Replacing a Converter - Fiberglass RV
Old 08-21-2008, 04:38 PM   #1
DaveK's Avatar
Trailer: 1994 Lil Bigfoot and 1967 Traveleze Royal Traveler
Even though I have a brand-new-to-me project trailer, I still have to keep up the Littlefoot. At Bandon the consensus from smart people was that my JVC am/fm/cd unit's woes are caused by my elderly converter, a Magnatek 15 amp unit that certainly came with the trailer.
I'm looking, and the replacement options that don't actually involve a mortgage seem to be these:
http://www.campingworld.com/shopping/item/...r-charger/27964
http://www.rvpartsoutlet.com/product_info....roducts_id=8805
http://www.rvpartsoutlet.com/product_info....roducts_id=6007
All are a good bit more amperage than I have now, and I'm darned if I can tell the difference between the two 45 amp units except price.
So I'm unclear which of these might suit me best. I'm not planning to increase the Littlefoot's draw, but I'm not finding an easy/cheap source of 15amp units, and if 30/45 is cheaper, I can go there.
But then, how much is involved in getting the trailer to accept a higher-amperage converter? Rewiring? Installing a circuit panel? Replacing fixtures? I'm no electrical whiz, but I can follow instructions and read a multi-meter.
Thanks.
Dave
DaveK is offline   Reply With Quote
Old 08-21-2008, 05:14 PM   #2
Lainey's Avatar
Trailer: 1989 Bigfoot 17 ft and 1989 Li'l Bigfoot 13 ft
I have the perfect solution to your dilemma - you don't have to maintain the Littlefoot
...sell it - to me!!
Lainey is offline   Reply With Quote
Old 08-21-2008, 05:47 PM   #3
Talking
One is a 9100 series unit
Optional Charge Wizard [b](sold separately)
The other is a 9200 series unit
Inteli-Power 9200 series converters with [b]built-in Charge Wizard
The 9100 units are not available here in Southern California, but the separate Charge Wizards are.
Old 08-21-2008, 06:28 PM   #4
Suz
Suz's Avatar
I purchased my PD 9145 w/charge wizard several years ago from Best Converter. At the time, I believe the company was smaller than it is now, but the prices always seem to be better than anyone elses. Not sure how they compare today, but they still look good to me. They also were extremely helpful on the phone and they had very good instructions on how to remove the old one and install this one in its place. In fact, they were so good, I did mine myself.
I have always said that the new PD 9145 converter was one of the best upgrades I ever did. After I installed that, I then added an AGM battery. That was several years ago and they are both still just humming along.
Suz is offline   Reply With Quote
Old 08-21-2008, 07:05 PM   #5
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
I bought my converter through Best Converter also. I would recommend you call and talk to Randy (the technician) and see what options he thinks you need. He steered me towards a WFCO 8725 and it was the perfect fit for my Trillium
Old 08-21-2008, 07:05 PM   #6
Trailer: 1993 Bigfoot 17 ftCB / 2003 Honda Odyssey
Hi;
I successfully replaced the POS Magnetek 6332 in my 1993 Bigfoot 17CB with a Progressive Dynamics Inteli-Power PD9260 with the separate PD92201 Converter status remote pendant for about $200 off eBay!
The 9260 is overkill for my needs, but it was physically smaller and fit well into the lower section of the Magnetek unit. I stripped out that useless stuff and slid in the new unit. I was worried that the lower rated units (PD 9230, 9240, 9245), being 4.5 inches high wouldn't fit. I'm not sure, but I think they would have fit after all - BUT measure yours to be sure, if you go that route. A minimum of wiring changes are required as I use the Magnetek box as it was for AC and DC distribution.
I also installed an additional size 24 battery under the front part of the other dinette seat, and ran #8 wire behind the panelling to parallel up the existing tongue mounted battery.
Do a search on my name, or "Upgrading an ancient power converter - a few questions", and you'll see a lot of info about the conversion.
That was done a year ago and it has been a 'perfect' solution!
<http://www.progressivedyn.com/PD9200_Manual.pdf>
If you do have any questions, drop me a note, or on this forum!
Good Luck, whichever way you go!
Mike.....>
Michael Pupeza is offline   Reply With Quote
Old 08-21-2008, 07:38 PM   #7
DaveK's Avatar
Best I can do is offer you third refusal when it's time.
I did read Michael's thread and it was very useful, just didn't address my simplistic "What do I buy?" question. And I will email if I get confused on the install.
I'll call Best Converter in the morning. Just looking at their home page is enlightening.
Thanks!
Dave
Old 08-21-2008, 08:31 PM   #8
Pete Dumbleton's Avatar
Consider not replacing it, except maybe to pull out the circuit breakers and 12VDC fuse block if in the unit and just getting a good multi-stage battery charger instead and put the left-over money aside to buy a new battery or a supply of beer (Although, the prices of good converters seem to be coming down and the chargers are going up).
The converter's prime purpose is to be a 120VAC > 12VDC power supply, with battery charging as a distant second purpose -- Smart charge converters or upgrades are expensive compared to a good battery charger -- The charger can also do other things like start someone's engine when it is flat (Can you see yourself running jumper cables between your charge wizard and your neighbor's truck battery? No, me neither).
