Rivets, Acorn nuts, Rivnuts etc. - Fiberglass RV
Old 05-02-2007, 10:03 AM   #1
Trailer: Scamp 16 ft
We've got the Merlot and Scotch in our kit like Garo, so I think we're over halfway there. That way if something breaks we won't care....
I did remove all rivets and replace with stainless steel bolts and nuts per Con's thread, so a Phillips head and 3/8" wrench will take care of 90% of what we'd run into now. Stocking the rest of the kit with wire ties, lubes, caulk(non-silicone), electrical items and the tire changing necessities. If it's anything major beyond that then the Merlot and Scotch come into play...
I am curious about replacing the rivets with stainless steel bolts. This really should not be too difficult. are they hard to find or commonly avainable. I guess I am more comfortable with that then those pop rivets.
Dan B is offline   Reply With Quote
Old 05-02-2007, 12:49 PM   #2
peterh's Avatar
--><div class='quotemain'>
[/quote]
Home Depot, Lowes, and other well-stocked hardware stores usually have a small selection of stainless steel hardware for sale.
Stainless steel is one option, but blind rivets have advantages, too. While you can re-tighten a loose screw, rivets don't have nuts that can loosen and fall off, and with blind rivets you don't need somone inside to stabilize the nut and washer while tightening the screw from the outside. They're also quick and easy to set and tighten.
--P
Old 05-02-2007, 05:05 PM   #3
Greg A's Avatar
Trailer: 2015 Escape 19
Hey Dan,
If you read through this entire thread
http://www.fiberglassrv.com/board/in...howtopic=18751
It covers how Con recommended replacing all the pop rivets with SS nuts and bolts. He gives a recommended supplier which I ordered through as well. Home Depot is a little weak on their SS supplies, but Lowe's isn't too bad and I've filled in somewhat there. I mostly use the SS locking nuts instead of the acorns as they won't loosen. The rivets are prone to leaking down the center hole which is how this thread got going. There is great info in there about Butyl tape as well.
Alf followed Con's information and replaced the rivets as well, so he may weigh in with his thoughts as well. Alf, you around?
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 05-02-2007, 05:44 PM   #4
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
Interesting thread and I largely agree with all of it. There's a lot of good wisdom there in my opinion which, I'm happy to see, mirrors my own...
I'm not entirely sure I agree with the notion of replacing all of your rivets with stainless steel. Thinking about all the rivets on my 17 (which I'm deeply acquainted with at this point, see my other thread on my Boler 17 refresh), all the rivets I can think of on the outside of the trailer come through the wall where there is insulation. In order to tighten a stainless steel nylok nut, you have to break through the insulation. This is great when, in my current state, I have removed all of the insulation anyway, but once I put the new insulation on, I have no intention of ever taking it back off so I can get to the other side of some fasteners... Also, I'd need to convince my wife to go in and hold the wrench for me on the inside while I turn the bolt on the outside.
On my previous Boler 1300, there were a bunch of rivets holding the cabinets to the trailer. I did recognize that as most un-enlightened and replaced those with stainless fasteners.
As to water leaking through the center of the rivet, this is a well understood problem. You can either just dab some paintable sealant on top of the rivet when you're done (which is a little cheesy, admittedly) or you can go to a reputable fastener store and get a closed-end pop rivet. I've seen them at Home Depot but haven't looked recently. Here's a page that has closed end blind rivets about 2/3 down.
Herb P is offline   Reply With Quote
Old 05-02-2007, 06:03 PM   #5
Brian B-P's Avatar
Herb, I see your point about fastener access. It appears in my B1700 that some external stuff was riveted on before the interior lining was installed, so the inside end of the fastener is not accessible: that's the rain deflector over the door, the awning rail, etc. Other rivets were installed after the lining, such as the ones securing the upper cabinet brackets; those are clearly visible now and would be quite accessible. Some fittings are in locations which are within cabinetry and with no lining (such as the service inlets), so they are at least somewhat accessible. Depending on the re-assembly order, the situation may change in the renovation.
The most highly stressed rivets (for the cabinets) seem to be the most accessible and thus the best candidates for replacement with bolts, which is either good planning (yeah, likely...) or just lucky.
There may not be a single answer best for all applications, even within one trailer.
Old 05-02-2007, 06:24 PM   #6
Greg A's Avatar
Good points Herb and Brian.
The Scamp must be a bit different, because 90% of the rivets are accessible and make sense to replace with the SS. There are some that just don't make sense as both of you pointed out and you do have to use the ol judgement for each situation.
