Painting vs. Gelcoat - Fiberglass RV
Old 04-28-2010, 10:45 PM   #1
Pamela S.'s Avatar
Trailer: 1984 Fiber Stream
I would be happy to just rejuvenate the gelcoat on my camper, but I had to repair a good-sized crack on the front street-side corner with new fiberglass cloth. So, obviously the color doesn't match the rest of the camper at this point.
I had assumed that I would have to repaint the entire camper to get a consistent color and a nice, finished look. However, I was browsing the West Marine site, and found that it is possible to buy gelcoat for repairs.
What would be a better approach, spiffing up the old gelcoat, and adding new gelcoat to the repair, or repainting the entire camper?
Based on what I've read on this site, I would use something like Marine Interlux with an extra small, high quality roller if I went the route of repainting.
Pamela S. is offline   Reply With Quote
Old 04-28-2010, 11:13 PM   #2
Raya's Avatar
Hi Pamela,
Assuming the rest of your gelcoat is either in good shape, or can be brought back (compounding or buffing) - and that you like the color - repairing a small area of it will probably be much less work and expense than painting.
Prepping for paint and then doing a good paint job is no small feat. It is a lot of work to do it right, and supplies are expensive. Especially if you use a premium coating, like a two-part LPU (more durable and the gloss is much longer lasting than a one-part paint such as Interlux Brightsides, which is a modified alkyd paint).
Now, that's not to say you shouldn't paint. A good paint job is a wonderful thing. Some high-end boatbuilders are delivering new boats with LPU paint instead of gelcoat right from the get-go. But making a gelcoat repair is going to be much easier and more cost effective, if it is feasible.
(And if you decide to go ahead with a repair we can give you tips.)
Raya
Old 04-28-2010, 11:53 PM   #3
Pamela S.'s Avatar
I think I can probably revive the bulk of the gelcoat with poliglow or something. I didn't realize that I might just be able to fix the gelcoat on the repaired area. I thought gelcoat was only applied when the fiberglass was first molded.
Old 04-29-2010, 12:37 AM   #4
Raya's Avatar
Well in a sense you are correct. The trailer is made in a female mold. First gelcoat is sprayed in, and than after that the fiberglass is applied (sprayed chop, or hand laid, or etc.). The gelcoat is mostly a cosmetic thing, but it is part of the molding process.
Gelcoat can be "painted on" or sprayed later, but in my opinion you have then lost the main reason to use gelcoat, and might as well put on something like a good LPU coating (meaning, if you had a bare fiberglass egg with no gelcoat and wanted to coat it, at that point why use gelcoat) (but that is just my opinion and others might have different opinions).
Anyway, the main point is that gelcoat can be patched - it's done on boats all the time.
Raya
Old 04-29-2010, 07:30 AM   #5
Too it depends on your expectations when finished. Your trailer is 26 years old. The gelcoat is not a consistent color across the body of the trailer. If you're expecting a perfect match on every patch, you may be disappointed. I would imagine every single patch would need to be judiciously color matched.
Old 04-29-2010, 07:39 AM   #6
Roy in TO's Avatar
A few years back I got some video's from the local library on gelcoat repairs. The interesting thing is that when you colour match gel coat, the colour does not change like paint when setting.
Link to my original post on videos.
I did a quick test while repairing my door using a brush on technique without colour matching and the gelcoat repair has held up.
Ray Massen totally redid his gelcoat. I've poured over Ray Massen's work a number of times to read how he did it. If I was keeping my boler American, I was going to try it.
http://forums.delphiforums.com/boler...ges?msg=5633.3
http://www.artechweb.com/boler.html
http://www.artechweb.com/2005arc.html
If I understand him correctly, the prep work is the same as prepping for painting. Applying the gel coat is about the same as painting, and getting the shine is about the same as restoring an old finish. IF I had a shop to work in and a place to store it, I am positive that is the way I would go. I even found a local supplier of gel coat that does custom colour matches.
