Preventing mold - Fiberglass RV
Old 03-23-2012, 09:00 PM   #1
Trailer: 16 foot Scamp
Preventing mold
I did a search but didn't find any real answers. Maybe that's because there aren't any! I am wondering how people who live in very wet climates prevent mold from forming in their trailers. I noticed spots of mold this year on various surfaces in my trailer. I'm also wondering if the rat fur liner in a Scamp could harbor mold? I really want to nip this in the bud. Lysol spray supposedly kills mold and mildew, but it stinks so bad. Does anybody know any magic here?
DavidSo is offline   Reply With Quote
Old 03-23-2012, 09:29 PM   #2
Trailer: 2008 13' Scamp
Ventilation seems to have worked for me over the years keeping my boats mould free. I think that the worst thing that you can do is put a plastic tarp over a boat or trailer and trap the moisture.
One extra that I do when I have access to power is use a single light bulb, mounted in a tomato juice can to create a convection current under a slightly open vent. Some people use a dessicant type dryer which also seems to work. But I think the most important things to do is provide ventilation and keep the interior dry.
Ron
Old 03-24-2012, 05:39 AM   #3
My trailer is buttoned up and winterized from right after the Fall NOG in October until right before the Spring NOG the last week of April. During hibernation, I use Dri-Z-Air (classic). I place the canister inside a plastic tub and put it in the sink. I've also be known to put another near the door. After every camping trip, I place the cushions on their sides to help with through ventilation.
This works for storage, but David are you looking for a 365 day solution? here's an entire thread. I see Linda and Taylor run a Sears Kenmore mini dehumidifier... requires electricity: Winter Storage - in very wet climate
Old 03-24-2012, 09:08 AM   #4
David Swinnard's Avatar
Trailer: Had to sell, no longer an egg owner
My Trillium moulded very badly the first winter I had it. It was buttoned up fairly tight with only minimal ventilation. After a long job of cleaning up all the black stuff I went with a small fan, a 100W open light bulb, and most of the jalousie windows open a touch. No more mould, and we get very damp, cool winters here. (the rest of the seasons too, but hey, we got TREES!)
The little fan has been running night and day, all year long for over three years now. What a fine little device.
100W bulbs are getting hard to find, but I did get a lot of them a while back when the local Home Depot was blowing them out.
Simple solution to a problem that was a real bear to clean up from.
David Swinnard is offline   Reply With Quote
Old 03-24-2012, 12:11 PM   #5
Thanks for the replies and the link to that thread! I think I will try some combination of fan and heat. The fan is easy using just a muffin fan. The mold I'm seeing is not so much on fabric areas as on hard cold surfaces. Even the windows had some. Most of the cushions and bedding have been removed. I think the moisture is just condensing out on those surfaces. The only vent I can open at all is the fantastic fan since it's in a Maxx-Air unit. The air here just becomes liquified, and we also have high winds. I can't crack any windows. 70-80 mph is common and a few weeks ago we hit over 110 before the power went down and shut off the wind meter. Keeping anything dry without a solid heat source is a challenge.
Old 03-24-2012, 07:25 PM   #6
You may find that running a small dehumidifier would help, if you can rig a way to send the water out through a drain hose. Helps on our boat.
Circulating fresh, non-humid air, is the key. The moisture has to go somewhere.
In the trailer, we crack the two vents just a little, run the fan on a thermostat, and that's enough in Florida during the non-camping months, if I remove the humidity holding textiles and paper.
Sherry
Old 03-25-2012, 04:22 PM   #7
Trailer: 2014 Escape 21
Virginia
For clean up I use Mold Control. Not much odor and no bleach issues.
Shop 32 Oz. Mold Control Spray at Lowes.com=
Eddie
Old 03-26-2012, 07:31 PM   #8
Most of the time I have kept the overhead vent cracked open a smidgen AND the kitchen window cracked open. Apparently it allows the air to move a little easier by convection. Never any mold or condensation inside. Plenty of "green slime" outside, however (not to be confused with the "pink slime" they are now taking out of our food. I'm sure I'll miss it.)
Old 03-26-2012, 10:50 PM   #9
I use this type 100 W heater with fan device, very safe. West Marine has a similar one but more expensive.
RV Accessory Store - RV TOY STORE - 1-800-334-5533
George.
Old 03-26-2012, 11:51 PM   #10
Roy in TO's Avatar
Concrobium
Concrobium Mold Control Removes, Eliminates and Prevents Mold and Mould at Home | Concrobium Mold Control
Old 03-28-2012, 06:25 AM   #11
Trailer: scamp 13
go to your local marina. this is a problem boaters face all the time. thay havr bags , or boxes of disicant that keep the moisture absorbed so no mold mildew problems.
Preventing Battery Drain in Your Tow! Karen L. Problem Solving | Owners Helping Owners 6 09-14-2009 03:02 AM
Mold on Fiberglass Alan P. Care and Feeding of Molded Fiberglass Trailers 16 08-15-2008 09:25 PM
Removing MOLD Kevin K Problem Solving | Owners Helping Owners 12 10-17-2007 10:43 AM
preventing door dingies PatandBob Problem Solving | Owners Helping Owners 3 09-13-2007 08:56 PM
Fuzzy mold Cheryl C Problem Solving | Owners Helping Owners 2 04-30-2007 05:39 PM
