Propane Tank Cover suggestions please - Fiberglass RV
Old 10-16-2010, 03:30 PM   #1
Karalyn's Avatar
Trailer: Eggless for now but looking. currently own Amerilite 21 ft
I bought a nice hard covered one at Camping World and it will not fit the Scamp due to where the gas lines are placed. Grrrrrrr!
I have a brand new Propane tank cover that I can not use
Are there any Scamp owners out there with a propane cover over their tanks, and if so how did you fit them over those tanks? Thanks.
Old 10-16-2010, 03:39 PM   #2
Trailer: 1999 Scamp 16 ft ('The Pod')
Karalyn,
We recently bought a Camco tank cover from RV Parts Outlet for our 1999 Scamp 16' and it fits perfectly: RV PARTS OUTLET I don't know what brand Camping World sells, but we have not been able to use their covers in the past, and got really tired of replacing the flimsy vinyl zippered covers.
Vivian is offline   Reply With Quote
Old 10-16-2010, 05:41 PM   #3
Karalyn's Avatar
Originally Posted by Vivian View Post
Karalyn,
My tank cover looks exactly like yours Vivian. Thanks for your reply. My propane hose from the tanks to the camper is in the way of sliding the cover over those tanks. The only thing I can think of to do is to cut part of the tank cover off to make room for the hose. Thinking that could cause the tank cover to be really losse and possibly blow away going down the road.
Those flimsy vinyl zippered covers are only good for one season. Not worth it.
Anyone else have an opinion?
Old 10-16-2010, 08:15 PM   #4
Trailer: 1980 Burro
Could you put on a longer hose so that it would flex out of the way and come out the bottom?
Andy B is offline   Reply With Quote
Old 10-16-2010, 09:41 PM   #5
Trailer: Fiber Stream
Cool
This is what my hose does, it is long enough to go down through the gap in the bottom between the tank shelf and the generic Camco hard cover, which I modified to better fit the short 20lb tanks by cutting the bottom 1/3 off of the cover.
7-pin cable to left, flex gas line to right; next to center rail
ID:	31767 Click image for larger version
Look for nut at center of top of cover (with flamingo leg inserted into hollow drilled into all-thread)
I also use the long piece of all-thread that the pressure regulator and the top tank clamp are attached to... mine is long enough to protrude through a small hole I cut in the top of the cover, where a washer and 3/4" nut hold the tank cover securely in place.
Old 10-17-2010, 03:28 AM   #6
I have a Scamp with twin tanks and the hard cover.
I just went to a barbecue/repair store and had them make a longer hose for me.
I also bought longer pigtail hoses so I could put a twist in and make them fit.
Bill K
Old 10-18-2010, 12:24 PM   #7
DonDeutsch's Avatar
It look slike the fiberstream is afraid to touch the ground! You must take excellent care of it.
DonDeutsch is offline   Reply With Quote
Old 10-19-2010, 01:51 AM   #8
Trailer: Uhaul CT-13
Ohio
Do they make those plastic clamshell covers for single 20 lb tanks?
Panoz77 is offline   Reply With Quote
Old 10-19-2010, 06:02 AM   #9
Not in the catalog I have, just doubles. (
Bill K
Old 10-19-2010, 09:13 AM   #10
Question
I haven't seen a hard plastic cover for single tanks, while they do make soft vinyl covers, that don't seem to last long or close up properly.
I always thought a round trash receptacle of the correct diameter might be inverted and re-purposed as a cover...
Old 10-20-2010, 03:02 PM   #11
Robert Johans's Avatar
Trailer: Nest Caravans
Originally Posted by Frederick L. Simson View Post
:I always thought a round trash receptacle of the correct diameter might be inverted and re-purposed as a cover...
I like that kind of thinking!
Old 10-26-2010, 08:22 PM   #12
Karalyn's Avatar
I ordered the vinyl ones from Amazon. When they wear out hopefully I will remember the garbage can idea.
Thanks for your help everyone. Maybe next summer I will take the Scamp in to have the propane line extended as it should have been in the first place.
THANKS EVERYONE
Old 10-26-2010, 09:20 PM   #13
Gina D.'s Avatar
West Coast USA
I did just that for the single on my 13...sort of. It was actually a scale in a bucket that I have not been able to find since. Its called a Mugadot. I don't think they are made anymore.
As a scale it stunk, but it sure was easy to use! Simply drop the tank down into the secured "Bucket", bungie down and be done with it.
Old 10-31-2010, 09:12 PM   #14
Karalyn's Avatar
Well the single propane covers I ordered from Amazon did not fit either. I give up for now. I miss my Casita more with each thing I try to spruce up with this Scamp. Next summer I will have the line redone so I can use the hard cover like I had on the Casita.
WANTED: Lil Bigfoot propane tank/ battey cover Mike Whitney Classified Archives 0 07-21-2009 10:56 AM
PROPANE TANK JIM DUNNE Problem Solving | Owners Helping Owners 5 05-17-2009 07:19 PM
Stove cover suggestions? Roger Harshaw Problem Solving | Owners Helping Owners 3 04-21-2009 05:39 PM
Suggestions Needed: 5th wheel hitch cover Gail Shook Problem Solving | Owners Helping Owners 2 07-07-2006 09:13 AM
Old Propane Tank Cover playared Classified Archives 0 01-21-2006 08:24 AM
» Trailer Showcase
Mel
Tyler W.
Boler
BrynTara
