Propane heaters - Fiberglass RV
Old 05-18-2009, 01:56 PM   #1
Trailer: Surfside
Hi all,
spent the weekend in sub zero temps (snow and freezing rain over night) and used a ProCat to keep the Surf Side toasty. Has anyone out there connect a ProCat to a 20lb tank? Alternately, has anyone used their 20lb tank to refill the smaller green disposable bottles?
Thanks
Jason, M is offline   Reply With Quote
Old 05-18-2009, 03:59 PM   #2
Trailer: 1970 Campster
Hi all,
Thanks
It would be best to contact Coleman directly to see if it is safe to connect your ProCat to your 20lb tank. The smaller green cylinder tanks used with portable propane devices are pressurized differently and, although someone here might actually hook their ProCat up to their 20 lb tank, it does not necessarily make doing so a safe venture. Coleman knows what's safest.
There are adapters that are used to refill small propane cylinders but there appears to be some controversy regarding the legality of doing so in various states. You might use the search engine to locate previous threads on this topic.
Lisa H. is offline   Reply With Quote
Old 05-18-2009, 07:42 PM   #3
Propane is propane and has no idea what size container it is in. They all have the same pressure when at the same temp.
Bill K
Old 05-19-2009, 10:59 PM   #4
Pete Dumbleton's Avatar
Not exactly true in practical applications-- The propane devices designed for attachment to one-lb cylinders have internal regulators, whereas the other devices rely on the regulator on the tank, so there ARE matching problems. There are also solutions.
propane
Catalytic Heaters Art Davis Problem Solving | Owners Helping Owners 56 04-23-2023 06:56 PM
Be careful with heaters jdtrotter General Chat 7 05-31-2006 06:56 PM
portable shower heaters Legacy Posts Modifications, Alterations and Updates 9 06-09-2003 08:30 AM
Catalytic Heaters Art Davis General Chat 0 01-01-1970 12:00 AM
Catalitic Heaters General Chat 0 01-01-1970 12:00 AM
