02-08-2012, 06:42 PM
Name: Dave and Shelly
Trailer: 2001 Spirit Deluxe Casita "New Name: Eggspensive"
Iowa
Replacing rivets?
How do i know if i need to replace my rivets? Alot of my caps are gone and the clear ring around the outside edge is pretty brittle. I e mailed Larry at little house customs and he said the only proper way to get the snaps on is to replace the rivets. Do we just drill out the old ones and replace with new ones from little house customs? Does the clear snap thingy go on after the rivet is thru? Then the cap? Is it hard to do? Have you ever had it split the fiberglass? I am so confused!
02-09-2012, 06:41 PM
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
On my Scamp the clear plastic 'cup' goes on the rivet before it is installed. I suspect it provides some 'cushioning effect and aid in water repellency as well as a seat for the plastic caps. When re-doing the rivets on my Scamp I drilled out the old rivet heads & pulled the rivet bodies from inside the trailer. I seated the clear plastic 'cups' on the rivet (not an easy job as the holes in the cups are undersized when mated with the correct size rivet) with the cup against the rivet head, dabbed a little acrylic sealer around the rivet tube, inserted & set the rivet (I added a little redundancy here; my wife held an appropriate sized washer on the rivet from inside while I 'set' the rivet), then added a little more sealer to the rivet head & installed the cap. So far thru some 'high pressure' water hose tests & a couple of severe T'storms none have leaked
02-09-2012, 07:51 PM
Iowa
Thanks harvey!
It really scares me to replace rivets on a camper that isn;t currently leaking. DH is feeling the same way. Does anyone just ad some of the fiberglass caulking that everyone talks about and put a cap over it? I would guess it would be safe to do it on the ones that already have decent snap left. Or would everyone say that it is better to redo everything at once?
02-09-2012, 09:18 PM
Arkansas
Being relatively new to fiberglass RV's I'm hesitant to make a recommendation. Were it me however, if I didn't have ANY leaks at all, I'd use the Lexel sealer around the rivet heads & to help hold new caps in place. If you should develop a leak it'd be a fairly easy job to replace that rivet. Dunno how other trailers are built rivet wise but in my scamp it was relatively easy to see when water was coming in around the rivet. The 'acorn nut' (or just the expanded end of the rivet) would begin to discolor even before starting to rust. I just replaced the rivet where I saw any evidence of water/discoloration. In my case quite a lot of the caps were missing & in some cases the 'cup' was also broken so I just replaced those rivets also even when they didn't appear to be leaking.
02-09-2012, 09:40 PM
The first one is the nerve racking one! After that it will seem pretty simple. Buy a good rivet gun. Its a two man job. Use a smaller drill bit than the hole that is there and have someone hold the inside part with a pair of pliers to keep the rivet from spinning. The person on the inside also gets to hold what ever you are shooting the new rivet into - in the case of my Scamp its a acorn nut.
02-09-2012, 11:49 PM
I've re furbished 6 or 7 FB trailers since I retired.
If there is any clear ring left and the rivet is not loose or leaking I simply fill a Rivet Cap with a FG compatible caulking and put it back over the rivet.
I use Dicor lap sealant for almost everything on my trailers.
Dicor is available at most RV stores.
John
02-10-2012, 08:01 AM
Iowa
Thank you everyone. Maybe i will get more brave once spring gets here. I need to order a kit and caps anyway just in case of a leak. And like Carol says once we do the first one and see that everything is ok maybe it will be a breeze after that! Thanks again!
02-10-2012, 02:19 PM
Trailer: Casita 2000 Spirit Deluxe
The idea of removing and redoing rivets really scares me. That was one reason I sold my last 2 campers. I saw what Shelly is seeing and I got rid of the trailer before I had any problems. Also another reason for my looking at stickys as well as Casita's. I am not a repair person. Wonder if camping world or other RV places fix rivet problems? Shelly, good luck and let me know if rivet fixing is easy or not. :-)
Karalyn
02-10-2012, 02:56 PM
Depending on where in the country (UVs) maintenance is about every five years to replace the caps. It's best to do it before needed, not after they've disintergrated. If done before damage to the underlying clear "gasket" happens, you don't need to use any caulk. There's a reason the white buttons (caps) are called snap caps.
Karalyn, you do know you are only trading rivets for seams... right.... in looking at stick built trailers? There isn't a trailer made that doesn't require maintenance. At least with molded you know they hold their value.
02-10-2012, 04:37 PM
True Donna, they do hold their value. Seams do not need replacing like rivets though, and I just do not know how to do rivets. I suppose someone at a fiberglass meet somewhere could show me. I bet Floyd knows how to replace them. :-) Are you saying that if replacing the caps every 5 yrs or so, the rivets may never have to be replaced????
