Queston How do you hook up an auxillary battery to my 1976 Trillium - Fiberglass RV
Old 06-26-2010, 08:51 PM   #1
Trailer: Trillium 13 ft
The trailer harness has a black wire designated as battery, yellow wire as auxiliary per wiring print out of trailer connector. Does the black wire go to the battery positive and the ground side of the battery go to the frame. What is the yellow wire for? The power converter has a three way switch with the positions marked BAtt, off, & trans.
Thanks for your help.
Randy
Randy Howarth is offline   Reply With Quote
Old 06-26-2010, 10:01 PM   #2
Trailer: Fiber Stream
Talking
Does the black wire go to the battery positive and the ground side of the battery go to the frame. [b]What is the yellow wire for?
Yes, the Black wire goes to the Battery Positive. Since I'm a Belt-AND-Suspenders sort of guy, I connected the Negative Battery terminal to the trailer frame PLUS the White wire in the trailer connector.
The most common use for the Yellow wire is to activate [b]Back-up Lights on the trailer if you have them. Some factory harnesses are pre-wired this way on the tow-vehicle end of the connector.
Top Bulb = Yellow Wire
battery, trillium
1976 13' Trillium and 1980 Trillium 5500 18' Jenn Classified Archives 10 05-19-2010 02:36 PM
1976 13' Trillium for sale Tim Ryce Classified Archives 4 09-20-2009 04:20 AM
Battery hook up - Bigfoot Carol Crawley Problem Solving | Owners Helping Owners 10 07-24-2009 07:32 PM
1976 13ft Trillium Edie Classified Archives 0 08-06-2008 08:32 PM
BATTERY hook-up for 16' Scamp lenny247 Care and Feeding of Molded Fiberglass Trailers 2 03-25-2006 06:50 PM
