Replacing a vent -- silicon? - Page 2 - Fiberglass RV
Old 02-03-2012, 05:30 PM   #15
honda03842's Avatar
Name: Norm and Ginny
Lexel and Butyl Tape
I used tape for the Hotwater, water intake, electrical cord, cable and satellite connection, things I might want to replace again.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-03-2012, 05:45 PM   #16
ALL plastic items on the exterior of the trailer will EVENTUALLY fail due to UV damage. In some areas of the country that happens sooner than in others. You can slow it down by spraying the parts with Fusion paint which helps inhibit the damage... but nothing will completely stop it. It's best to plan ahead, rather than have regrets because you thought you were affixing something "permanent" on the exterior of the trailer. Norm has the right idea... YMMV
Old 02-07-2012, 11:41 AM   #17
Name: Dave and Shelly
Trailer: 2001 Spirit Deluxe Casita "New Name: Eggspensive"
Iowa
Is this Lexel the self leveling stuff you guys have talked about before?
sfoss is offline   Reply With Quote
Old 02-07-2012, 12:03 PM   #18
Trailer: Casita 17 ft DLX SD
Lexel
The lexel I've used is not self leveling . I do know that it adheres better than silicone , is more UV resistant than silicone, has good stretch properties and Lexel will stick to Lexel which is nice if you need to repair a spot.
Steve Dunham
Old 02-07-2012, 12:25 PM   #19
I also vote for Butyl tape only for sealing vents, fans, lights etc to the trailer. I do though but a tiny bit of Lexel caulking in the hole before I shoot the rivet into it and put a tiny tiny dab of it onto the hole in the middle of the rivet.
Old 02-07-2012, 12:25 PM   #20
LukeP's Avatar
Iowa
as Steve said, I'm not using self-leveling either. Here's a link to the caulk - I use the 5.5oz tube (you can click hypertext on this page), and I use white. You can also google "Lexel white caulk 13033"
LexelŽ - The superior alternative to silicone.
LukeP is offline   Reply With Quote
Old 02-08-2012, 05:45 PM   #21
Iowa
Thank you LukeP. Going to Camping world this weekend and Omaha so will check it out.
replacing escape hatch vent crank.. Christi V. Problem Solving | Owners Helping Owners 4 03-04-2009 06:16 PM
Replacing ~9" roof vent in Boler Raya Care and Feeding of Molded Fiberglass Trailers 34 12-16-2008 07:01 PM
Replacing the Roof Vent DanMurphy Care and Feeding of Molded Fiberglass Trailers 8 06-03-2008 02:04 PM
Replacing Scamp Ceiling Vent With Fan Parker Buckley Modifications, Alterations and Updates 6 02-29-2008 02:08 PM
Replacing -----------Roof vent cover Kevin K Problem Solving | Owners Helping Owners 11 02-04-2008 08:57 PM
