quick fix for leaks - Fiberglass RV
Old 12-26-2005, 09:04 PM   #1
Taylor Kissinger's Avatar
Trailer: 19 ft Scamp (Egg Salad Annie)
I went out to check " Egg Salad Annie" and OOOOO No a leak. The carpet just before the step up to the dinnette was wet. YUKkjppp4lvnnvnv''!!! Got to looking and found that I had just the right trailer level to cause the rain to run down and into the water heater access. By chance it ran down and found a way to run down the copper pipe into the area under the the sink , Then to the carpet. Well I first changed the angle of level by a bit that stopped it. The access has a cut out on its upper lip this allows water in. For now I went and got some Duct seal Putty and until it stops raining this will work. Duct seal is cheap and easy to use and remove We use it on the tugs I work on for just this kind of short time fix.
Glad I checked the trailer before I head to sea this week.
Have a Happy New Year.
Taylor the Sailor
Taylor Kissinger is offline   Reply With Quote
Old 12-28-2005, 09:09 PM   #2
Gina D.'s Avatar
West Coast USA
NOW you tell me
During a dry (Well, NOT raining) spell while in Portland, I grabbed a ladder and discovered the leak happening from my roof vent mounting. It was a couple screws with NO butyl tap under the outside lip!
I took the butyl tape and foil tape kindly given to me for just this purpose by one of our party goers in P Land and stuffed the leaky holes, remounted the rusted screws, covered the entire lip with butyl tape and covered THAT with foil tape.. 100% of the perimiter. No leak there anymore, it will get me home.
I did the same treatment around the front and rear windows on the inside, and just the foil tape outside.
My trailer looks like the Beverly Hillbillies wagon, but I am dry inside!
When I get home, I am going to check into your duck seal and keep that in the trailer. Sure wish I had it on the way up!
Old 12-29-2005, 12:30 AM   #3
NOW you tell me
Glad you found and stopped the leaks. Duct seal comes in a block it is similar to Butyl $2.50 at my local hardware store.
Good Luck Taylor
leaks, weatherproofing, window leaks
The Window to my Burro leaks Casey G Problem Solving | Owners Helping Owners 9 04-22-2011 07:07 PM
Fixing leaks Tom Byron Problem Solving | Owners Helping Owners 11 12-23-2009 10:27 AM
Fix for door window leaks DannyH Problem Solving | Owners Helping Owners 2 12-10-2009 08:26 PM
Gas Leaks Legacy Posts Problem Solving | Owners Helping Owners 2 07-26-2003 10:45 PM
Bathroom Plumbing Leaks Legacy Posts Plumbing | Systems and Fixtures 4 06-20-2003 09:56 PM
