Propane Regulator Installation - Scamp Style - Page 4 - Fiberglass RV
Old 10-28-2017, 03:59 PM   #61
Raz
Raz's Avatar
Originally Posted by gordon2 View Post
BTW, is the only difference between the MEGR-291 and the MEGR-298 the direction of the vent? And then there is the question of the high capacity versions (with H appended to model number) or not.
I think you are correct, the 291 is intended for vertical mounting with the vent down where the 298 is designed for horizontal mounting with the vent down. As far as capacity the way I read it the high capacity I'd intended for large trailers with large appliances. Same pressure but higher gas flow.
I had an Amazon order ready to go in so I order another 291. When it gets here I'll install it and check the pressure. If the pressure is off back it goes.
Old 10-29-2017, 08:51 AM   #62
Paul O.'s Avatar
Originally Posted by Raz View Post
...Since the regulator was new I decided to check the pressure. This morning I built a manometer and connected it to the gas line. I expected to see 11"wc. I opened the gas and the water blew out the open end of the tube. ...
Nice job on the manometer, Raz. Only one comment - is the bottom loop longer than the straight, vertical? (Hard to judge from the pic.)
Old 10-29-2017, 09:18 AM   #63
Raz
Raz's Avatar
Good point. Bottom loop =10 1/2". Vertical =9" which equals 18"wc. It occurred to me to check as I was tightening the wire ties.
propane, scamp
Question about propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 13 02-14-2010 03:29 PM
Help needed for Campster lock and propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 11 06-09-2009 06:44 AM
Propane regulator Kevin K Problem Solving | Owners Helping Owners 9 04-24-2008 05:08 PM
Propane Regulator Replacement Don Nicodemo Problem Solving | Owners Helping Owners 2 08-06-2006 05:34 PM
