Question re Bigfoot Weight - Page 5 - Fiberglass RV
Old 03-21-2003, 07:36 PM   #57
Kitty's Bigfoot lead
Way to go Kitty! Welcome to Bigfoot country! Anxious to know what type of floor plan you have (same as 15B17CB or the 15B17G as shown in the Bigfoot website)? My '84 has the 15B17G plan with Gaucho. Mike T., mine has a fridge (you were wondering if the "Gaucho" came with a fridge?). I'm sure Kitty's Bigfoot will to.
Old 03-21-2003, 08:18 PM   #58
No *zap*
Bought an adaptor that went from male blade fitting to flat four fitting. Fit together great! Unfortunately, it did not make the lights work. All I could get were tail lights. Using two flat four connectors, I stripped the wires and messed around with them, but the best connection I could get was tail lights and brakes. Darn! We'll try again tomorrow and bring it home, even if we can't get the turn signals working.
I am breaking out one of my last bottles of Canadian cider tonight.
Kitty :chin
Old 03-22-2003, 08:04 AM   #59
Trailer wiring
Kitty- what are you using for a tow vehicle- what type of taillights do you have? separate brake and signal or combined?
On my trailer I had to re-connect the tailight wiring so It would work with my van--- the previous owner had an import with separate stop/ turn lamps and I had to make a change at the taillights
Old 03-22-2003, 09:09 AM   #60
Candles in the wind?
Joe,
I'm using a Previa which has never towed anything before. Uhaul hitch, installed a couple weeks ago. When I was just stuffing raw wires from my four flat into the 6 (7?) blade female connection on the trailer, I got brakes, signals and tails all showing-- just not at once. All I get is tails with the adaptor.
Sure is lucky I find this kinda thing entertaining...
Kitty :wave
Old 03-22-2003, 10:42 AM   #61
Previa wireing
Kitty
Friends of ours had a Previa and they needed some little gadget wired into the van to make the trailer lights work properly.
Nancy
Old 03-22-2003, 01:01 PM   #62
Any vehicle with separate lights for turn and brake (usually turn is yellow, a la Euro style) has TWO wires that need to come together as one wire for the trailer (turn and brake are on one filament of the bulb), but need to not interfere with each other (the brake lights on your car will be flashing when you signal for a turn and vice versa).
They now sell a variety of wiring harnesses at XMarts and auto parts stores made for modern cars to plug right into the car's harness and produce the right stuf for Flat4/Bargman7/Round6 or what have you. These gizmos have the appropriate blocking diodes built right in.
In the event there is no pre-manf gizmo for your particular vehicle (in another life I needed one for a '93 Saturn), and you can't find a generic gizmo to wire in yourself, head on down to a *knowledgeable* UHaul shop and buy one there or have them install it.
Kitty, take it back and ask them to show you the diode block that needs to be there -- either they didn't put it in or the guy didn't wire it right -- might help to tell them that a friendly policeman gave you a warning and wondered where you ever had such shoddy work done...
Pete (aka Deppity Dawg or R.E.D. Jaquette for a brief moment) and Rats
Old 03-22-2003, 02:52 PM   #63
Home at last!
Good idea, Pete. We got the little beuty home without benefit of lights. I'm going to check the bulbs to make sure I didn't fry any of them, then I will go talk to the uhaul guys.
It looks like driving in 5th gear is a thing of the past, but the Previa handled our *very* steep driveway with no problem. Husband, older daughter & I got the trailer disconnected and pivoted around in place without too much difficulty, though I will be looking for a tongue wheelfor future use.
Looking forward to testing systems later.
Thanks for all the info.
Kitty
Old 03-22-2003, 07:15 PM   #64
wheelie
You might find that stowed someplace in the trailer. Perhaps under the rear Gaucho (bulkhead). BF shipped with a tounge wheel.