I understand that one of the Vector models is auto-start, so you can just hardwire it to the battery and plug it in to an outlet -- Every time the egg is connected to shore power or generator, it will be charging the battery.
http://www.battery-rechargeable-charger.co...r-products.html
If I were buying a new one today, I would get the VEC1097A, which has charge rates from 2 > 10 > 30 Amps, with a jump-start rate of 80 Amps -- I just saw it for $74 US.
You can also take the charger off and put the old converter back in if you decide to sell the egg.
Old 08-22-2008, 08:35 AM   #9
kevin61's Avatar
Trailer: 13 ft Boler and 17 ft Boler
I took my old converter out of my Boler and replaced it with a Xantrex Truecharge battery charger. Find one that won't exceed the charging parameters of your battery bank. ie) a 200 amp bank can be charged with up to a 20 amp charger while a 100 amp charger would be best suited to a 10amp (it is best to not exceed 10% of your battery rating)
As Pete says, the charger is hardwired into the trailer so that every time it is connected to shorepower the charger is silently doing its job of recharging the house batteries. The batteries in turn, feed all 12 volt appliances and your inverter if you have one installed.
kevin61 is offline   Reply With Quote
Old 08-22-2008, 08:56 AM   #10
Gina D.'s Avatar
I am with Pete.. except the price of beer is going up too.
Dump the converter all together.. you'll lose weight, and thus.. have more room for beer.
Old 08-22-2008, 09:08 AM   #11
Lainey's Avatar
Okay, I await your email
Seriously though, if you decide to sell it once you have your other project up and running let me know. Best of luck with your converter - or beer - whichever way you end up going.
Old 08-22-2008, 03:55 PM   #12
DaveK's Avatar
Noted. ::scribbles on a post-it::
Thanks all for your input. I read the thread(s) about going converter-less before starting the topic. I like the idea for me (and the project trailer), especially since there's an 85 watt solar panel in the garage waiting to be mounted on the roof. But come Littlefoot selling time I suspect having a converter might be a better selling point, especially if it's to a newbie.
The fellow at Best Converter recommended http://www.bestconverter.com/WFCO-8725-Pow...er_p_83-50.html and it should be here next week. It came in plenty cheaper than the others I was looking at, so there's still beer money!
Dave
Old 08-22-2008, 05:12 PM   #13
Dan Meyer's Avatar
>snip<
I've not been following these forums very much lately; just exactly what problem are you trying to solve?
-- Dan Meyer
Old 08-22-2008, 07:25 PM   #14
Dan's on to it -- If it's noise in the stereo, it might be solved by something like a noise filter.
BTW, on my old Magnatek, some of the fuse positions on the fuse block were set up to be filtered by the battery, whereas others were for noisy appliances like fridge, fan, furnace, etc. You might solve the problem by moving some wires around.
Old 08-22-2008, 09:01 PM   #15
Dave;
Looking at the specs of the unit that you chose, I would agree that you should be OK with that system.
As a Ham Radio Operator, I did also look at the 'RF Noise' generated by some of these units, but, rarely, are any of them a real problem!
My experiences with several Magnetek units have soured me on that maker!
Even the "upgrades" turn me off!
However, as has been mentioned, a 3 stage charger is a good replacement for a 'Converter' as long as there is a real battery connected at all times!
Be aware that some of them will seem 'dead' if the battery goes below a certain minimum voltage! You would be without 12V power if you had a dead battery, even with the charger! That is the difference between a 'Converter'!
Good luck,
Mike .....>
Old 08-22-2008, 09:07 PM   #16
DaveK's Avatar
It's not noise at this point. The stereo has been odd from day one. It worked perfectly at first -- until the first time I turned on the Maxx fan. Drove the stereo crackerdog, literally crashed it. After a reset and and a 30 minute wait all was well. After that, turned on the fan first, then the stereo, no worries.
At NOG Byron suggested an in-line filter, but I didn't get to it, and then in the driveway, I accidentally turned on the fan second -- and everything was fine.
I changed out the battery before the last trip, and suddenly the stereo will only work on battery power. Switch to shore power, it makes blinky lights and funny noises. Switch back to battery, all is well. Reset doesn't affect. Fan, doesn't affect. Very strange. Switch back to the previous battery, still no better.
This elderly magnatek has one fuse, and everything is connected in parallel right out of the back from two wires. At SOG Gene L and Peter H concurred on converter being a probable cause, on the theroy that it was putting out raggedy (my word) dc power.
If nothing else, I'll get a charge circuit for the battery out of it.
Dave
Converter ted saxton Problem Solving | Owners Helping Owners 10 09-17-2011 07:19 PM
My converter AGAIN! Monica M Problem Solving | Owners Helping Owners 12 09-08-2010 09:10 PM
Converter Darnelle Care and Feeding of Molded Fiberglass Trailers 5 04-28-2010 07:24 AM
need a converter? Jeanne and Steve General Chat 2 12-13-2007 03:53 PM
converter question Karalyn Care and Feeding of Molded Fiberglass Trailers 2 07-18-2007 03:03 AM
