Preserving Casita fiber glass finish - Fiberglass RV
Old 05-04-2015, 09:06 AM   #1
Name: Jim & Chris
Trailer: Casita Spirit 17
Question Preserving Casita fiber glass finish
About 3 years ago I read a post on treating the outside with a product called RedMax acrylic floor coating. The poster had success with the process so I tried it. It did an outstanding job of preserving the like new shine. It was recommended that it be recoated every 2 years or so. It's been 3 years and the coating has become mottled, with some spots completely worn off and others still looking good. My question is: What do I use to strip off the old coating as I want to recoat it again. I still have the original RedMax material, however when I tried to find the RedMax stripper, it is no longer available. The company was bought out by ZepCo. I tried the ZepCo stripper recommended on their website but it does not remove the old coating. I tried laquer thinner, and it does take the coating off, but it is a very long and difficult process as the laquer thinner dries very quickly and leaves a sticky residue. There has to be an easier way!
Any suggestions would be greatly appreciated. The camper is kept inside except when on a camping trip. 1995 Casita Freedom Help!!! Thanks
semaj38 is offline   Reply With Quote
Old 05-04-2015, 09:20 AM   #2
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
I gave up trying to strip the old coat. I washed very well and dryed. Then I started reapplying RedMax. It only took 2 or 3 thin coats where the original shine was good. It took 5 coats where the original had worn off. Now looks just like 4 years ago.
Old 05-04-2015, 09:49 AM   #3
Jim first thing is do not use lacquer thinners on the fiberglass unless nessasary to remove small spots of paint residue or overspays. The zep floor stripper should easily remove the zep or red max finish if done properly as I have removed the finish on my trailers many times.aply the stripper in small sections at a time giving it a little time to desolve the finish use a sponge scrub pad to remove the old finish and rinse . You can also bypass all of these steps by wet sanding the old finish with 600 grit wet sandpaper removing the loose finish and just reapplying a new coat of zep high gloss finish as I just did on the trillium and it's good to go for another year or two . The trillium I just refinished looks as good as the first time I did it .
Mikmay is offline   Reply With Quote
Old 05-04-2015, 10:03 AM   #4
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Years ago I saw a post where they stated that if you use the "engine & tire" setting at the local self car wash, let it soak, then wash, the Red Max will strip off. I haven't tried this to see if it works.
Dave & Paula
Old 05-05-2015, 09:24 AM   #5
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
I use Poly glow rather than RedMax and the Poly glow kit comes with a stripper that should work on the Red Max. Pretty sure it's available separately.
Walt
Old 12-26-2015, 07:09 AM   #6
Name: Jim & Chris
Finally after 7 months!
<_< It's been a busy year and not much camping. I finally got out to my shop and went to work on the Casita to remove the Redmax(Poly Glo). See my post from May 5 2015. After reading Mikmay's response, I went back and actually read the directions on the Zep floor stripper jug and guess what? I worked perfectly, I did a small patch, say 4/4', used a sponge/scratch pad from the kitchen and then sprayed it off with my carwash pressure washer(small electric one, 1500psi). It is back to the original pure white and even the tree sap stains are gone! Now, back to recoating it and following the directions. (Some folks are slow learners!) we are looking forward to a full camping year in 2016. We hope to meet some of you on the road this year! Thanks for all the good advice and help. Jim
Old 02-04-2016, 12:45 PM   #7
Trailer: Casita 2001 spirit
I need to wash the dust off to see how well the the wax job has lasted. What do I use for soap in my bucket to start with?
Elaine
partslady9 is offline   Reply With Quote
Old 02-04-2016, 01:07 PM   #8
Trailer: Casita 17 ft DLX SD
Elaine
I use car wash soap that is designed to remove dirt but leave the wax.
Old 02-04-2016, 02:02 PM   #9
Thanks, car wash soap it will be, thought El Nino might do the job but think that has passed by southern CA.
Elaine
Old 02-05-2016, 10:45 AM   #10
Trailer: 1999 Casita 17' SD
Ohio
Floor stripper works great but you have to keep it wet and then when it's soft wash it off. If it dries you'll need to reapply the stripper.
ZEP was the original manufacturer of Red Max and they just changed the packaging.
casita, vin
For sale 1974 eco fiber glass travel trailer dorothy m Classified Archives 4 03-05-2010 10:23 AM
wanted 13 ft fiber glass RV mary P Wanted: Molded Fiberglass Travel Trailers 1 03-11-2009 09:58 PM
Information on small fiber glass trailers William Lee Care and Feeding of Molded Fiberglass Trailers 2 04-14-2008 08:51 PM
Roof Mounted Fiber Glass Shelf Kurt in BC Modifications, Alterations and Updates 10 03-24-2008 09:34 PM
fiber glass mtr hm for sale bud sutter Classified Archives 0 10-29-2007 11:42 AM
