Old 03-02-2012, 09:57 AM   #1
Trailer: Looking for a Trillium
Repairing cracks in green fiberglass
My husband and I are considering buying this Trillium (photo: Roulottes Trillium légère comme boler) but are slightly concerned about the crack in the fiberglass around the fridge, covered by duct tape in this photo. Can anyone tell me if this is easily fixed, or would there always be an ugly seam there? Since it is green fiberglass, I'm guessing it will be harder to disguise? Thanks in advance for your help!
MadgeW is offline   Reply With Quote
Old 03-02-2012, 10:08 AM   #2
Kevin K's Avatar
Trailer: 1999 17' Casita SD 2nd owner
Hopkins,Minnesota
Nice rig
Kevin K is online now   Reply With Quote
Old 03-02-2012, 12:21 PM   #3
P. Raz's Avatar
Vermont
Hi Madge and welcome to the forum. I am guessing that the refrigerator is newer than the trailer. When the original refrigerator dies there is no current replacement that fits in the hole so owners come up with some way to make a current model fit. Most folks build some sort of wooden frame to fill the gap and seal the new fridge to prevent exhaust entering the living space. Have to wonder why it is cracked? Also there appears to be duct tape by the upper cabinets? Why is that there? I am sure any crack in the gel coat can be repaired and color matched but I suspect it would be costly. Good luck, Raz
An after thought: I bet they cut the hole too large and had to duct tape some of the fiberglass back in to seal in the new fridge.
P. Raz is online now   Reply With Quote
Old 03-02-2012, 04:36 PM   #4
Trailer: U Hall VT
Smile
Welcome to FG, it is not that hard to fix either one of those just take a little time, but you might get a deal on it this way.
Roger Kimble is offline   Reply With Quote
Old 03-02-2012, 06:17 PM   #5
Trailer: 2008 13' Scamp
You're correct about the green color making it harder to disquise a repair.
Pros are quite good at doing it but they're also quite pricey.
Stores that sell fiberglassing supplies sell colored gel coats and it's possible to get one, perhaps even from the manufacturer, of the correct shade.
Repairing fiberglass chips etc. is covered in other posts but the bottom line is that it's possible to fill or repair the damaged surface and have it look pretty good. Sometimes, if care is taken to wet sand, wax, and buff you have to look pretty hard to see the repaired area.
Ron
Old 03-02-2012, 06:47 PM   #6
HI Madge, welcome to FiberglassRV we're glad you're here! What a repair boils down to, is what you're willing to accept. If the price is within your budget, are you willing to accept something less that perfect? If you think you will never look beyond a repair (of any kind) maybe it would be best to pass. Then too, when was the last time you saw a molded lightweight trailer for sale that was within your budget and (willing) driving distance. Remember, you are buying a CAMPER... not the Hope Diamond. Perhaps building a frame around the fridge to cover it's imperfection would work for you. If you're expecting something to look perfect... it may cost you more than you want to pay. YMMV
Double Yolk
1988 16' Scamp Deluxe
Old 03-03-2012, 06:48 AM   #7
Pam Garlow's Avatar
Trailer: U-Haul 1985
It does appear that they had to remove a section of the cabinet and then just 'taped' it back into place around the fridge. You can repair the seam to a smooth finish, eand then skin over the area around the fridge with a different finish or paint color that is complementary to your interior. Nice trailer. I like trilliums
Old 03-03-2012, 08:31 AM   #8
Trailer: 1977 13' Trillium
Louisiana
I like Donna's answer.
I don't know about where you live, but down here the paint store I use will color match and put it in a rattle-can (spray bomb, spray can). Fiberglassing is not hard to do and in my opinion, if you buy an older FGRV, you should learn aout it. You can save a LOTS of money doing it yourself.
On the other hand, you could frame it in with wood (that's what I "wood" do). You can stain the wood the same as your doors. It would look great - IMHO.
Nice Trillium! Go for it!
itlives is offline   Reply With Quote
Old 03-03-2012, 07:51 PM   #9
Gina D.'s Avatar
West Coast
I have been up on my own roof all day fiberglassing in cracks, holes and dumb boo boos from over the years.
Its not hard, it is a bit messy and most certainly time consuming. But.. IT"S NOT HARD. Like any project, it's all in the prep.
You can buy fiberglass resin and cloth if you want to go that way. All the resins have easy to follow instructions. You just need to make sure you can do it in an uninterrupted time. Once you start mixing it and working with it, you only have a few minutes per batch to work. No mixing , going to lunch and coming back later.
Old 03-04-2012, 04:57 AM   #10
Trailer: scamp 13
yup there you go!
old age, wisdom, and sneakiness, will beat youthfull enthusiasm every time.<_<
Old 03-04-2012, 07:33 AM   #11
Thomas G.'s Avatar
Trailer: UHaul CT13 TV: Escape Hybrid
SE Michigan
..........down here the paint store I use will color match and put it in a rattle-can (spray bomb, spray can). ..............
This is a great tip. What kind of a paint store is it - i.e. how would I find a similar one near me? (Auto paint, professional/ business store, big box???)
Thomas G. is online now   Reply With Quote
Old 03-04-2012, 07:41 AM   #12
Louisiana
I would just let my fingers do the walking. First call the local paint stores -not a big box. Then, if they can't help, call a hardware store. If someone says no, I always ask do they know who does what I'm looking for. I like the phone betterer than using my gas to find stuff.
In the south, the laws are still quite relaxed on paint products. Other parts of the country have quite a bit of "beauracratic (sp) intervention". So sad....
Old 03-04-2012, 09:29 AM   #13
Trim could B the answer.
Wood or metal
Old 03-04-2012, 03:16 PM   #14
Thanks everyone for your suggestions! I think the repair would bug me, as aesthetics are one of the reasons I like the Trilliums and Bolers, etc., but that's just me.
trillium
Repairing fiberglass chips? Greybeard Problem Solving -- Owners Helping Owners 8 10-29-2011 08:48 AM
Fiberglass cracks Janne Potter Problem Solving -- Owners Helping Owners 3 04-25-2011 02:53 PM
How do you fix Fiberglass cracks SharonNDean Problem Solving -- Owners Helping Owners 12 02-12-2008 08:46 PM
Cracks BAMA & Pachyderm Posse Care and Feeding of Molded Fiberglass Trailers 7 12-13-2005 03:57 PM
repairing cracks Legacy Posts Care and Feeding of Molded Fiberglass Trailers 30 02-27-2003 03:00 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
