Removing bunk "bump" - Fiberglass RV
Old 05-06-2013, 06:09 AM   #1
Trailer: Burro 13'. 1982
Montana
Hi all! I'm a Burro owner who wants to know if anyone has removed that bump for bunk beds jutting out at the inside front of the camper? My cushions aren't fitting well when I'm setting up the area for regular seating. I have no plans to use the area for bunk beds. Thanks!
Lfoxmont is offline   Reply With Quote
Old 05-10-2013, 08:16 AM   #2
Pam Garlow's Avatar
Trailer: U-Haul 1985
I took the bunk bump out of my UHaul. It left some bare fiberglass that I covered with my backer cushions. Worked fine and so much more room on the seat
Old 05-10-2013, 11:39 AM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
As Pam said, you can take it off. The tradeoff is that the front wall is a little weaker, but strong enough for most uses.
Old 05-10-2013, 03:30 PM   #4
Montana
How did you take it off? Hack saw?
Old 05-10-2013, 03:56 PM   #5
Thomas G.'s Avatar
UHauls may be slightly different than our cousin Burros. How is your "hump" attached?
Old 05-10-2013, 04:19 PM   #6
Montana
I just checked...it's covered by rat fur but if I really pry apart the fur if kinda looks like the bump might be a piece of wood. Do you think it will really compromise the wall?
Old 05-10-2013, 04:28 PM   #7
Montana
Here's some pictures of the bump, etc.
Old 05-10-2013, 05:28 PM   #8
Thomas G.'s Avatar
It won't be as strong without it, but it will probably be just fine.
Old 05-13-2013, 07:43 PM   #9
Pam Garlow's Avatar
My 'bump' was a large molded piece of fiberglass that was glued and screwed onto the inner walls. These photos show the 'before' removal, and the 'after' removal. I've covered the raw fiberglass with a decorative cloth covered board.
Old 05-30-2013, 11:35 PM   #10
Montana
Well, that was interesting. My bump was a block of wood turned sideways. I got it off with a jigsaw then broke off the fiberglass that was sticking out with pliers. Took a while but it's done.
Old 05-31-2013, 05:55 AM   #11
That's because you have a Scamp and Linda was asking about a Burro. Two different kinds of trailer builds.
1984 Burro "Bunk House" Sleeps 5! Jon Munn Modifications, Alterations and Updates 6 07-18-2012 11:16 PM
Will 4" foam (instead of 3") work on Scamp top bunk? Ryan P R Problem Solving | Owners Helping Owners 5 07-14-2012 02:27 PM
Top Bunk Safety Net / Feature for 13" Camper Carl G Modifications, Alterations and Updates 7 03-29-2009 10:09 PM
SOLD 13ft Play-Mor II For Sale "The Brown Egg" Susan Tiller Classified Archives 3 01-13-2007 03:48 PM
