Rivet Gun for Casita? - Fiberglass RV
Old 04-21-2013, 09:23 PM   #1
BOBSMITH's Avatar
Trailer: 2002 Casita Freedom Deluxe / 2007 Nissan Frontier King Cab
What rivet gun and what rivets do I need to replace rivets on my 2002 Casita? I've been told to remove the old rivets with a 3/8" drill bit. Right?
All help appreciated.
BOBSMITH is offline   Reply With Quote
Old 04-21-2013, 10:17 PM   #2
Perry J's Avatar
Trailer: 16' Casita
I don't know about Casita but Scamp uses 3/16th dia. rivets.
I use a 3/16 bit.
Old 04-22-2013, 05:27 AM   #3
Trailer: casita freedom dlx 17
There are different size rivets in the casita's depending on the location. I just bought a rivet gun from home depot and it works fine.
But the size of the rivet depends on the location. I called Casita, asked them to send me an assortment of rivets, caps, etc and it was here in a couple of days.
Then you can see the rivet you want to replace, match it with the new rivet casita sent you, use a drill bit guide to size things up, and then have fun.
I wasn't able to find the right size and diameter of rivets in the stores so I just called casita, the parts were not overpriced or anything and it was good to know I had all the proper sizes.
Enjoy
Don W. is offline   Reply With Quote
Old 04-22-2013, 06:34 AM   #4
GMike A's Avatar
I cut and pasted this from another thread on Rivets.
"You can also order enough caps and bases from Pro-Dec.com for the about the price of ONLY the shipping from Scamp. It cuts the price almost in half."
Pro-Dec: Manufacturer of Screw Covers, Screw Caps & Snap-CapsŪ
Pro-Dec uses the mail and I received my order in 5 days.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 04-22-2013, 06:41 AM   #5
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
While talking to Casita about something else, I mentioned rivets and replacing them. They told me to use a drill bit no more than 1/64 oversize. A 3/8 drill bit is HUGE. I believe most of the rivets are 3/16 but there may be 1/8 in there somewhere.
I have a 1/2" wide chisel I don't care much about and that I've softened the corners of, that I sometimes use to shear off the head of the rivet. It's use depends on whether I can get the flat side of the chisel flat against the wall so that I don't score the wall. That leaves me the hole pretty much as Casita drilled it and I can test rivets in it.
The chisel thing only works on aluminum rivets. I wouldn't use it on stainless steel rivets or stainless shank rivets.
Old 04-22-2013, 06:52 AM   #6
GMike A's Avatar
I guess we all have different methods. I use an over size SHARP drill and just lightly hold down on the head and it cuts through it and the head spins right off and leaves only the body down in the hole. I can then go back with the correct size drill and go down through the body. You can tell a good riveter when the shaft is not there and you can drill it right out. Those where the pull pin were snapped off are bears to get out. JMHO
Mike
K5NAN
"Miss Adventures"
Old 04-22-2013, 08:29 AM   #7
fusedlight's Avatar
Trailer: 16' 1998 Scamp
I'm glad I saw this... as I strip the Cat Fur off the Scamp I am seeing a TON of missing rivet spots.
Thanks for the links!
fusedlight is offline   Reply With Quote
Old 04-22-2013, 08:51 AM   #8
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by GMike A View Post
I guess we all have different methods. I use an over size SHARP drill and just lightly hold down on the head and it cuts through it and the head spins right off and leaves only the body down in the hole. I can then go back with the correct size drill and go down through the body.........
My technique, also. You need to watch carefully for the top to separate, then pull back on the drill.
Old 04-22-2013, 09:53 AM   #9
Gary, the link Scamp Rivet Size List will help you. Scamp also uses different sizes/lengths on their trailers. Found that one of the sizes was hard to find locally without having to buy a really big box of them that I will never use up. Scamp sells a bag of all the sizes and number of them you will need to replace all of rivets on the trailer and the price is pretty good. You can also get from Scamp a bag of all the different sized snap caps and plastic cap holders they use as well.
Old 04-22-2013, 11:05 AM   #10
Trailer: 2008 13' Scamp
I guess we all have different methods. I. JMHO
Looks like that's true. I've never use an oversize drill or a chisel. For an 1/8" pop rivet I use an 1/8" drill bit. Most of the time the deed is done in seconds. For the odd time when it's not working as usual I give the drill a little side-to-side wiggle and that usually does the trick.
What ever works for ya
Old 04-22-2013, 11:05 AM   #11
Perry J's Avatar
Trailer: 16' Casita
Scamp uses 3/16 diameter by 1/4" grip range and 3/8 to 1/2 grip range.
I used the 1/8 x1/2 on the curtain rod holder.
All sizes are available at Ace Hardware or Lowes for less than the prices of shipping from Scamp.
Same for the snap caps and Pro Dec.
The Pro Dec cap bases have a slightly larger hole so you don't have to force the rivet through them.
Old 04-23-2013, 10:34 AM   #12
BOBSMITH's Avatar
Thanks for the advice. Man...I've had a COMPLETELY different experience with Casita. No one there to help. They close at 4:00 pm. Constantly being put on hold. Hang ups. etc.
I'll try to find the stuff locally.
Old 04-23-2013, 10:47 AM   #13
GMike A's Avatar
When I went down there last week I saw Tim from parts on the phone, a salesman, Victor was doing a demo and I saw one admin. There might have been some mechanics in the shop doing work. That was it. They did approach and want to assist me as best as they could, that was not an issue for me. Tim finally was able to come over and talk to me and he was very helpful. Nice showroom and units on the floor.
Mike
K5NAN
"Miss Adventures"
Old 04-23-2013, 10:51 AM   #14
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
For those buying off-the shelf aluminum rivets, I advise to make sure you're getting those with aluminum mandrels- some are steel, and the itty bitty part that's left after installation will eventually bleed rust!
Per riveters:
I wimped out and bought an air-driven riveter as I find rivets over 1/8 inch hard to do with a hand riveter.
Francesca
casita
Pop rivet gun... clearcut Problem Solving | Owners Helping Owners 8 11-10-2012 09:20 PM
Rivet Gun Kit Deb & Chuck Commercial Posts and Products 3 08-27-2012 05:30 PM
Rivet Gun Rarebird General Chat 7 04-15-2010 09:34 PM
Rivet gun question DannyH Problem Solving | Owners Helping Owners 12 01-11-2010 05:09 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
