Rust stains - Fiberglass RV
Old 07-02-2011, 07:28 PM   #1
Trailer: '74 Trillium 1300
Rust stains
Trilliums often have rust stains coming from the belly bead because the pop rivets holding it have carbon steel mandrels and they rust!
These stains can be removed with hydrochloric acid (muratic acid same thing) or a cut lemon which cannot harm anything.
Cheers
IanWR is offline   Reply With Quote
Old 07-03-2011, 05:39 AM   #2
Trailer: 2015 Escape
Muriatic acid is dilute hydrochloric acid if my memory of high school chemistry from over 50 years ago isn't failing me. Wouldn't be a good idea to use undiluted HCl.
rgrugg is offline   Reply With Quote
Old 07-03-2011, 08:23 AM   #3
Trailer: 1973 13 ft Compact II
...this ACID is Oh, so DANGEROUS, if...
...you are not EXTREMELY careful and wear protective EVERYTHING while doing this, OUT in the OPEN AIR.
Much easier, by FAR for me, is that wonderful trailer companion of mine, BARKEEPER's FRIEND. It's a cleanser that sells for under a dollar and is UNREAL in it's cleaning fiberglass capabilities...of course, I cleaned old oxdized trailers and not pristine ones with perfect gel-coat finishes!!!!
bbuehler is offline   Reply With Quote
Old 07-03-2011, 08:26 AM   #4
vinogirl's Avatar
Trailer: Winnie drop hopeful, Bambi airstream, Boler 1975 AND 1980
Try using boat cleaner that deoxidizes. Worked on mine.
Got it from Home Hardware.
vinogirl is offline   Reply With Quote
Old 07-03-2011, 08:34 AM   #5
Will M.'s Avatar
Trailer: 1978 Trillium 13 ft
bbuehler
Barkeepers Friend does work well, but if you are concerned about using acid you should be aware that it contains oxalic acid, the same stuff used in many chrome cleaners. I searched all over to find it after reading about it on this forum. I ended up picking it up at a Lowes in the US. Shortly thereafter my local Home Hardware store started stocking it (three blocks from my home). Go figure! It works very well as a prep for the Redmax and also to clean the glass cooktop on my stove.
Will M. is offline   Reply With Quote
Old 07-03-2011, 11:18 AM   #6
Trailer: 1999 Scamp 16 ft ('The Pod')
Is the Barkeepers Friend you use in powder form or liquid?
Vivian is offline   Reply With Quote
Old 07-03-2011, 02:37 PM   #7
Will M.'s Avatar
I have tried the powder only. I imagine the liquid works just as well but it is more expensive.
Old 07-05-2011, 08:41 AM   #8
Thanks for the tip on Lemon juice Ian!
For sterilizing, use vinegar instead of bleach. Vinegar is just as effective as bleach but completely safe.
Darnelle is offline   Reply With Quote
Old 07-05-2011, 04:35 PM   #9
Ann B's Avatar
Trailer: 1978 Boler 13 ft
bbuehler
you are oh so correct
dumb A$$ at work spilled some DH walked through it --ate through his work boots ,sock & into his skin took months for it to heal!!
Ann B is offline   Reply With Quote
Old 07-05-2011, 06:21 PM   #10
The very best way to deal with rust... is to PREVENT it. Pay attention to the needs of the trailer and take care of rust as a maintenance issue. When items start to rust, either seal it up or replace. It's far easier than dealing with rust on the gelcoat.
Old 07-06-2011, 10:46 AM   #11
Carol H's Avatar
3M's boat Restore & Wax will also take the stains off.
Old 07-09-2011, 01:17 PM   #12
For rust stain removal on fiberglass I use oxalic acid which not as aggressive as hydrochloric acid; it doesn’t generate nasty fumes as HCl does. I would never use full strength (36% by weight) HCl. For tough rust stain I mix it with mildly aggressive aqueous polishing fluid and rub the stained area using gloves.
George.
WEST MARINE Cleaner at West Marine
GeorgeR is offline   Reply With Quote
Mold stains on rat fur Richard Davis Problem Solving | Owners Helping Owners 9 08-16-2010 06:45 PM
Black Roof Stains Tamid Problem Solving | Owners Helping Owners 1 04-26-2010 07:32 PM
Rust, Rust Everywhere! Rick Harmer Problem Solving | Owners Helping Owners 10 09-20-2009 09:37 PM
TREE STAINS on the ROOF??? Alf S. Care and Feeding of Molded Fiberglass Trailers 32 09-22-2008 05:18 PM
Resin stains Legacy Posts Care and Feeding of Molded Fiberglass Trailers 18 04-30-2003 05:10 AM
