Replacement glass for side windows? - Fiberglass RV
Old 07-03-2013, 05:17 AM   #1
Trailer: Boler 1978
I have to replace a side window pane because it has a crack. Is it regular plate glass that I can get at the hardware store or is it automotive safety glass? if it is plate glass, any opinion as to replacing these with automotive safety glass?
Thanks,
Winfield456 is offline   Reply With Quote
Old 07-03-2013, 05:50 AM   #2
Trailer: 2014 Escape 21
Virginia
A local glass shop replaced one pane in a black radius frame Hehr window for me for $25 in about 30 min. It was a side rear Casita window about 16" x 16". The older windows are plate, if yours did not crumble it is not tempered. Mine was plate glass and I just replaced it with plate glass. Replacing with anything other than plate gets more expensive and takes more time.
Eddie
Old 07-03-2013, 07:41 AM   #3
Brian B-P's Avatar
My experience was just like Eddie's, and I agree with his assessment of the choices.
If you use one of the forum search tools and look for "tempered" you will find some previous discussions of this topic.
Old 07-03-2013, 08:04 AM   #4
Virginia
One note: The cracks in the Hehr black radius frame are mostly caused by people trying to lock the window when it is not slid to the fully shut position. When they pull the lock lever down/up the lock blade should fit into a groove in the frame. If the window is not fully closed the lock blade will flex the frame and crack the glass, usually in the center of the window.
Eddie
Old 07-03-2013, 07:45 PM   #5
I replaced the door window glass in my Scamp with laminate... the same stuff they use in windshields. Typically "tempered" is used elsewhere. But I figured if laminate kept a windshield together when a head or other body part hit it, it was good enough for my door. Tempered vs laminate price wise... laminate wins hands down. YMMV
windows
Looking for ideas on new side windows voytek Modifications, Alterations and Updates 3 09-11-2013 08:28 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
For Sale: Uhaul side windows uhaulin Parts: Buy | Sell | Trade 10 06-20-2013 11:34 AM
LiteHouse side windows. Davie B Problem Solving | Owners Helping Owners 6 03-15-2012 06:13 PM
scamp side windows... nancy and steve Problem Solving | Owners Helping Owners 0 05-28-2011 10:00 AM
