Oliver insulation - Fiberglass RV
Old 08-05-2013, 09:00 AM   #1
Trailer: In the market
Oliver insulation
Greetings again: I posted a few months ago about the potential winter time use of these trailers. Bigfoot may be the consensus winner - if any forum can have a consensus. Well I have a new neighbor and he has a Oliver, which I toured, neat little trailer and from what I saw incredibly high quality. Now for the question what insulation is used (if any) between the walls? I searched the forum and some said lizard skin, which seems to be more of a sound barrier, and I don't believe the claims of painted on insulation. Others speculated on a 3M composite material, which is interesting, as I am a 35 year employee of 3M and did not realize we made a thermally insulating composite. Does anyone know for sure? Does anyone know the effective R value?
Thanks, and yes I did write to Oliver, but I suspect they are to busy trying to make trailers - and responding to e-mails hasn't reached the top of their I'm box.
Chucked
Stillwater Mn
chuckd is offline   Reply With Quote
Old 08-05-2013, 09:27 AM   #2
Glennrose's Avatar
Name: Rosemary & Glenn
Trailer: 2012 19' Escape
Are Olivers still being made? I thought they were defunct... Anyway, here is what I could find about their insulation.
Oliver say that "The Frame is an all aluminum box tubular design. The reason for an all aluminum construction is to lighten the weight of the unit as well as provide a frame that will never rust. The overall construction of the Oliver Legacy is a Double Wall Fiberglass Core that contains Thinsulate™ Acoustic Insulation. Basically, you have a completely custom molded fiberglass exterior shell, as well as a completely custom molded fiberglass interior shell. Between the two layers of fiberglass there is an insulation barrier. The custom molded exterior has been designed to direct and keep water from ever entering the shell. Every opening or attachment to the exterior has been encased in a fabricated enclosure and sealed to protect from all of the elements."
Glennrose is offline   Reply With Quote
Old 08-05-2013, 11:29 AM   #3
US
Robert will know if the Lizard is used
Fiberglass RV - View Profile: Robert Partee
http://www.lizardskin.com/
Old 08-05-2013, 12:33 PM   #4
cpaharley2008's Avatar
Do not over look Escape Trailers, another Canadian fg trailer manufacturer that can make you a customized trailer with winter upgrades.
Jim
Never in doubt, often wrong
Old 08-05-2013, 03:15 PM   #5
Jim: I called escape as they have a nice looking trailer. There cold weather package, is dual pane windows, foam on the underside of the coach, and addition relex(sp) in the walls. When I looked at how they installed the relex material, they did not have an air gap on either side, this is necessary for reflex to be any kind of insulation, as has been reported on this forum in the past. None moving air is a good insulator, that is why foams and fiberglass work as well as they do.
So if escape used a foam in the walls and ceiling, would be all over them.
Chuckd
Old 08-05-2013, 03:16 PM   #6
Brian B-P's Avatar
They're back in the trailer manufacturing business:
Oliver Travel Trailers production to resume
Oliver is Back!?
Old 08-05-2013, 03:20 PM   #7
Brian B-P's Avatar
Originally Posted by chuckd View Post
... addition relex(sp) in the walls...
Aluminized bubble-wrap insulation, most commonly known by the brand name Reflectix®
When they use it, Escape puts it on the interior side of the single fiberglass shell wall, and generally in places where it is in cabinets, rather than an exposed wall surface.
Old 08-05-2013, 03:32 PM   #8
Reflectix
Not going to debate (much) the veracity of reflectix or other bubble wrap materials, I saw a picture of the Escape production line with reflectix draped down from the top of the wall. It will not be effective when used in that manner no matter where it is used.
Chuck -who actually majored in heat transfer a very, very long tme ago.
Old 08-05-2013, 04:01 PM   #9
emers382's Avatar
Trailer: 2007 Escape 5.0
Manitoba
Jim, hope you chime in here, now I'm concerned about this type of insulation if Escape's method doesn't work then why pay extra for the insulation?
Adrian
emers382 is offline   Reply With Quote
Old 08-05-2013, 04:12 PM   #10
Brian B-P's Avatar
Originally Posted by emers382 View Post
... now I'm concerned about this type of insulation if Escape's method doesn't work then why pay extra for the insulation?
The Reflectix (or whatever brand it is) in an Escape with the extra insulation package will work as well as it does in a Scamp. Whether or not this type of insulation works very well anywhere is the subject of endless debate.
In any case, I don't think Oliver uses this type of insulation.
Old 08-05-2013, 04:36 PM   #11
US
Chuck
let us know if you get an answer from Oliver on the insulation. How long have you been waiting for a reply? We just had a thread how two other trailer places had problems answering email.
Old 08-05-2013, 05:05 PM   #12
Adrian
It works, it works real nice. There are 2 interior finishes, the 1" thick vinyl elephant hide wall and ceiling finish that is installed over the reflectix in all parts of the trailer in all areas from the bed and dinette up, including closets and overhead cabinets. The extra insulation package includes reflectix installed on all bare fiberglass below and underneath the bed and dinette exterior walls, over the wheel wells. Then you have the 3-4" spray foam underneath the floor which covers the entire floor, front to back. finally the dual pane Hehr windows, including the door. All this adds up to a well insulated unit that is warm in the winter and cool in the summer. I have been out in -0- degree weather in the 19' with the extra package and the tanks did not freeze and neither did I.
Jim
Old 08-05-2013, 05:07 PM   #13
I think Oliver uses the reflectix between the inner and outside shells, based upon my observation of inside closet and underneath seat areas inspection of the 3 Olivers I saw in Tennessee this Spring..
Jim
Old 08-05-2013, 05:21 PM   #14
GPJ
Trailer: Looking
There are 2 interior finishes, the !' vinyl elephant hide wall and ceiling finish that is installed over the reflectix in all parts of the trailer in all areas from the bed and dinette up, including closets and overhead cabinets. The extra insulation package includes reflectix installed on all bare fiberglass below and underneath the bed and dinette exterior walls, over the wheel wells.
So in a standard Escape without the extra insulation package, do you know what is the insulation used under the bed, under the dinette, over the wheel wells, etc? It sort of sounds like there is no insulation there unless you get the $1000 extra insulation package - but I may be misunderstanding and haven't seen this for myself.
GPJ is offline   Reply With Quote
oliver
Insulation Chris Jones Modifications, Alterations and Updates 4 07-21-2013 05:35 PM
Looking for Oliver Redrover Wanted: Molded Fiberglass Travel Trailers 10 08-11-2012 07:26 PM
insulation Hazel in Sk Problem Solving | Owners Helping Owners 9 07-15-2012 08:43 AM
Insulation Brian Tin Problem Solving | Owners Helping Owners 12 11-02-2010 08:02 PM
08 Oliver Tom Trostel Referrals: Molded Fiberglass Trailers 1 02-25-2010 06:13 AM
