let it run for a few hours and then stick your hand on the freezer, and if it works, you`ll feel the frost starting to build there...it takes longer to actually feel the difference in the cooler part of the fridge... .....Benny
12-volt marine fridges with the Danfoss compressor Loren G. Hedahl General Chat 13 04-05-2008 05:27 PM
propane fridges Michel pouliot Care and Feeding of Molded Fiberglass Trailers 27 07-25-2007 10:26 AM
norcold fridges FYI General Chat 0 12-31-1969 07:00 PM
