Rivet Gun for Casita? - Page 3 - Fiberglass RV
Old 04-24-2013, 08:29 AM   #29
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Thanks, Mike. What a fun tool! Two questions:
1) Do you rivet from the inside out, or outside in?
2) Is there some sort of grommet gizmo you put into the hole before putting in the rivet to prevent any leaks?
Thanks!
fusedlight is offline   Reply With Quote
Old 04-24-2013, 08:39 AM   #30
GMike A's Avatar
Depends if you are pulling my leg. If you are then you wait til a full moon to rivet. If not then you rivet from the outside in using a snap cap and a sealer.(sorry for the disclaimer, but we have lots of good-hearted pranksters on the forum- myself included) Regardless Donna will tell you to never put silicone onto fiberglass. Most times its recommended to use two people, one to use the gun and the other on the inside to insert a correctly sized washer on the rivet head. If you use the Google search engine at the top you will find tons of rivet threads.
http://www.fiberglassrv.com/forums/m...q=rivets&sa=Go
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 04-24-2013, 08:57 AM   #31
fusedlight's Avatar
Me, Be in Jest? Surely you Jest! (Just don't call me Shirley!)
Old 04-24-2013, 10:19 AM   #32
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
The rivet itself forms the seal- if properly inserted/sized for the hole no washers or compounds are used unless strengthening for the load, which is sometimes done by use of a backwasher. A better alternative for heavier loads is a bigger rivet.
Caps are strictly decorative, and the loss of one only a cosmetic issue.
Francesca
Old 04-24-2013, 10:40 AM   #33
Originally Posted by Donna D. View Post
I don't care whether you use rivets, SS bolts, VHB tape, glue, OR SILICONE! I know what I USE/like ... the rest of you stay away from my trailer
Me Too! it goes like this "Please step away from my trailer!
In my old trailer I have had a number of old rivets snap and one of them has snapped more than once in the past 5 years due to its location and what its holding and the rough roads I have been known to travel on - actually had one fairly new rivet snap in southern Cal last winter and in that case the road could have used a repaving thats for sure but not overly rough - just miles and miles of the trailer being bounced a bit more than normal.
Suspect my choice is simply based on having been around fiberglass boats long enough to know what happens when fiberglass and SS bolts meet and one of them needs to give for whatever reason.
Old 04-24-2013, 10:57 AM   #34
Thanks!
Normally you rivet from the outside to the inside. On your Scamp you will see that most of main rivets used to go through the exterior that attach to the cabinets have acorn nuts on them. Those are much easier to do if you have someone on the inside holding the acorn nut.
No grommet gizmo but some will argue that the plastic cap holder that Scamp uses does act as a bit of a cushioning washer and helps to have them if for some reason the hole the rivet is going through has been "slightly" enlarged for what ever reason. Donna now needs to close her ears but it isnt unheard of for a few folks here to put a very "tiny" dap of Marine Polyurethane type caulking (such as a 3M 4200 which is removable) on the bottom(trailer side) of the cap holder to seal it to the fiberglass and in doing so taking care of any problems there may be with the hole size.
Old 04-24-2013, 12:32 PM   #35
fusedlight's Avatar
Is that acorn nut held in by the rivet as it forms its flange?
Oh... and talk about targeting... the display ad at the top of the page is for JayCe rivets!
Old 04-24-2013, 12:36 PM   #36
Yes it is.
Old 04-24-2013, 01:36 PM   #37
GMike A's Avatar
I cant do a search anywhere on Google or Yahoo or I cant buy anything on Amazon and if I go to any forum or my FB, Twitter, etc on any page I am bombarded with widgets that I was looking at just ten minutes ago. No one is safe from the evil eye.
Mike
K5NAN
"Miss Adventures"
Old 04-24-2013, 02:04 PM   #38
Have you tried turning on your pop up blocker? or looking a bit deeper into your web surfing apps security settings. I switched to Google Chrome some time back as I got to frustrated using Microsoft's IE.
Old 04-24-2013, 02:37 PM   #39
Trailer: 77 Scamp 13
Clear your cookies google delete cookies for {your browser} These small files allow adverts to know what "you" have been looking at elsewhere if the ad company has any affiliation with any site you went to. Or had ads on any site you went to. Sigh.
On rivets I'm in the camp of drill the head with sharp bit just a tiny amount larger than shank. Most of the time the shank will push right through after the head spins off. Nice to have someone on inside to hold rivet with pliers if it starts to spin or when installing to hold things in place, like acorn nuts.
I would add that I pad the sides of my rivet gun with tape to help prevent scratches if the head jumps when the rivet snaps. Just a few layers of masking tape.
I did put a really thin layer of buytl tape under my snap cap washers. Warmed by rolling into little ball I can press it thin on the back. Remove any that comes out around the sides with a toothpick. I know it won't stick or be hard to clean off later and does sort of squish into the openings.
Old 04-24-2013, 02:43 PM   #40
GMike A's Avatar
I gave up on IE years ago and only use FF. Also I think that I am gravitating to just a tad bit of buytl under the cap also. It wont hurt and to me it will displace any water that wants to use capillary action and suck under the cap. IMO
Mike
K5NAN
"Miss Adventures"
Old 04-25-2013, 07:53 AM   #41
fusedlight's Avatar
Has anyone used this gun from Harbor?
Heavy Duty 17-1/2" Hand Riveter With Collection Bottle
Old 04-25-2013, 08:09 AM   #42
GMike A's Avatar
To be VERY honest I have not but it really looks nice. I did buy their other fixed head at a right angle and the air propelled one. This actually looks very versitile and with the 20% coupon could work out. I will check it out the next time I go there, but really never noticed it before. I like it has a capture bottle and head storage and looks like a leverage mechanism. The others there are straight grip and sometimes you have to muscle that last 1/8 inch to get it to pop. Thanks. I do notice that every time I go in there they are out of aluminum rivets.
Mike
K5NAN
"Miss Adventures"
casita
Pop rivet gun... clearcut Problem Solving | Owners Helping Owners 8 11-10-2012 09:20 PM
Rivet Gun Kit Deb & Chuck Commercial Posts and Products 3 08-27-2012 05:30 PM
Rivet Gun Rarebird General Chat 7 04-15-2010 09:34 PM
Rivet gun question DannyH Problem Solving | Owners Helping Owners 12 01-11-2010 05:09 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
