painting fiberglass - Fiberglass RV
Old 10-03-2012, 09:28 PM   #1
Utah
painting fiberglass
The trillium I have has been painted but the paint is wearing a lot at the metal parts and some areas of the body are deteriorating. I was considering using monstaliner for the durability. I'm sure some you would cringe at the thought of this but I intend to take the trailer most everywhere I can, it has a two inch lift. Anyway, I'm not married to the idea but I am wondering if anyone has tried this. If it is a bad idea, other suggestions you might have would be appreciated. If this has come up before,point me in the right direction and I will check the other posts. I have had no success with the search engine on the site.
saltcreek is offline   Reply With Quote
Old 10-03-2012, 09:45 PM   #2
Jared, it all gets down to how you want it to look when you're done. The Monstaliner is a great idea if you don't mind the rough surface. Totally maintenance free and shouldn't ever chip or flake if you've prepped the surface per the instructions.
The other option is to use a single part polyurethane marine paint, like Interlux Brightside. These paints can be rolled on and "tipped" with a high quality brush for a shiney surface finish that will look like it was sprayed. Again, you'll have to prep the surface per the manufacturers instructions. You can find these paints and video instructions on the web at places like Jamestown Distributors. I suspect the Marine finishes will be more expensive than the Monstaliner by the time you're done.
Good luck. Send us pictures of the work and final results !!
SailorSteve is offline   Reply With Quote
Old 10-04-2012, 04:06 AM   #3
Hi Jared, check out this link and the pictures of Jenny's and Brady's Boler completely done with DuraBak: Total Boler Restoration or go straight to the pictures here: Brady's and Jenny's Boler on Picasa
Old 11-06-2012, 08:40 PM   #4
StacyJayT's Avatar
Trailer: "79 Scamp "Tiny Tow"
Painting
That Durabak is incredible! I love what they did. I wonder if it added 100 lbs to the trailer! HA!
StacyJayT is offline   Reply With Quote
Old 11-07-2012, 02:52 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
As with any paint job, preparation is key- adhesion of the top coat will be entirely dependent on the substrate it's applied to. If the paint that's on the trailer now is coming off, it will probably continue to do so if you attempt to paint over it.
Whatever you decide on as a top coat, you may have to remove the paint put on by the P.O.'s, and sand/prime the original gelcoat so as to provide a gripping surface for the new paint.
Good luck with the project!
Francesca
painting
Painting fiberglass Marjorie M. Care and Feeding of Molded Fiberglass Trailers 9 04-03-2017 11:11 AM
Painting interior fiberglass Cyndivg11 Care and Feeding of Molded Fiberglass Trailers 4 07-23-2009 10:59 AM
Painting Fiberglass Interior Booker B. Problem Solving | Owners Helping Owners 6 04-27-2008 09:44 PM
Painting Fiberglass Cupboards LauraW Problem Solving | Owners Helping Owners 4 04-26-2006 03:14 PM
Painting fiberglass John Vleck Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
