Removing the stove. - Fiberglass RV
Old 04-20-2011, 12:19 AM   #1
Trailer: '74 Trillium 1300
Removing the stove.
Anyone know how to remove the two burner from a '74 Trillium 13', for servicing?
Cheers
IanWR is offline   Reply With Quote
Old 04-20-2011, 08:48 AM   #2
honda03842's Avatar
Name: Norm and Ginny
It's usually pretty easy. Begin by shutting off the gas at the propane tank
I've never done it on a Trillium but have on four other rigs. Usually the top lifts up exposing the burners. This might require removing two screws or pressing a clip. Sometimes it is just a pressure fit and flips up.
Lifting the top may expose the gas line connection. We again make sure we have shut off the gas at the propane tank. When you disconnect the gas line there will still be some gas in the line that should quickly dissapate.
(If this does not expose the gas line connection, it will certainly be under neath the stove top and can be disconnected there.)
We than undo the gas line fitting, usually a copper line about 3/8" in diameter.
Their may be a couple more screws that hold the top in after you lift the burner cover.
Once we have disconnected the gas line and removed the stove we put a plug in the gas feed line to prevent any leakage should some one open the propane tank valve.
Hope this helps,
Norm
Old 04-20-2011, 08:33 PM   #3
It would be pretty easy if could find a screw or clip to remove the top!!
Cheers
Old 04-20-2011, 11:41 PM   #4
Trailer: 1974 Trillium 1300
Cheers
I just removed the stove in our 74 trillium. I will take a few photos in the next day or two to help you out.
bastiaad is offline   Reply With Quote
Old 04-21-2011, 09:06 AM   #5
Great!
Thanks
Old 04-21-2011, 02:56 PM   #6
Trailer: Trillium 13 ft
On my '80 Trillium, you remove the grates, three clips hold them down and you just bend them a little to remove. The top just lifts straight up. There are two posts on the under side of the top that "snap" into a mating hole in the stove base.
Brian Gibbon is offline   Reply With Quote
Old 04-21-2011, 04:57 PM   #7
Our stove - 1974 Trillium
Mine is just like Brian described. There are three layers: the top, the burner layer and the outter box. The burner grates held down with clips and two cabinet post-clip thingies hold the top down to the outer box. The layer beneath (the burner layer) is screwed into the outer metal box with four screws and then four more screws mount the outter box into the cabinet. See the pictures of it out of the trailer below. The gas line was a bit of a wiggle to push out of the box once it was undone.
I am planning on using Barkeepers friend to polish up the top and paint the inner layers with high heat Tremclad.
Good Luck!
Old 04-22-2011, 09:01 AM   #8
Thanks you so very much! I was worried about prying up the top layer and possibly bending it - I couldn't see or feel any sort of hold-down
Thanks again.
Removing old adhesive Vicki A. Problem Solving | Owners Helping Owners 6 02-17-2010 12:32 AM
removing a post ken spicer Forum Admin, News & Announcements 1 01-23-2010 05:15 PM
Removing silicone! Crystal, Huscroft Care and Feeding of Molded Fiberglass Trailers 30 07-28-2009 10:38 AM
Removing old caulking Legacy Posts Problem Solving | Owners Helping Owners 9 06-28-2003 08:28 AM
removing a post Rands E. General Chat 0 01-01-1970 12:00 AM
