Hi James! Good to see you again man!
And good tip on using the
Casita wooden sink cover and having it double as a small, post table.
I never thought of that (which is another reason I'm glad you're here!)
Note to other owners ... if your brand didn't come with a wooden sink topper .... it's really quite easy to make ... you cut two wooden boards ... one slightly smaller than the exact diameter of your sink ... and another piece of wood about a inch wider, all around ... glue or screw the two boards together ... and you have a nifty sink topper ... good for food prep, cutting or setting a coffee pot.
The small board portion sticks down into the sink ... and holds the topper in place while traveling.
James' tip is to fasten a female metal post holder thingie on the bottom ... and the sink cover can serve as a small table.
Just perfect for afternoon tea.
Thanks James!
