Roof weight limits - Fiberglass RV
Old 02-22-2016, 11:28 AM   #1
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
Roof weight limits
I'm sure this been brought up, but my search didn't find anything obvious...I got my new fantastic vent/fan today, and the forecast is for sunny skies and temps in the 40's through Friday. I'm going to get after it.
Am I ok to be up on the roof? Obviously I'll be careful, but as far as what the roof can support, is it fine for me to be up there?
Old 02-22-2016, 12:42 PM   #2
David Tilston's Avatar
Umm... I am not small, so I sent one of my teenage daughters on the roof of the Trillium 4500 that I installed a Fantastic Fan on. Maybe a Bigfoot has more support, I can't say.
Old 02-22-2016, 12:55 PM   #3
I do not believe that any of our fibreglass trailers are designed to take the full weight of a person on the roof.
Having said that some have the roofs have been reinforced for AC units some have not .... but if it has been reinforced and already has an AC I still would not think the extra weight of a person would be a good thing.
Old 02-22-2016, 01:13 PM   #4
ZachO's Avatar
Montana
Ok thanks.
Well in the end there's just no way around it. I don't have AC, but with the width of my roof, there's is just no way of getting the old vent out and the new vent in without being on the roof.
I definitely can't reach from the ladder.
Old 02-22-2016, 01:18 PM   #5
ZachO's Avatar
Montana
And how worried should I be about this? It's just on the front part of the roof. The dark spot is crud, not a hole.
Old 02-22-2016, 02:01 PM   #6
ZachO's Avatar
Montana
Maybe I should start a new thread, but...
As some of you may know, this stuff is hard to get off. I got all the silicone off, but the stuff that looks like Dicor lap sealant is on there really well. I know silicone won't stick to silicone, but if I get butyl tape where the silicone used to be, will the Dicor adhere to the old Dicor?
Obviously I'm going to clean it up as well as I can, but I'm just wondering how much effort I absolutely need to put into this. I'm willing to do what it takes to keep it from leaking, but don't feel the need to do any extra work.
Old 02-22-2016, 02:21 PM   #7
tractors1's Avatar
Trailer: Escape 21 - Felicity
A scraper tool on an oscillating saw will take that off. Dremel makes one that's not too pricey.
Shop Dremel 7-Piece 2.3-Amp Oscillating Tool Kit at Lowes.com
Charlie Y
Old 02-22-2016, 02:31 PM   #8
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
Those wrinkles - how do they feel? Is the shell somehow delaminating? If that is the case, I would be concerned, but have no idea how to deal with something like that. Somebody else knows?
When I have to do something on the roof, I lean my six foot step ladder against the side with some duct tape protecting the side of the camper and reach over. Sometimes I have to use two of them or move it from side to side.
Old 02-22-2016, 02:53 PM   #9
ZachO's Avatar
Montana
Ok, thanks.
Yeah, your Scamp is narrow enough that can work. My Bigfoot is 8' wide...
I don't think there's any delaminating. Just ripples in the fiberglass. Except I don't know enough about fiberglass to know if there are layers which can delaminate..? I don't know if it's an age thing or a water damage thing. There is no sign of water damage inside anywhere on the ceiling.
Old 02-22-2016, 02:56 PM   #10
ZachO's Avatar
Montana
Thanks. I think my money flow has officially dried up So I won't be buying any new tools. Though I'm sure something like that will pay for itself in the long run...
I saw somewhere else online that lap sealant will bond to lap sealant. Just needs to be cleaned up a bit. I'll keep chiseling away at the bigger chunks up there, then just make sure to take the dirty surface layer off the rest, and clean it all up with some mineral spirits or something before I install the fan.
Unless anyone knows for sure that all the old sealant needs to come off...
Old 02-22-2016, 04:20 PM   #11
The cleaner you can get it the better... spent about 2 full days working on cleaning up the roof and hatch of my scamp when I redid it.
If you use google you will find lots of threads on this forum on the topic of removing it..
Here is a fairly good one. Silicon Remover.
I used the DAP product and found that after I scrapped off the major part of it putting the Dap over the remaining thin layer of it and leaving it on for at least a few hours worked fairly well, overnight even better.
Old 02-22-2016, 05:05 PM   #12
Trailer: 2014 Escape 21
Virginia
When working on a Scamp escape hatch you can remove the table top and place a small step ladder under the hatch. You then remove the regulator and regulator mounting bar and top. You can then do just about anything you need to do through the escape hatch hole and not worry about falling off the side of the trailer.
Eddie
Old 02-22-2016, 05:19 PM   #13
ZachO's Avatar
Montana
Thanks Carol, I'll check that out. Maybe I just need to work on using better search terms.
Yes Eddie, now that I've got the old vent out, I can slide the rear bed platform in the Bigfoot out and stand on it, and access the roof fairly well. But not as well as your Scamp...'cause another nice thing about the Bigfoot is the headroom!
Old 02-22-2016, 05:53 PM   #14
I use pool noodle or pipe insulation to protect the trailer from the ladder.
weight
Trailer weight limits - question from chubby folk! songsparrow Care and Feeding of Molded Fiberglass Trailers 5 08-10-2014 07:50 PM
Parkliner bunk bed weight limits or other options? HappyCamperUt Problem Solving | Owners Helping Owners 3 06-02-2014 06:51 AM
Safe weight limits in mountains esgonza Towing, Hitching, Axles and Running Gear 26 07-05-2012 10:33 AM
Weight Limits for Front Bunks Pamela S. Problem Solving | Owners Helping Owners 12 12-23-2009 10:27 AM
Tow limits on cars Philip Care and Feeding of Molded Fiberglass Trailers 34 01-27-2008 11:47 AM
