Questions on the 16' Scamp - Fiberglass RV
Old 05-02-2008, 07:37 PM   #1
Hello,
I'm looking at some of the larger fiberglass campers an have questions on the Scamp.
1. The brochure lists the R rating as R15. How does Scamp insulate to get this number?
2. I don't feel the 13" tire that Scamp lists on the trailer is adequate on gravel back roads and a trip to Alaska in 2009. Will a 15" load range D fit the wheel well and axel as after market add on.
Thanks
William Lee is offline   Reply With Quote
Old 05-02-2008, 07:55 PM   #2
Pete Dumbleton's Avatar
Scamp gets the insulation number from the Reflectix published numbers (and the other stuf they use also), but it really depends on the orientation. It's a double-foil with bubble-wrap in between, and then the marine carpet, aka rat fur, is installed on the inside of it. So, you have fiberglass, Reflectix and carpet.
Larger wheels might not fit; even if they did, your 'bounce' room would be shortened. If you want extra room for larger wheels, have a spacer welded between axle bracket and frame.
BTW, I dragged my 91S13 all over BC, YT, AK and some of NWT with 13" wheels and had no problems, but on the rougher roads, I lowered the tire pressures on truck and trailer to make them less susceptible to rock damage and I also slowed down. I didn't go on either the Dalton or Dempster Highways.
Questions on the Scamp 5th Wheel Tony L General Chat 11 10-05-2008 07:04 PM
Questions about Scamp 5th wheel Frank G. Care and Feeding of Molded Fiberglass Trailers 17 03-07-2007 11:35 PM
13' Scamp Questions padowd General Chat 8 09-05-2006 12:05 PM
Questions on new 16' Scamp yakimovich Problem Solving | Owners Helping Owners 8 07-05-2006 06:53 AM
Got myself a 77 Scamp, Got questions, too! Legacy Posts Care and Feeding of Molded Fiberglass Trailers 21 12-21-2002 02:45 PM
