Preferred Deep Cycle Battery Brands? - Page 2 - Fiberglass RV
Old 04-04-2009, 10:53 AM   #15
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Donna is right, for example I know that Home Depots plumbing fixtures are not always equal to the same model that a plumber would get from a wholesale supplier.
A good AGM or L-16 deep cycle battery properly maintained and not overcharged should last up to 8 years.
I am not saying there is anything wrong with Walmart batteries, there are just better ones made out there.
I prefer to keep my batteries inside, and modified my current trailer to house them in a bench inside a sealed chamber. The new Escape I am getting has them inside too.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-04-2009, 01:08 PM   #16
Don N's Avatar
Trailer: 1989 Bigfoot 17'
No votes for the AC Delco Voyager? I just installed one in mine a month ago and have only used it for the one week in Florida.
Don N is offline   Reply With Quote
Old 04-04-2009, 03:49 PM   #17
As most of the eggs come with inexpensive converters that do not have the smart charger capability and tend to boil the water out of the sealed tight battery that seems to indicate that one should either get the least expensive 3 year replacement battery, or invest in a more expensive converter and an AGM battery.
When the math is finalized, the 3 year total replacement battery from WalMart, BJ’s Wholesale, Costco or Sam’s Club will prove to be the most cost effective hands down over the up conversion of the converter and AGM.
Do the math and prove this theory wrong.
Old 04-04-2009, 06:21 PM   #18
Pete Dumbleton's Avatar
On second thought, purchase one of those DEEEEP Cycle $150 batteries that really last, put on the front of your trailer, and see just how long it remains there. (They are some kind of coil technology and are one of the following colors Yellow, Red or Blue)
Lest the Fairy Tale continue, as we have discussed on the Forum before, the Optima batteries are *NOT* DEEEEEP cycle, rather they are a hybrid of deep cycle and starting and don't have as many Amp-hours as a typical El Cheapo flooded lead-acid from many sources -- They may last twice as long, but typically cost in excess of twice as much...
Optima - Hybrid
Wally Trolling - Deep cycle
Trojan Deep Cycle - DEEEEP cycle
See PeterH's comments above in this thread for more info on the Optima and Trojan.
Batteries can be a fragile thing subject to failure from outside (Bad TV charging system, bad converter charging system) and can be stolen (been there), so I am personally reluctant to get anything but the El Cheapo -- YMMV!
Old 04-04-2009, 06:56 PM   #19
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
Smile
I go with the Walmart idea, when you stick with name brands and something goes bad on the road you have to find a dealer if you are stuck on the same brand the blew. Walmart, because there is one in every town you walk in as I did with or without a sales slip they look at how long you have owned it and your on your way in 15 minutes with a brand new one. Sometimes it doesn't matter how well you take care of stuff it still goes south.
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
Old 04-05-2009, 05:48 AM   #20
Yvon Chayer's Avatar
Trailer: Bigfoot 17 ft 1992
Quebec
In my last Boler i use 4 years a delco voyager size 24 and i dont have nothing problem and for fishing i use delco voyager size 27 since 3 year and it is perfect with my trooling motor
When i bought my scamp 16 4 years ago it come with a optima batterie and it work great again same if I l' have to empty complete several times and it was full of power again
For me delco voyager and optima are great battery and optima require no servicing
when i bought my scamp i have equiped it with an intlli-power converter and i love it , battery always full chage , no overchage a full power when i have 110 v acces and when i have a dry camping i run a 2000i honda when it require to chage battery for me it is a great set up
Alway same thing, escuse my english i speak it just a bit !!!
Yvon Chayer
Yvon Chayer is offline   Reply With Quote
Old 04-05-2009, 06:39 AM   #21
Yvon, your English is just fine.
A good converter like the Inteli-power over its life span will pay for itself by keeping a battery properly conditioned and protected. A good converter is equally or more important to the longevity of a battery, then the type of battery itself. Yes, even for the Walmart batteries.
The Delco Voyager and Optima are both good batteries, and perform well. The Optima is rated for about 1/3 more charge cycles, but cost twice as much.
One other reason for going with a better deep cycle battery, is that they can often take more then twice as many charge cycles.
I know I'm going to get more bashing from the Walmart fans, but the OP did ask for opinions after all.
2017 Escape 5.0 TA
Old 04-05-2009, 06:56 AM   #22
No bashing here. Objective opinions based on facts are valued. It's about giving choices. Different strokes for different folks
Old 04-05-2009, 08:29 PM   #23
james kent's Avatar
Trailer: Boler 1984
I picked up ours at Canadian Tire. I think it was the largest they had. I added a two wire plug at thebattery so that I can connect this small 15w solar pannel which I sit on the rock guard. It's enough to replenish the battery which we use for lighting only.
BTW We used to carry a battery box on the tongue but no battery. We used it as a small toolbox for hammer, pliers wrenches etc.
This is the other picture I meant to place
Old 04-05-2009, 09:56 PM   #24
I buy Interstate 27DC from Sam's. They are $6 more than the Everstart at Walmart, but I believe the Interstate brand to be more reliable.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 04-10-2009, 04:44 PM   #25
Pamela S.'s Avatar
Trailer: 1984 Fiber Stream
Are any of the Walmart cheapies sealed AGM or are they all the type that need distilled water added?
Pamela S. is offline   Reply With Quote
Old 04-10-2009, 10:36 PM   #26
All of the Wally-batts I have seen so far have been flooded lead-acid batts, not AGM, but it seems to be up to the store managers as to what they stock. FLA's usually have a way to add water, although some are sealed very tightly so as to be called maintenance-free.
Old 04-11-2009, 05:13 AM   #27
Trailer: 73 Boler (modified)
I have the cambodian tire one too, It's a group 24 Nautilus marine deep cycle. i only used it for half of last season, left the converter plugged in a little too long (apparently), and I forgot about it in the trailer this winter. (i know i know, but we had bigger fish to fry ). I pulled the boler out of hibernation, it still had a charge and the cells are still full. I'm impressed for $90. plus it's got the 3 year warranty, so i think i'll keep right on abusing it...
Nate is offline   Reply With Quote
Old 04-12-2009, 11:37 AM   #28
Doug P.'s Avatar
Trailer: Escape 5.0TA
Southern Alberta
For maximum amp hours you should look at two 6 volt battries
instead of one 12 volt. Most 6 volt battries made for golf carts
work great and you can really abuse them....
Doug P. is offline   Reply With Quote
battery
Two 6 volt vs. 12 volt deep cycle Kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Deep Cycle vs Marine Deep Cycle? Shelley Care and Feeding of Molded Fiberglass Trailers 5 12-17-2016 05:23 AM
What kind of Battery to buy. . . Marine Deep Cycle okay? Maggie S. Electrical | Charging, Systems, Solar and Generators 28 11-17-2011 09:46 PM
Help! New Dometic refer too deep... Robert Johans Problem Solving | Owners Helping Owners 7 03-15-2010 11:26 AM
13' Trillium Trailer wanted - Vancouver Island preferred but will Booker B. Wanted: Molded Fiberglass Travel Trailers 2 12-19-2008 09:42 AM
