Putting Together a Tool Kit - Page 3 - Fiberglass RV
Old 05-02-2007, 04:49 AM   #29
Trailer: Boler 13 ft / 31 ft Holiday Rambler
Maine
You can take a 3/8 drive ratchet and generate enough force with a foot and half ot two feet piece of pipe over your ratchet to loosen even the toughest lug nuts or springe bolts or what ever. With a 1/2 inch drive set you can keep the trailer ball tight with the right socket.
Garry, I did use this cheater bar idea once while working on a 71 Jeep spring shackle and bent the head of the 3/8 breaker bar.
I just took off some nasty lugs off of a 82 plow truck of mine with a 4 way and bent the shaft but didn't round any nuts over so I will opt for this.
I never even concidered the ball loosening up in fact when I want to change sizes I need to go to a garage and have an impact wrench put to them.
Gerry
Old 05-02-2007, 10:15 PM   #30
Joy A's Avatar
I carry just about everything mentioned above but I also carry fuses for both the Scamp and Jeep. I didn't see them listed but I may have missed them. I also carry a 12Volt impact wrench that has sockets which fit both the lugs on the Jeep and Scamp.
I carry a AAA card and Visa however after my first and only call to AAA for a flat tire, I'll get my impact wrench out, change the tire and be on my way. I say this because it took nearly 2 hours for the tow truck to arrive which was at one point almost across the street from me doing nothing. With the impact wrench it only takes minutes to change a tire.
I carry a key hole saw which I purchased while in Coos Bay several years ago. I had decided that I wanted to take the round electric off the Scamp and replace it with a square locking door and also added a cable jack to the outside of my Scamp. I did this in my spare time while squatting at The Mill Casino prior to one of the Oregon Gatherings. Hey, I get bored easy and need something to do. I've kept the key hole saw in the Scamp as you never know I might decide to change something else one day.
Another thing I carry is one of those roller things that applies the spline to the screen door. I've noticed on occasion that the spline works it way out of the groove.
I have a box with all sorts of nuts, bolts, screws, cable connections, electric splicing connectors etc. This box gathers all sorts of things that I might purchase while on a trip. Once or twice a year I go through it and take things out that I think may not need.
Oh, and don't forget some lengths of nylon cord. I had to tie my solar panel down because of the wind at Joshua Trees. It'll come in handy for other things at times.
In my tool kit is a Water Thief for faucets without threads. I also have a half dozen or so handles that fit the various faucets. I can open just about any faucet with one of these handles without damaging the faucet with a wrench.
I can show you any of these when I see you.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 05-06-2007, 08:02 PM   #31
Matt O'Bryan's Avatar
Trailer: Eco 12 ft
Keep in mind, we have ALOT more cargo capacity then the average Egger, but here's what goes with us.
Repair Tools:
22 piece SAE/Metric combination wrench set.
1/4 and 1/2" ratchets, 1/2" breaker bar.
aprox 50 sockets, SAE and metric.
20 piece screwdriver bit set, doubles as my hex and torx keys, I only use them to fix other poeples rigs.
#1,#2,#4 phillips.
3 flat screwdrivers, one very large for double duty as a pry bar.
5 piece punch/chisel set
12" hacksaw frame and several blades, including some wood blades (doubles as a camp saw.)
sabre grip for the saw blades
3 vice grips
5lb single jack sledge
36" crowbar.
self igniting plumbers torch
several sticks of brazing rod, along with some 1/8th" 7018 welding rod.
large flat, meduim sized half round, and small round files.
Digital Multimeter, will double as the battery gauge for the trailer when we get that far.
crimp on electrical connectors, roll of solder, old style soldering iron.
10" and 18" cresent wrenches
12" channel locks
Large 4way wrench.
Rivet gun
needlenose and slip joint pliers
wood splitting wedge, useful for all sorts of stuff.
Expendables:
JB weld- original style
Gorilla glue
Duct tape
teflon tape
2 20' rolls of eletrical wire, 14g and 10g.
Zip ties
roll of baling wire.
random assortment of nuts/bolts/screws
Rubber cement, tire patches and plugs.
pop rivets
Misc:
Cordless LED trouble light.
US Army Entrenchment Tool
small tarp
2 20' 3/8ths log chain, 20' nylon strap
large jumper cables, plus one smaller pair, it makes on the spot welding easier.
Welding goggles
MAPP cylinder
random rigging gear.
Depending on the tug we are using at the moment, also ad a 12v air compressor and a heavy duty come-along.
Thats what comes to mind at the moment, though I know I'm missing some stuff.
Matt O'Bryan is offline   Reply With Quote
Old 05-07-2007, 06:16 AM   #32
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
Gerry,
That is why years ago I put a couple of cheater bars in the tug. They are pieces of steel EMT electrical conduit, big enough to go over the ratchet handle and increase leverage.
Garo
Gary, I have several 3/8" drive sets and only one 1/2" socket set that does duty in my garage. I have four vehicles, however, and three of the four are equipped to do towing duty. Each of them has a basic tool kit in it with a good quality (that's important) 4-way wrench and bottle jack in them. My Tundra has a tool box in the bed and it carries the full gamut of tools because I use it as my maintenance truck for my apartments. If you rotate your tires regularly, maintain your studs and wheel nuts, and don't let the tire shop carelessly re-install them with an impact wrench, the 4-way works just fine and will do all of your lug nuts on anything you tow as well. They're also significantly cheaper than buying another 1/2 drive socket set.
Roger
Old 05-07-2007, 06:25 AM   #33
Roger H's Avatar
Iowa
<Moderator's Note>
For all you acorn nut affectionados, I have split the rivet/acorn nut posts off into their own discussion thread here.
Roger
Putting a new license plate on a Scamp Monica M General Chat 6 05-27-2009 10:28 AM
Putting a Basement in a Scamp Gary Carvajal Modifications, Alterations and Updates 11 09-24-2008 07:09 AM
Putting money into a trailer... Todd Sleeman General Chat 4 05-30-2008 06:12 PM
LP Gas Troubleshooting Tool Pete Dumbleton Problem Solving | Owners Helping Owners 7 04-27-2007 04:51 PM
Putting the truck on a diet Legacy Posts Problem Solving | Owners Helping Owners 6 05-08-2003 07:59 PM