Old 03-22-2003, 08:41 PM   #65
Wheels
I'll make a more thorough search tomorrow and maybe the wheel will turn up. I found four lightweight jackstands and put them to work. Found a bunch of cables for a tv, that will join others of their kind in my electronic grab bag in the garage. Did not find a pigtail for the electric. Hope to get one tomorrow so I can have lights.
I smell a little propane, but a thorough soapy spray down did not show bubbles.
I am not liking the look of a patch on the roof that holds some kind of aftermarket vent. Looks like they dumped some kind of glass putty on it. Yuck.
Having fun.
Kitty
Old 03-23-2003, 11:41 AM   #66
wiring adapter
You should find a gadget something like this on your Previa, if they wired it right.
<img src=http://www.fiberglassrv.com/board/uploads/3e7dfb531c2e5R74209.jpg/>
Reese part R74209
This converts the separate brake and tail light to one wire.
However if your new trailer has electric brakes they won't work until you put in a brake controller, but your running lights and brake/taillights will.
The 7 pin connector has wires for the following-
pin 1-ground (negative)(white wire on tailer harness)
pin 2-electric brakes ( blue on trailer harness)
pin 3-running lights and tail-lights (green on trailer harness):sunny
pin 4-battery charge (positive from car) (black on trailer harness)
pin 5-L.H.stop/turn (red wire on trailer harness):red
pin 6-R.H. stop/turn (brown on trailer harness):red
pin 7-auxilliary ground or extra circuit(usually spare)(yellow on trailer harness)( round pin in centre)
this is assuming the previous owner didn't make any changes
Old 03-23-2003, 12:09 PM   #67
Great!
Joe,
Thanks for the info! I'm off to see if I can gather up parts locally. There is no critter on my Previa like that.
Who knew?
Kitty :wave
Old 03-23-2003, 05:45 PM   #68
Orginally posted by Kitty McKoon-Hennick
I smell a little propane, but a thorough soapy spray down did not show bubbles. *
Kitty
Kitty, check the propane tanks to make sure they are "off" then check the stove and / or oven to make sure the knobs are not in "light" or "pilot" [oven] The furnace is most likely OK as they don't get used much and the fridge if you have one may have a propane option and the water heater could be on "pilot". It's unlikely a leak developed immediately after you bought it.
Mike
Old 03-23-2003, 09:37 PM   #69
Mike,
One of the tanks was slightly open. I didn't mess with any of the gas appliances today, but found that the fridge works great on AC and that my old RV battery is still capable of taking a charge, so I'll install it tomorrow.
All,
This is a remarkably clean vehicle. The plywood under all the seats looks brand new.
There is a very gunky attempt at a patch around the vent over the bathroom, though. I'll need to scrape it, pull off the vent and reglass it when the weather gets warmer.
What are the little square-drive screws screwed into? It looks as though someone smeared silicon caulk around every possible fitting, but didn't pull anything off and reseat it. I'm inclined to start unscrewing and rebed things properly. There is no evidence any leaks ever happened inside, though.
Kitty
Old 03-25-2003, 03:13 PM   #70
Kitty, one thing to remember about trailer light connections is that the top three reasons for failure are, in order, :
1. Bad grounding
2. Bad grounding
3. Bad grounding
Very often, you will get the wierdest symptoms because one set of filaments is actually finding ground thru another set of filaments, causing stuf like your taillights dim as the turn signal cycles...
Pete and Rats
bigfoot, weighing, weight
Bigfoot 17' weight ?? Yvon Chayer General Chat 2 06-27-2009 05:35 PM
tongue weight, dumb question Ed Calkins Problem Solving | Owners Helping Owners 36 08-20-2007 03:03 PM
A question for 21' Bigfoot owners Charles Richerson General Chat 3 05-18-2007 09:12 AM
Bigfoot 17.5 empty weight Dale H Problem Solving | Owners Helping Owners 7 08-06-2006 05:48 PM
Weight Distributor/Bigfoot Legacy Posts Modifications, Alterations and Updates 1 02-25-2003 11:32 PM