Yep, all campers have issues. I have been online looking all day at options. I went to the camping show in Minnepolis yesterday and the stickys are so much roomier. I only really need a place for about 3 people to sleep and still think I may get better gas mileage with the Casita. I have asked a couple of other questions today on the board re Casita tongue wt etc. My heart is still with the Casita as it is easier to haul (I think)
Karalyn
02-10-2012, 06:45 PM
True - your don't replace the seams. When the seams leak - after about 4 or 5 years - you replace the whole trailer! (That's why I'm into glass now after having a sticky as my first one!)
02-10-2012, 06:56 PM
My brother bought a brand new monster fifth wheel. Two years later, the entire roof had to be removed and two walls in the nose section pulled out. Water had leaked from the roof seams into the insulation (batting?) He didn't know it was leaking until the fiberglass side started to bulge at the bottom. Fortunately it was 100% covered under warranty. But, he's never felt the same about the trailer and wonders what is going to let go next.
Karayln, buy a good rivet gun and a box of aluminum rivets. Go to the dollar store and buy a flexible cutting board or some other thing of thin plastic. Punch a couple of holes and practice. It's NOT hard..... OR, replace all the rivets you want... when you need to with stainless steel screws and acorn nuts, a number of people have done that. There ARE options and you CAN do it!
02-10-2012, 07:54 PM
Yikes Donna, your brother was lucky his rig was under warantee. I guess I will keep looking for my Casita. I am beginning to think I should have kept my Scamp even though I needed a stool to reach the toilet.
Karalyn
02-10-2012, 08:20 PM
Karalyn, whatever brand of molded towable you get... you will be ahead of a lot of other people. AND, you have the support of all the active members of this forum in your corner when you have questions.
02-10-2012, 11:03 PM
Trailer: We have had all the brands at least once.
Replacing rivets is not hard. You need a 1/8 drill bit to drill out the center of the rivet, a punch to push the rivet center all the way through. I owned a 1995 Scamp under some of the caps were wood screws. I replaced all the snap caps. Listen to Donna and get some help with the rivets. Get a good rivet gun look at Fiberglass Travel Trailers RV.
Good luck,
Chuck
02-11-2012, 08:16 AM
Iowa
So true!!
I haven't even gotten to camp in my casita yet and i don't know what I would have done without this wonderful website! I thank all of you who have been so supportive and helpful. Off to camping world.... woooo hooo!
02-11-2012, 10:11 AM
Rivets
We did the same thing when replacing our roof vent and some bad rivets on our Scamp. We put Lexel on the rivet and the backside of the clear plastic cup washer added a SS flatwashers on the back side of the fiberglass and set the rivet. We then put Lexel in the Snap Cap and installed the Snap Cap wiping off the excess Lexel . May not be the right way but it stopped the leaks and the caps don't fall off.
02-11-2012, 10:39 AM
Karalyn, Donna has given you some great advise. You never know you might enjoy riveting things and start looking for more things to rivet Fixing a stick trailer that has a leak IMHO is *way* harder, more expensive and time consuming.
Replacing the caps before they fall apart will keep the clear snap ring in good shape for much longer but even if you do replace the caps at some point you may find that the rivet itself will need to be replaced - as others have mentioned if the inside fastener is changing colour that's a good indication that water is getting through & the rivet will need to be replaced. With age and stress the rivet itself can also snap in two. Its a good thing that the rivet snaps under stress rather than having the fiberglass crack. On my 20 year old trailer I had only 1 rivet snapped in two in the first 4 years of ownership but two snapped apart on a recent trip - but that was after having put well over 8000 miles on the trailer this year alone & traveling on some not so smooth roads and they were rivets that I have never replaced since I owned the trailer so its a good bet they were original to the trailer.
03-12-2012, 05:37 PM
Trailer: 99 Scamp 16
Idaho
My 99 scamp 16' doesn't have any of those caps left on any of the rivets maybe two, so you are supposed to pull out every rivet and replace them with the plastic washers and caps? That seems like a lot of work, can't you just put rv caulk around them to prevent a possible leak caulk under a cap and put just the cap on?
03-12-2012, 05:46 PM
Arkansas
You should be able to easily identify any rivets that are 'leaking' by checking inside during/after heavy rain or use the hose test. Even tho the 'caps' are gone, if you still have the plastic 'cup seals' outside, & that rivet doesn't leak, I'd say you'd be pretty safe in just replacing the cap only. I'd also add a little sealer of some kind around the rivet head before putting on the new cap. If the plastic 'cup' is missing or has deteriorated to the point that it'll no longer 'hold' a cap I think I'd go ahead & replace that rivet. JMO...
