Scamp 5th wheel. What is the rivets gripping on the backside? Acorn nuts?
Do I need to pull away the "rat fur" to see them? Is the rat fur glued around all the windows if I have to pull the windows for new Butyl tape?
Scamp uses "blind" rivets- nothin' back there but more rivet! To remove, just drill out the center, usually a 1/8 bit will do it.
Tip:
If you've never used a blind riveter, Youtube has lots of vids on the subject.
Francesca
................................. Propane Facts vs. Fiction:. Click here Tow Limit Calculator: Click here
John,
The rivets with the acorn nuts are the same type of blind rivet. The Acorn nut is there for either esthetics or strength (i.e. in stead of a backing washer)
