Prevent wasp nests under trailer? - Fiberglass RV
Old 10-09-2015, 05:16 PM   #1
Does anyone have a good suggestion on keeping wasps (of one kind or another) from nesting under the trailer and in the bumper?
I don't know about other areas, but here in LA (Lower Alabama) they want to build nests in very short times and when you go out the work on the trailer....Surprise!
Old 10-10-2015, 09:42 AM   #2
Trailer: Scamp 16 ft.
Well, spray foam is great at all the openings under the wood floor of Scamps. Other than that, a good spray once they start to nest.
Flyboyscamp is offline   Reply With Quote
Old 10-10-2015, 02:49 PM   #3
As far as your bumper goes I got some bumper caps at Tractor Supply that were designed to keep out wasps. You might try spraying WD 40 under your trailer once and awhile. The wasps wouldn't be able to attach their paper nests to any surface with WD 40 on it.
Lee
Captleemo is offline   Reply With Quote
Old 10-10-2015, 06:40 PM   #4
Trailer: T@B
Arkansas
They are bad where I live as well. I store my trailer under an open-sided shed. The only way I can control them is to spray insecticide on the shed and under the trailer about three times a year. Since I live out in the woods, I don't need to worry about affecting anyone but me. I do wear protective clothing and wash my hands after handling the trailer. I hate using it, but I hate getting stung as well.
RZRBUG
2013 T@B
Larry G. is offline   Reply With Quote
Old 10-11-2015, 08:04 AM   #5
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
I'm in the pest control business and if I had a product that would keep wasps from building nest on or around houses, campers, and any and all buildings I would be a millionaire!!!
The best thing you could do is fog under your RV with a flying insects spray that contains permethrin. It is a very safe insecticide. It will flush the wasps out to where you can see them and then go treat there nest directly with the same spray. It is very fast acting and there is very little chance you will get stung. Not to say a rogue wasp with a vendetta won't hunt you down and take vengeance on you!
Jason
If you think you are to small to make a difference just try sleeping with a mosquito –- The Dally Lama
kirkman is offline   Reply With Quote
Old 10-11-2015, 06:29 PM   #6
Trailer: currently shopping
Massachusetts
Wasps
They generally will not build a paper wasp best where there are other nests. They are territorial menaces. Stuff small brown paper bags like lunch bag and hang them in the area of the camper. It may work. Check every so often to see if it will work. I have seen this trick work with others.
rita in ma is offline   Reply With Quote
Old 10-11-2015, 08:59 PM   #7
Administrator
Mary F's Avatar
Paint the underside of the trailer sky blue, the way the ceiling overhangs of porches are painted in the southern U.S.?
Mary F Fiberglass Rules!
FGRV Forum Custom Search
How can we prevent theft of our FGRV? Ellpea in CA General Chat 54 09-02-2015 11:22 AM
Anybody install a siphon360 to prevent black/grey water odor? jenbooks Modifications, Alterations and Updates 50 06-11-2015 08:11 PM
Wasp/hornet spray for self defense rabbit Problem Solving | Owners Helping Owners 47 03-18-2013 12:16 AM
FOUND - Wanted: FG trailer under 2000 pounds Brian Barr Classified Archives 2 04-02-2009 11:35 AM
