question about interior lights 1980 trillium 1300 - Fiberglass RV
Old 07-06-2015, 03:35 PM   #1
Trailer: 1980 Trillium 1300
last week we were camping and suddenly the interior lights stopped working, the plugs work, the running lights for the exterior work but the lights inside stopped. There is no obvious damage but the light above the stove/sink flickered often since we bought the trailer 2 years ago.
Any insight on rewiring the lights? The plugs and other areas seem to have been upgraded over the years but the lights seem to be original but in great shape - well other than not working.
wolfie the trailer is offline   Reply With Quote
Old 07-06-2015, 05:31 PM   #2
David Tilston's Avatar
There are a couple of fuses in the road side of the gaucho, where the wire that goes to the tow vehicle enter the trailer. Check there for a blown fuse.
The flickering light might be an intermittent short. The fuse blowing might have prevented a fire. I have found that the wires on an older trailer can corrode with time, even under the insulation at either end. Get some replacement wire for that light. Try to maintain the same colour code. Tie the new wire to the old wire and use the old wire to pull the new wire to the end of the old wire. Then connect the replacement wire at either end. Don't forget to remove the old wire completely.
Old 07-06-2015, 06:34 PM   #3
where you plugged into power at the time? Did the light flicker only when plugged in or did it when off the grid as well. An early warning sign your converter may be on its last legs is lights doing a tiny flickering when running off power.
Old 07-06-2015, 06:48 PM   #4
it is one light that flickers a bit, none of the other lights do. And then all the lights went out. We were plugged in at the time.
Old 07-06-2015, 06:48 PM   #5
what is a gaucho?
Old 07-07-2015, 09:10 AM   #6
A gaucho is the front couch that turns into a bunk bed.
Old 07-07-2015, 11:46 AM   #7
thank you
light, lights, trillium
NFLD (Canada) - 1980 - Trillium 1300 Front Dinette - $4500 David Tilston Referrals: Molded Fiberglass Trailers 4 04-11-2016 03:21 PM
QC | $5500 MONTREAL QUEBEC Trillium 1980 model 1300 Refait a neuf !!! je.bedard For Sale: Molded Fiberglass Travel Trailers 20 04-07-2016 03:18 PM
ON | SOLD: 1980 Trillium 1300 for sale in Ontario $5000 Tonydd Classified Archives 0 09-01-2013 12:17 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 09:10 AM
CANADA - 1980 - Trillium 1300 - Factory Front Dinette - $3500 David Tilston Referrals: Molded Fiberglass Trailers 2 09-15-2012 03:55 PM