Old 07-14-2010, 03:32 PM   #7
Gel coat is relatively easy to work with. You can spray, roll or brush it on and it can be sanded with superfine wet & dry sandpaper to get the same smooth finish as it comes from the factory. Once it is sanded smooth, buff & polish to bring up the shine.
You may have to tint the gel coat to match the patch are for colour, the closer you come to the surrounding colour, the more invisible that patch will be. The down side is the catalyst that is required to make it harden.
Kevin
KevinC is offline   Reply With Quote
Old 11-15-2018, 11:08 AM   #8
Trailer: Burro
Paint or Gel coat?
can any one clarify for me. To "redo" the outside, I mean restore the white shiny exterior of my Burro general steps are thus:
wash and repair fiberglass holes cracks etc.
sand and prime whole unit
apply paint then gel coat? Or apply paint or gel coat?
3-4 coats with sanding in between
polish and shine with wax?
also has anyone done this to the interior?
also I have no garage can this be done out side on a fine day? or do I need to construct or buy a " temp garage"?
thanks K
pot roast n kisses is offline   Reply With Quote
Old 11-15-2018, 12:10 PM   #9
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Karen,
Restoring the exterior gelcoat surface can mean many things including:
- Scrub, wash, wax and polish: good idea to try this first to determine whether the original gelcoat is in good enough condition to rejuvenate.
- If the original gelcoat is not in good enough condition to rejuvenate, either because it is severely damaged (chips, cracks, etc) or worn through to the glass layer, then it can be repaired and then coated with either new gelcoat or paint.
- Much of the work can be done outside in fair weather, however, applying either new gelcoat or paint is easier done under cover.
Restoring the interior gelcoat surfaces can usually be accomplished by cleaning, waxing and polishing, unless its severely damaged.
EDIT: Its my understanding that gelcoat is more difficult to work with than paint. First, matching/coloring gelcoat is usually a DIY task, unless you buy off the shelf colored gelcoat and coat the entire camper, e.g., white. Second, it produces a very hard, rough finish that must be sanded extensively before re-coating. Paint on the other hand is easy to match in paint stores and just requires light sanding between coats.
John
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 11-15-2018, 05:54 PM   #10
Trailer: Casita 16ft.
The OP dates back to 2010. It's interesting how some of these can remain in play. Especially when they have relevant questions.
Here is a good comparison of gel coat vs paint by someone who knows a lot about the topic.
Nor Cal Mike is offline   Reply With Quote
Old 11-15-2018, 06:16 PM   #11
West Marine has a youtube channel. Before you try to make a definitive decision you can watch their gel coat repair video. The best decisions are informed decisions and videos showing what you will be doing when you make a purchase of a product does allow you to make an informed decision.
https://www.youtube.com/playlist?lis...0280DD6B1D2331
Old Yesterday, 09:07 AM   #12
Trailer: in the market
Indiana
Delphi Forums Login - Welcome! Please log in.
Boler Blog
Boler Blog archive 2005
Hi,
Can you tell me who did the custom color matching on your gell coat?
Ours is beautiful avocato green.Trillium 1300
thanks,
Rich
rjannunziata is offline   Reply With Quote
paint, painting
Gelcoat Cavities and Cracks kyle minor Problem Solving | Owners Helping Owners 23 11-14-2011 11:08 PM
Longing to spray a new gelcoat Gigi Modifications, Alterations and Updates 14 05-06-2006 08:17 AM
Repairing the gelcoat Legacy Posts Care and Feeding of Molded Fiberglass Trailers 16 08-07-2003 02:56 PM
Fiberglass, gelcoat or paint? How can I tell? Legacy Posts Problem Solving | Owners Helping Owners 2 07-12-2003 01:26 PM
Renewing gelcoat surface Legacy Posts Problem Solving | Owners Helping Owners 5 06-18-2003 01:59 PM