Some of the ones that weren't accessible behind the ensolite Con drilled through and put a SS washer over the ensolite on the inside, but you have to make sure it will be visually appealing. I did the same in some cases where it made sense, however, some rivets make sense to stay, although don't have many left and most of them are on the closet.
Owner:
Old 05-02-2007, 10:54 PM   #7
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: A power outage in the middle of my browsing put me out of the picture...but I am bbbbbbbackkkk... Yes I am still doing the S/S shuffle...I had to go back and re tighten a few...curtain rod brackets...Try that with a pop rivet!!! The only place I may use Pop Rivets is for the awning rail as there are so many...so close. Now I am into installing a MaxxFan but first I have to go visit my friendly FACCA fasteners store to replace the hardware supplied with the fan...with S/S!!! I have cut two 3/4 plywood spacers to fit in the roof as per Brian BP's install and have some very sticky black Buytl tape to hold them in place while I install the fan collar with S/S screws. I hope to be able to gently peel back the Ensolite so the spacers fit under it and I can stretch it over to cover the plywood. Since going Digi. I am taking stepXstep pic's and will create a new Album when finished.
Old 05-03-2007, 10:25 AM   #8
Hey Dan,
In looking at the interior of my Scamp it appears that the inside of my rivets is an acorn nut. I wonder if the company did not adapt to using some of them. the outside has a white rounded cap on it about the size of a dime.
Old 05-03-2007, 02:33 PM   #9
Brian B-P's Avatar
Some makers (including Boler, and apparently Scamp) use an acorn nut to to finish off the inside of the rivet. From the tool kit perspective, this means an appropriate wrench would be ideal, but for an on-the-road repair a failed rivet would just be drilled out and replaced (needing a rivet gun) like any other rivet, and if the nut is just for appearance it could be replaced later.
Old 05-03-2007, 07:07 PM   #10
Greg A's Avatar
Dan,
It was the same on mine. They had an acorn nut over the end of the rivet certain places. The white caps on the outside on mine were chock full of silicone and covered the rivets or screws. Of course, the silicone had failed and most had rusted through to the interior. A mess to clean up.
Now that I have them replaced it is just Stainless steel bolts showing and it looks better, shouldn't leak or rust like the old hardware.
As for my tool kit, I just need to carry a philips head and a 3/8" wrench. No rivet gun or rivets.
Owner:
Old 05-03-2007, 07:29 PM   #11
Alf S.'s Avatar
Hi: The acorn nuts on the interior side of the pop rivets on our Boler were just for decoration and are not tightenable... and they rust where rivets leak leaving ugly stains/streaks on the Ensolite... Once replaced the interior will... I hope stay cleaner... My Wife likes that idea Alf S. North shore of Lake Erie
Old 05-04-2007, 11:49 PM   #12
[/quote]
Dan I just replaced one of those on my Scamp and they a pretty easy to replace. I found somewhere on this site an actual drawing of how the whole thing fits togther.
Per Scamps parts department they are 1/4" acorns. The rivet goes directly into the acorn. The white caps on the outside pop off and are attached via a plastic washer/cap holder which goes under the head of the rivet - Scamp actually uses two different sizes of these caps and holders/washers. I found both sizes of the caps and washers at Home Depot. The not so easy part is finding the right length of rivets. I ended up having Scamp send me a number of them.
Carol
Old 05-07-2007, 09:39 AM   #13
Trailer: 13 ft Scamp
if you are going without an acorn nut, i would suggest using a nylock nut. otherwise a little dab of blue lock-tite will keep that thing from rattling loose
Mark Houghton is offline   Reply With Quote
Old 05-07-2007, 05:29 PM   #14
I've not seen anyone comment about the rivets designed to be the weak link. The rivet would break before the fiberglass sustained damage. IMHO, riivets are a lot easier to replace and caulk than having to make a repair to cracked fiberglass.
The concept of a "weak link" has many other applications. Automotive design protects the occupants be sacrificing parts of the vehicle.
Just food for thought!
Kurt & Ann K.
Speed Nuts Mike Bromley Care and Feeding of Molded Fiberglass Trailers 5 04-30-2010 09:15 PM
Scamp Acorn Nuts Parker Buckley Problem Solving | Owners Helping Owners 8 10-14-2009 09:08 PM
Nuts - Bolts % Other HDW Darwin Maring Problem Solving | Owners Helping Owners 1 05-09-2007 07:03 PM
Rivets and Acorn Nuts Steve L. Modifications, Alterations and Updates 6 11-16-2005 09:36 PM
» Virginia Campgrounds
