Recharging battery and shore power - Fiberglass RV
Old 08-02-2015, 01:27 PM   #1
Ellpea in CA's Avatar
This is probably a silly question... but will your battery normally re-charge when you're plugged into shore power?
Ellpea in CA
1988 13.5' Lil Bigfoot
2002 Volvo V70 (turbocharged)
5 cylinders, 5 speed auto transmission
Ellpea in CA is offline   Reply With Quote
Old 08-02-2015, 02:27 PM   #2
You're right.
Old 08-02-2015, 02:27 PM   #3
That's a "Maybe" with your Lil Bigfoot.
When we bought ours, for some reason or another, a previous owner had wired in a separate battery charger to charge the coach battery. Most (but not all) converters also have a battery charging function. The easiest way to find out is to read your battery voltage when unplugged and then read it again when plugged in. It should jump from the mid to low 12 volts to about 14 volts. I think that there is also a switch on your power panel to switch from battery to plug in power.
We replaced the original stuff with a Progressive Dynamics PD-4045 power center with a built in smart charger.
Old 08-02-2015, 03:48 PM   #4
Ron has done that and the voltage did not change.
One thing neither of us know is whether we HAVE a converter. Isn't there usually a panel inside? I don't see one.
Ellpea in CA
Old 08-02-2015, 04:09 PM   #5
Carl Pa's Avatar
Do you check battery voltage while the battery is connected to trailer, While plugged in, or unplugged, ??? I just got a mutimeter and trying to figure everything out. Carl
Carl Pa is offline   Reply With Quote
Old 08-02-2015, 04:32 PM   #6
Converter
The Lil Bigfoot converter/power panel is usually in the lower section of the left bed/dinette seat, just aft of the sink counters. Look under that seat and see what's inside.
Old 08-06-2015, 07:53 PM   #7
Ellpea , I have been watching this thread, and others you have been involved in, and I have come to one conclusion.
It is not an insult to say that you do not know your trailer - it is something new to you and I can assure you that if I somehow became the owner of a Cessna Piper Cub, then I would be just as unfamiliar with the plane.
But the good news is that camping trailers are all more alike than different, just as small planes share many common features. Therefore, if I woke up tomorrow with good title to that Cessna, I would go to the local airport and find an owner (or three) of similar planes to walk me through the basic construction and operation (as a first step toward getting my pilot’s license).
I strongly suspect that your trailer does have a converter and it would charge the trailer’s battery if it was operating properly. But only an onsite inspection can confirm that. My best guess is that you have a converter that is not fully functional, but that is only a guess. And that’s the rub, dealing with this issue in the forum, with limited information and no actual inspection, means that we can only take uneducated guesses. The power systems in most trailers are not that different, although larger campers and motor homes have more stuff. If I could get a look in your trailer, I am sure I could help you figure it all out, and I am not even one of the more knowledgeable trailer owners.
So my suggestion is to network with one or more local camping trailer owners and have them over for a glass of wine, a pizza or similar enticement, and start a conversation about the trailer sitting in your driveway (after it gets back of course). There is no substitute for someone who knows just a little more than you taking a look at the actual hardware.
Best of luck and if you ever get this way I will be glad to have a look at your rig and offer my mostly uneducated two cents.
Old 08-06-2015, 08:10 PM   #8
Ellpea... Do you have more pics of the interior that you have posted somewhere? If you take some we can see, it will help immensely.
Old 08-06-2015, 10:33 PM   #9
No, additional pictures, but I can take and post some tomorrow. I'm guessing you're interested in the inside works? Under the bunks and where all the wiring is?
Thank you, Bob, I do appreciate your willingness to help.
Ellpea in CA
Old 08-06-2015, 10:39 PM   #10
snip
Gordon, It's probably very tiresome to see repeated questions from someone who barely understands the subject. Having local trailer acquaintances would be ideal and is certainly a goal. Thank you for your kind suggestions.
LP
Ellpea in CA
Old 08-07-2015, 05:23 AM   #11
Gordon, It's probably very tiresome ..
LP
I think a better adjective is unproductive but we do what we can with the inherent limitations of the online medium.
Old 08-07-2015, 02:14 PM   #12
unproductive
We used to admonish students that there was no such thing as a silly question, because if they had it, it was guaranteed that many of their colleagues had the same one. Perhaps I have been mistaken as to the purpose of this forum. Is there a better location where I and others with *unproductive* issues might flounder?
Ellpea in CA
Old 08-07-2015, 02:25 PM   #13
Gordon2 was trying to help you and offered good advice. If you have no clue, you can't ask intelligent questions and get a useful answer.
You need one-on-one instruction from somebody familiar with your trailer.
There are silly questions.
Old 08-07-2015, 02:43 PM   #14
Hang in there Ellpea, at least you are asking multiple questions about a rig you actually own. If need be I will PM you my private email address. But if you can post those interior pics it will help.
This is a place to learn. I too was a Teacher/Trainer/Instructional Designer (M.Ed.) and, so far I haven't seen you post any irrelevant questions.
BTW: I would be on the phone to Volvo North America in NJ wanting to know where my parts were. If they haven't gotten here within a week I'd question if they actually exist in the U.S. or if they are coming from Sweden (or China?)
battery
Shore power without battery? hobofoto Electrical | Charging, Systems, Solar and Generators 7 11-05-2013 12:01 PM
Battery recharging? Lfoxmont Modifications, Alterations and Updates 30 06-09-2013 01:17 PM
Battery Discharging While On Shore Power jimmied Electrical | Charging, Systems, Solar and Generators 17 11-21-2012 05:43 PM
Kipor Generator for recharging House Battery kevin61 Problem Solving | Owners Helping Owners 8 06-05-2008 05:04 AM
Battery Recharging - A Study Legacy Posts Problem Solving | Owners Helping Owners 9 05-08-2003 03:01 PM
