Paint or Undercoat The Frame? - Fiberglass RV
Old 09-01-2008, 07:15 AM   #1
Trailer: 2013 Escape 19
Hi All. I'm thinking of painting the frame under our 2004 13' Scamp. The axle gets a lot of abrasion from the road and has lost whatever paint it once had, at least on the forward side. The swingarms are both a bit rust-covered. The actual trailer frame and small cross-members still have the paint mostly intact. So I'm wondering whether it's worth rolling under there to clean things up and apply a little rust-inhibiting paint after some sort of surface treatment (a rust conversion product, for example). I might even apply some sort of undercoating to the axle, since that might handle the abrasion better. On the other hand.....the axle/swingarm assembly is the one thing that gets periodically replaced and I'm sure whatever rust is on it will not be the limiting factor in its useful life. Thoughts?
Thanks,
Parker
Parker Buckley is offline   Reply With Quote
Old 09-01-2008, 07:28 AM   #2
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Thanks,
Parker
Hi: Parker... I found it easier and IMHO better to use an aerosol can of Krown Rust Control...$10.00 I think( 1 can does a 13'er). For one thing you can get the spray nozzel in places a paint brush won't go... it won't harm the fiberglass underbelly... it takes 20 min. to apply and working from the center out you won't get dripped on...and the compound creeps through the surface rust.
Thats what I did to our former Boler FWIW!!!
Old 09-01-2008, 09:29 AM   #3
RustOliem has a new product that has rust reformer in a spray can and it comes out like black paint. The rust reformer changes the rust . I just sprayed the frame of the 5r.
To find out what rust reformer is, look up another product "Extend" that sprayes clear and truns the rust black, a great product but more costly.
I like the RustOliem that comes out black. I purchased mine at Ace Hardware.
Old 09-01-2008, 09:54 AM   #4
I saw that product at Lowes. I think I may give it a try. I understand it forms a primer surface, so I'll go over that with RustOlium black. I appreciate the other comment about working center-out to avoid coming out looking like a Dalmatian!
Thanks,
Parker
Old 09-01-2008, 09:59 AM   #5
http://www.rustoleum.com/CBGProduct.asp?pid=40
Rust Reformer
Old 09-01-2008, 01:00 PM   #6
Tony Nowak's Avatar
Trailer: 2003 Bigfoot 17 (15B17CB), 2017 Escape 17B
Wisconsin
Parker,
We are painting the frame of our 1999 scamp. We sanded and primed the tongue and bumper and plan on using semigloss black as a finish (Rustoleum).Those areas were not that rusty so I didn't think it was necessary to use a rust converter.
Under the trailer I plan to use Extend since that area is quite rusty and I already have some on hand. Thanks for asking the question on the axle/swingarm, as that is a question of mine.
Tony and Darlene
Tony Nowak is online now   Reply With Quote
Old 09-01-2008, 01:27 PM   #7
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Parker, you have seen what condition the trailers underbelly is like now. Any 'protection' you use now to protect for the future IS going to get the same treatment the underpinnings have had over the years so, NOTHING is permanant. Saying that though sounds almost like I'm trying to deture you from painting. NO, NOT so, just being sure you are aware that it will need similar attention in years ahead. This attention paid IS A GOOD IDEA!!!!
Old 09-01-2008, 02:43 PM   #8
Paint over rust and it bubles through the paint. Use rust reformer first then paint over that and you should be golden.
The new rustoleum rust reformer comes out black and makes a great primer at the same time.
Old 09-01-2008, 03:42 PM   #9
james kent's Avatar
Trailer: Boler 1984
I have a quart can of Tremclad [Rustoleum] rust paint in the basement and use it and a brush to re-coat the fram every few years to make it presentable.
No matter how much I try to be neat I always seem to get just as much on my arms too. Painting the underside of the frame is not my claim to fame.
Old 09-01-2008, 03:52 PM   #10
Just got back from Lowes armed with RustOlium rust converter and their enamel to topcoat it. I really appreciate everyone's comments, including the reminder that this won't be a permanent paintjob. I considered using something more elastic for the axle, like an undercoating, thinking it might resist the abrasion a little better, but what the heck.....it will be good to roll under there and get up close and personal with the undercarriage again in a couple of years.
Parker
Old 09-01-2008, 04:55 PM   #11
While U R under there, check your brake wiring and ground(s). Make sure your brakes have a good ground.
I have used the rust reformers for over 25 years and I do not remove the rust. I reform it and it seals the rust and does not rust in that spot any more. I know others will say the rust must be removed however I did this on a Plymouth Valiant that I drove for 10 years and the rust spot never got bigger or rusted again. I'm a firm believer in the product. When using the reformer, it turns the rust spot black and that may not look so good however It just don't matter on the frame.
Good Luck on your frame project.
DR in Virginia
Old 09-01-2008, 05:27 PM   #12
DR in Virginia
DR,
A friend showed me a spot he treated on an old Volvo years ago, and he had the same luck with it that you describe. Probably the biggest thing will be washing all the road crud off first. I'm not going to go crazy with this, however. Gotta get back out on the road with this thing while we have the weather for it!
Parker
Old 09-05-2008, 12:57 PM   #13
"Probably the biggest thing will be washing all the road crud off first."
I have a buddy who uses an oscillating lawn sprinkler for this job. He puts it underneath, turns the water on for awhile, moves it along under the vehicle/trailer chassis and repeats as required. Kind of a "set it and forget it" procedure. Not that it is a water conserver, mind you.
Don
Don & Viv is offline   Reply With Quote
Old 09-05-2008, 01:43 PM   #14
Don
Guess I could park it over the lawn and get credit for watering the grass if nothing else! Actually, by this point, I've been under there with a spray bottle of Simple Green, a wire brush, and a garden hose and have that part done, at least to my satisfaction. I've now got it primed with the rust conversion spray and will probably get it top-coated this weekend. When it comes right down to it, it took less time to do it than I've spent here writing about it!
Parker
paint, painting
Frame Paint Question DannyH Problem Solving | Owners Helping Owners 4 11-05-2009 05:16 AM
Flooring and Frame Paint Advice? Jeff Nightingale Problem Solving | Owners Helping Owners 24 09-15-2009 05:55 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
FRAME JIMZ Care and Feeding of Molded Fiberglass Trailers 53 02-17-2008 10:05 PM
Frame sag Rick Weiss General Chat 0 12-31-1969 07:00 PM
» Trailer Showcase
Seascape
kkinna
Scamp
GingerB
